LG 42PJ350 Starts, Shuts down, won't restart
  • dkneyle
    • Dec 2013
    • 441
    Classic symptoms. Start up from cold OK. Runs OK for a period of time. Then starts to go into an auto restart routine. Eventually even this doesn't work and it just dops into the relay clicking on-off scenario. Disconnecting from the mains isn't enough to get it going again. It must be left for some hours before it will re-start and then repeats the same symptoms.
    I'm assuming it's the power supply. All caps physically look OK.
    Lots of clues out there on the interweb for the 'no-start clicking relay' type scenario, but not actually for my situation.
    Before I start randomly replacing electro capacitors I thought someone might have a suggestion for me? I even read elsewhere on this forum that it could be the regulating IC acting up once it gets hot.
    As always, good advice is much appreciated.
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: LG 42PJ350 Starts, Shuts down, won't restart
    Sounds like temperature related problem.
    If you have a hair dryer and a can of air(to clean pc out etc) then you can pin point the problem relatively easy...
    Start with TV cold,so it would work like you said,have back cover off TV,aim hair dryer at let's say the power supply board and heat it up,see if TV acts up,should be able to replica the fault in like a minute...
    Once you found the board that reacts to the heat,you then take the can of air,hold it upside down and spray on parts of that board,the freon that now comes out of the can will freeze components,the temp sensitive part/area will reveal itself
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • dkneyle
      • Dec 2013
      • 441
      Thanks for the troubleshooting advice Martino. In fact I too was thinking of going down that line. Then I went looking for a can of spray freeze and was surprised at the cost. About $50. Still, the more I'm doing this servicing work I need to build up a supply of basics. Years ago when I worked in the telecommunications industry I had easy access to things like spray freeze and didn'tthink about it. No that I'm starting to move from hobbyist into professional tech repairer I realise that I have to have these things for myself. I'll let you know how I go. My guess from reading other posts is that it's the regulating IC.
      • tw2005
        • Oct 2011
        • 6458
        A cheap can of air inverted will generally do. Maybe $8-10
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          I use just a plain can of air,they are cheap,like 8 bucks here in Canada...They don't really last too terribly long but enough to do several trouble shooting projects...Didn't know the official freeze spray was that costly,wow....
          • dkneyle
            • Dec 2013
            • 441
            Well, the story moves on. It was re-sarting after cooling all OK. So it came time to remove the power supply board and have a closer look. I did nothing to the board. I put it back in-situ and now it won't restart - just your classic relay clicks. Anyway, this may be a good thing because at least now the fault is there all the time.
            There are repair kits available on E-Bay/Internet for this power supply board, and the components give a good clue as to the regular failing parts. I've been looking around the vicinity of the 6 terminal power regulator. Type 3BR1565JF. There is a Schottky diode (40V 1A) [type SD140 for anyone trying to track that part down] in parallel with a resistor (R305) which appears to be 0.36 ohms from the colour bands. Out of circuit the diode reads OK, and my meter doesn't have accuracy at that low level of resistance but reads 0.6 ohms so the resistor is probably OK (shows no signs of distress). But I'm a bit mystified how the diode does it's job if shunted by such a low value of resistance?
            I'm going to order a replacement 3BR1565JF and see whether that brings it back to life.
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Double checked if all cables where plugged in correct??
              When you froze the powerboard,could you pinpoint the area where it was temp sensitive?
              Did you check the solder side to look for any bad solder joints?
              • dkneyle
                • Dec 2013
                • 441
                I didn't get an opportunity to heat and freeze because it went into a permanent fail state before I could get to that step. The solder joints all looked good. I'm betting on that 3BR1565JF device as being the cuplrit. I'll report back when I have taken that next step.
                • dkneyle
                  • Dec 2013
                  • 441
                  Replaced the 6-terminal regulating device 3BR1565JF and the set powered up no problem and has been heat soaked and continues to work OK. I looked at the data sheet for that device and the typical circuit shows a low value resistor used for current sensing that has a reverse biased diode across it. As I said above, both of these checked out OK. Purchased the device from Macau, landed in Oz for <A$5, and I probably paid too much anyway! So this plasma goes back into service for less than the cost of a hamburger. I suspect these devices have substitutes; I notice in another post a SMPS problem that seem to revolve around a 6-terminal regulator part number STW6765 which sounds very similar (but check first if you are reading this post).
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    Nice repair.!! And thx for reporting your findings
                    • Amraks
                      • Nov 2011
                      • 725
                      Just got one of these tv's same symptom. So replacing this works?
                      • dkneyle
                        • Dec 2013
                        • 441
                        G'Day mate, we'll it worked OK for me. I got the device from China via E-Bay. Let me know how you go.
                        • Amraks
                          • Nov 2011
                          • 725
                          Cheers I picked the setup for 20 dollars I thought it was stolen for a about 1 hour until it turned it self off.
                          from where I got it is a dodgy place.
                          I will order it seems like it has ur symptoms.
                          Gotta replace the Coax Plug on the mainboard. should be a simple fix, I will remove tuner from main and solder in a new rf plug.
                          • dkneyle
                            • Dec 2013
                            • 441
                            I think I paid about $5 for that regulator chip. I'll be very interested to hear how you go. I believe the set I repaired is still going strong; it hasn't bounced anyway.
                            • Amraks
                              • Nov 2011
                              • 725
                              Well that never worked took a 40 mins to turn off.
                              • Amraks
                                • Nov 2011
                                • 725
                                wondering if its these 5W22RJ resistors in this location R927 R929 and I hope my new 3BR1565JF hasn't shorted.
                                • Amraks
                                  • Nov 2011
                                  • 725
                                  r929 22.03oHms
                                  r927 22.00oHms
                                  so not them guys..
                                  • dkneyle
                                    • Dec 2013
                                    • 441
                                    Good news, bad news. We are on the right track. We know that the original 3BR156JF was dead. But now the replacement is also. Order another one of those. It failed in order to protect the 2c component somewhere else! I need to look at the circuit diagram, but I reckon there's a snubber diode somewhere close by that IC that has probably gone open circuit. You look around with your meter and I'll try to find it on the circuit diagram.
                                    • dkneyle
                                      • Dec 2013
                                      • 441
                                      • Amraks
                                        • Nov 2011
                                        • 725
                                        The original one would do the samething.
                                        It would go for 40 mins and shut down and it would keep clicking when turned off.
                                        The snubber diode you are talking about tests bad in circuit but tests good out of circuit..
                                        I will buy some freeze spray.
                                        • chaos-theory
                                          Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                          by chaos-theory
                                          I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                          Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                          03-14-2025, 05:37 PM
                                        • Shobos
                                          Dell E6420 XFR Rugged starts to boot but after 3 secs shuts down.
                                          by Shobos
                                          Hi, I bought 6420 XFR that tries to boot but shuts down after about 3 seconds, CPU gets warm, fan starts.
                                          So far I have tested all rails wich are good, BIOS flashed with CH341, 3.3,5, main rail present. multiple ram sticks tested. Sometimes it might stay on for longer like 4-5 seconds but not always, theres no picture whatsoever. Also on some rare occasions the caps lock flashes 1 time by itself.
                                          NOTE: I am using bench power supply not dell charger with ID pin and NO battery present, kinda doubtful this would cause this issue.
                                          Any help is welcome. Thanks !
                                          07-29-2025, 03:53 PM
                                        • PowerAmpFreak
                                          LG OLED 65B7V starts with green screen a few seconds then shuts down
                                          by PowerAmpFreak
                                          LG OLED model 65B7V starts up with green screen for a few seconds then shuts down.
                                          Can this be a sign of shorted ceramic caps in the T-con ?
                                          Best,
                                          10-07-2022, 10:27 AM
                                        • Christian0734
                                          Power Issue with ASUS A705UA.
                                          by Christian0734
                                          Hello
                                          The PC starts and shuts down correctly when the battery is removed. However, if I hot-plug the battery, it starts charging as if everything is normal. However, when I turn off the computer and then restart it, there is no display on the screen. The battery indicator blinks slowly, the fan runs, and the power consumption is approximately 520 mA, as if the computer is in standby mode. At this point, even if I disconnect the power supply, the computer doesn't start up normally anymore. Pressing the power button to force a shutdown works, but as soon as I release the button, the...
                                          09-13-2023, 03:04 PM
                                        • shouri
                                          Dell latitude e5490 auto restart
                                          by shouri
                                          Hi guys, can someone help me?
                                          I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                                          Board model is dm70 la-f401p rev:1.0 2017-09-20.
                                          At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                                          After a few days test, is seems ok.
                                          Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                                          12-10-2024, 09:27 PM
