Clicking faults in LG plasma TVs
  • fzabkar
    • Mar 2009
    • 772
    I have an intermittent clicking fault in an LG 42PJ350 plasma TV. I saw the problem once, but I have not been able to reproduce it after taking the back off the set. I am proposing to compile as much information about this problem as I can.
    Here are just a few related threads:
  • fzabkar
    • Mar 2009
    • 772
    Re: Clicking faults in LG plasma TVs
    PSU = p/n EAY60912401
    IC701 = MC81F4316
    IC701 markings:
    • V1.2A-D99D
      F4316MSF17
      KOREA
    Datasheets for PSU ICs:
    ICE3BR1565JF, Infineon, FF CoolSET, TO-220-6, 68W/125W, 67kHz, 1.5ohm RDSon:
    *** could not find datasheet
    Infineon Solution for LED TV SMPS (shortform catalogue):
    https://cdn.badcaps-static.com/pdfs/...ed91163bc3.pdf
    ICE3BR0665JF, Infineon, FF CoolSET, TO-220-6, 110W/200W, 67kHz, 0.65ohm RDSon, 650V:
    https://cdn.badcaps-static.com/pdfs/...1a485dfec1.pdf
    ICE3BR1065JF, Infineon, FF CoolSET, TO-220-6, 80W/144W, 67kHz, 1.0ohm RDSon, 650V:
    ICE3BR2565JF, Infineon, FF CoolSET, TO-220-6, 55W/90W, 67kHz, 2.5ohm RDSon, 650V:
    AN-EVAL3BR2565JF, 40W 18V SMPS Evaluation Board with CoolSET-F3R ICE3BR2565JF:
    ENPC Workshop: Auxiliary Power Supply Solution --- CoolSET:
    https://cdn.badcaps-static.com/pdfs/...e3bff90cb7.pdf
    ICE3BR2565JF OR ICE3BR1565JF OR ICE3BR1065JF OR ICE3BR0665JF filetype:pdf
    L6599A, STMicroelectronics, high-voltage resonant controller:
    https://cdn.badcaps-static.com/pdfs/...475bf7d342.pdf
    AOD484, Alpha & Omega, 30V 25A N-Channel MOSFET:
    PC-17K1, Kodenshi, photocoupler, 1 channel:
    D15XB-60H, Shindengen, 600V 15A, Bridge Rectifier:
    SDURF1040CTR, SANGDEST, dual ULTRAFAST PLASTIC RECTIFIER, ITO-220AB, 10A 400V:
    FQPF27P06, Fairchild, P-Channel QFET MOSFET -60V, -17A, 26mohm:
    https://cdn.badcaps-static.com/pdfs/...51f9616739.pdf
    FMEN-220A, Sanken, dual Schottky Barrier Diode, 100V 20A:
    https://cdn.badcaps-static.com/pdfs/...3aceca0c52.pdf
    KIA431A, KEC semiconductor, PROGRAMMABLE PRECISION REFERENCE, TO-92, 1%, 2.5V:
    KIA2431A, KEC semiconductor, PROGRAMMABLE PRECISION REFERENCE, TO-92, 1%, 1.24V:
    TK13A60D, Toshiba, N-Channel MOS Type (p-MOS VII), 600V 13A:
    http://toshiba.semicon-storage.com/i...dName=TK13A60D
    FMX-22S, Sanken, dual High Frequency Rectifier, 200V 10A:
    FQPF10N20C, Fairchild, N-Channel QFET MOSFET 200V, 9.5A, 360 mohm:
    FCF10D60, Nihon (NIEC), dual FRED diode, 10A 600V:
    FML-G13S, Sanken, High Frequency Rectifier, 300V 5A:
    https://cdn.badcaps-static.com/pdfs/...79a5e57c44.pdf
    SD14N60, Infineon, MOSFET 600V 14A TO220F:
    R2A20117, Renesas, Power Factor Correction Controller IC:
    (R2A20117)
    https://cdn.badcaps-static.com/pdfs/...c97488ec96.pdf (R2A20111)
    https://cdn.badcaps-static.com/pdfs/...9b0eeb4c40.pdf (R2A20118)
    MC81F4316, ABOV Semiconductor, 8-bit Single-chip Microcontroller, 28-pin, 16KB flash, 512B RAM, 2.2V - 5.5V @ 4.2MHz:
    MC81F4315, ABOV Semiconductor, 8-bit Single-chip Microcontroller, 28-pin, 16KB flash, 512B RAM, 2.2V - 5.5V @ 4.2MHz:
    • fzabkar
      • Mar 2009
      • 772
      Diagram of PFC voltage detection circuit (may contain errors):
      • BR- is the negative terminal of the bridge rectifier (hot side of PSU).
        GND is the Vss pin of U701 (cold side of PSU).
      Code:
           from auxiliary     D609
            supply (ZD301) >------>|-----+---------------.
                       +5V  .-. 2K7     |
                       ___  | | R628     |
                       1|   '-'4       |
                   PC103 | V -> |  |       |
                       2|   3|       |/
                       .-.   +----->|------| Q605
                    R727 | |   |   D    |>
                     1K | |   z        |
                       '-'   A        |
                       |   | ZD601     |
                       V   |        |
                      U701-4 ===       |
                          GND       |
               0 ohm  |    |          |
                R114  |    |          |
                ___   z    |          .-.
              .--|_0_|--->A    |       R123 | |
              |      | IC102 |        1K5 | |     +5V
           C110 ---     | TL431 |          '-'     ___
              |      |    +--------------------+----.1   | 4
                   BR-   ---       R122 | | | V -> |  |
                        ---       1K5 | | | -  |> |
                        | C109       '-' | |   | |
               680K 680K 560K |          | '-|------|-' R728
              680K 680K 620K   |          +----'2  3|  ___
               __  __  __  |          |   PC101 +--|___|--> U701-27
               | | | | | |  |       ZD101 z      |  1K   PFC_detect
              .-..-..-..-..-..-. |          A      |      to CPU
       from      | || || || || || | |  13K   20K   |   R733 | |
       APFC      '-''-''-''-''-''-' | R115  R118   |   22K | |
       supply     | | | | | |  |  ___   ___  |/      '-'
        o-+----+------' '--' '--' '---+--|___|-+-|___|-+-| Q101    |
         |  |  R108 R110 R112       |    | |>      |
         |+  |+   R109 R111 R113     .-.12K  |  |     ===
        === ===                | |R117 --- |     GND
        /-\ /-\                | |   --- |     Vss
         |  |                 '-' C111 |  |    U701-24
       C617|  |C616               |    |  |
        o-+----+--------------------+-------------+-------+---+
         2x 150uF         |
          450V         ===
          105C         BR-
      • fzabkar
        • Mar 2009
        • 772
        Links to training manual, service manual, exploded view. and parts list:
        http://www.jordansmanuals.com/Defaul...&Model=42PJ350
        http://www.jordansmanuals.com/Servic...rts%20List.csv
        • fzabkar
          • Mar 2009
          • 772
          I will post the diagram for the AC Detect circuit in due course.
          In the meantime I would very much appreciate opinions on the function of IC102 (TL431). I confess I don't understand what it does. AISI, C110 would be charged by Iref (the current out of the reference pin) until its voltage reaches 2.5V, at which point IC102 would turn on thereby switching off PC101. But why?
          • fzabkar
            • Mar 2009
            • 772
            Here are some hires scans of the rear of the PSU.
            • fzabkar
              • Mar 2009
              • 772
              Trying again ...
              • fzabkar
                • Mar 2009
                • 772
                ... and again ...
                • fzabkar
                  • Mar 2009
                  • 772
                  AC Detect circuit:
                  Code:
                          63V
                      D303  C308            D307
                          47uF R307
                     o-->|---+---+----+----+----------------->|----+------> VCC
                   from    |  |  |  |            |    IC301
                   auxiliary  |  |  .-.2K |            |+  ICE3BR1565JF
                   winding   |  |+ | |  |        C307 ===
                   of xfmr   z === | |  |        33uF /-\
                         A /-\ '-'  |         50V  |
                      ZD301 |  |  | |/ 2SC3198        |
                         |  |  +--| Q301         ===
                         |  |  | |>            BR-
                         |  |  |  | J121  ___
                         |  |  z  '-o--o--|___|-----.
                         |  |  A           |
                         |  |  |ZD302    R125   |
                         '---+----+       10K   o
                             |         J20 )     +5V
                             ===           o     ___
                             BR-           |      |
                                         +----.1   | 4
                                        .-. | |  |/ | PC-17K1
                                        | | | V -> |  |
                        240K 150K         1K8 | | | -  |> |
                       240K 150K 100K          '-' | |   | |
                        __  __  __          | '-|------|-' R729
                        | | | | | |         +----+2  3|  ___
                       .-..-..-..-..-. |         |  |PC102 +--|___|--> U701-28
                       | || || || || | |         |  |   |  10K   AC_detect
                       | || || || || | |      IC101 |  |   |      to CPU
                       '-''-''-''-''-' | R119   KIA431 |  |   |
                    D102  | | | | | | ___      \_|_  |   .-.
                    o-->|---' '--' '--' +-|___|--+---+--->/_\\ |   | |47K
                       R103 R105 R107 |    |  |   |  |   | |R732
                   Active   R104 R106  | 100K .-. |   |  |C112 '-'
                            C108 ---   | | ---  |  ---   |
                               |  91K '-' |C113 |  |   ===
                               |  R120 |  |   |  |   GND
                                        BR-
                  • bffargo
                    2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                    by bffargo
                    LG 60PB66550 NOV 2014
                    PSU: EAY63168603
                    PCB: EAX65359531 2013.11.01 Rev:1.0
                    Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                    Symptom:
                    While watching, just went black and started clicking relay every few seconds.
                    Initial diagnosis:
                    Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                    Deeper diagnosis:
                    Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                    09-09-2022, 07:34 PM
                  • Sisko
                    Onkyo-593 No power and now clicking sound
                    by Sisko
                    Hi all!!
                    Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                    10-03-2025, 02:18 PM
                  • B0r1s
                    Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                    by B0r1s
                    PSU - BN44-00878A
                    Symptoms:
                    The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                    A weak clicking sound was coming from the transformer.
                    Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                    Progress:
                    After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                    01-17-2023, 04:58 PM
                  • novak2
                    Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                    by novak2
                    Hello there,
                    I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                    The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                    From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                    Thanks in advance.
                    09-25-2020, 02:34 PM
                  • slimmy182
                    [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                    by slimmy182
                    Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                    I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                    Looking on google I found this:...
                    01-14-2023, 11:55 AM
