LG 50PK550 Plasma Clicking Problem
  • jun3280net
    • Jan 2014
    • 10
    Hello there,
    I'm a complete beginner, so I apologize in advance if it takes me a bit longer to digest some of the instructions and technical aspects of troubleshooting. That said, I'm excited to post as I've seen how helpful the members at badcaps are.
    My LG 50PK550 plasma television recently just began to experience the dreaded clicking problem, where the TV will immediately shut off or go into standby mode upon power up.
    I can confirm I get a grey flash upon power up, and the tv screen will go black 1-2 seconds later. From time to time, I can get a sustained picture for 5-10 min before it shuts off again.
    I've ready many posts for variants of the LG Plasma PK540, PK590, etc, which suggest it's due to a bad resistor on the upper right side of the power board. Most of the boards I've read consist of 2 x 5W22 Ohm resistors. My board has 3 x 5W10 Ohm resistors. I measured them, and they seem stable at 10 Ohms. I swapped out the one resistor that seemed to fluctuate, but no difference. I tested the resistor afterwards, and it held stable at 10 Ohms.
    When the boards are connected, the TV will turn on for a couple seconds, flash “grey”, and then shut off. I am unable to measure the voltages.
    To troubleshoot, I disconnected the Z-SUS and Y-SUS from the power board, and I was able to measure the voltages. They are as follows :
    On the power board (A)I measured :
    P811 to Z-SUS (B) :
    (M5V=5.4V, M5V=5.4V, GND=0V, VA=60.8V, VA=60.8V, GND=0V, GND=0V, NC=0V, VS=202V, VS=202V)
    P812 to Y-SUS (C) :
    (M5V=5.2V, M5V=5.2V, GND=0V, VA=60.7V, VA=60.7V, GND=0V, GND=0V, NC=0V, VS=202V, VS=202V)
    P114 connector (bottom of Y-SUS) :
    (60.2V, 60.2V, 60.2V, 60.2V, 0V, 0V)
    P813 to Main Board (D) :
    (17.1V, 0V, 5.2V, 5.2V, 0V, 0V, 5.2V, 2.3V, 3.2V)
    When I connect just the Z-SUS (B), and power up, there is no picture, but the sound is on. The device is able to sustain power.
    When I connect just the Y-SUS (C), and power up, it flashes “grey” and shuts off shortly after.
    When I connect just the Y-SUS (C) – but remove the connections to (1) – the unit powers up, flashes a red screen for a few seconds and then shuts off.
    Any other ideas as to what might be the problem - or other items to test? Thanks in advance for your insight and assistance.
    Thanks,
    J
    Re: LG 50PK550 Plasma Clicking Problem
    Just above "A" there is a sticker with a part # e.g. "Model: PDP50N7####" printed what is yours?
    • jun3280net
      • Jan 2014
      • 10
      Hi there,
      It looks like PDP50R10000.
      Thanks,
      J
        Your panel is covered in this document
        Find the 50R1 panel.
        Of note is the section on -Vy and Vsc testing, please perform this test while set operates and when it malfunctions.
        • jun3280net
          • Jan 2014
          • 10
          Thanks for the link to the document tom66. I've been unable to get to my parents place to test their television, due to a busier than normal work schedule this past week. I'll try and follow your guide later this week - and post my findings then.
          In regards to this section - for the Pre-Heat - does that mean leave leave the TV on for 10 min? If so, it seems hit and miss as usually the TV shuts off after a few seconds. Does that mean I should disconnect the Y-SUS to ensure the TV remains on for 10 min - before reconnecting it again to test?:
          "50R1 VSC, -Vy ADJUSTMENTS
          PREPARATION:
          PROCEDURE: (See figure below for locations)
          1) Adjust –Vy VR302. Measured across –Vy TP R334.
          Match your specific Panel’s Voltage label ±1V.
          1) Pre-Heat unit for at least 10 Minutes
          before making adjustments.
          Vs and Va adjustments complete.
          2) Place unit into White Wash from the
          Customer’s Menu for all adjustments.
          3) Be sure to use all adjustment values as
          indicated on your panel’s voltage label in
          the upper left of the panel.
          2) Adjust VSC VR301. Measured across VSC TPs R324.
          Match your specific Panel’s Voltage label ±1V."
          Cheers
          • bffargo
            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
            by bffargo
            LG 60PB66550 NOV 2014
            PSU: EAY63168603
            PCB: EAX65359531 2013.11.01 Rev:1.0
            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
            Symptom:
            While watching, just went black and started clicking relay every few seconds.
            Initial diagnosis:
            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
            Deeper diagnosis:
            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
            09-09-2022, 07:34 PM
          • Sisko
            Onkyo-593 No power and now clicking sound
            by Sisko
            Hi all!!
            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
            10-03-2025, 02:18 PM
          • B0r1s
            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
            by B0r1s
            PSU - BN44-00878A
            Symptoms:
            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
            A weak clicking sound was coming from the transformer.
            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
            Progress:
            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
            01-17-2023, 04:58 PM
          • novak2
            Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
            by novak2
            Hello there,
            I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
            The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
            From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
            Thanks in advance.
            09-25-2020, 02:34 PM
          • slimmy182
            [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
            by slimmy182
            Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
            I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
            Looking on google I found this:...
            01-14-2023, 11:55 AM
