LG 42PJ350- No picture
  • ascertain
    • Jun 2014
    • 8
    Hello all, I've been looking for a forum like this for a while...glad I found it!
    I have a LG 42PJ350 that my neighbor gave me for free because it wont turn on. I figured I would give it a go and hope I can fix it. When I initially plug it in I hear two clicks "Click....Click" and the stand-by light illuminates. However, when I push the power button, nothing happens except the stand-by light extinguishes. I did some research on the model and someone suggested I change capacitors C360 and C351 on the power supply board. I changed them and still have the same issues. I have checked the three fuses on the Y-SUS board and the three fuses on the power supply board (all check good). I then disconnected the Y-SUS board and tried to power on the TV, still no voltage at VS and VA. I didn't want to randomly pull any other components off the board just to put a meter on them, however, if you suggest it, I'm willing to try anything. Any thoughts?
    Thank you in advance...
  • sordids999
    • May 2013
    • 2152
    • uk
    Re: LG 42PJ350- No picture
    You could try changing the x2 5W22RJ resistors on the power unit should be R927 R929 worked for me when i had the same problem clicking when trying to power up the tv
    • ascertain
      • Jun 2014
      • 8
      It only clicks when I plug it in initially. It won't click when I push the power button. Do you still recommend I change the resistors? Thanks
      • sordids999
        • May 2013
        • 2152
        • uk
        https://www.badcaps.net/forum/showthread.php?t=37530
        This may help you worth a try
        • ascertain
          • Jun 2014
          • 8
          Great read. Thanks. I changed both resistors. Unfortunately, it didn't fix the issue. Still doing the same. Any ideas? Thanks.
          • sordids999
            • May 2013
            • 2152
            • uk
            hello maybe Tom66 might be able to help you more he might reply
              You checked Vs & Va from Y-sustain board using a volt meter?
              • ascertain
                • Jun 2014
                • 8
                Sorry for not getting back to you any sooner, I was out of town for the 4th of July...
                Update...I plugged in the TV, hit the power button, and it turned on!!! The picture was perfect. Unfortunately, after I turned it off it wouldn't turn back on
                Tom66, I checked for power on the power supply board (top left connector on the picture). It's the connector that connects the YSUS and the power supply board together. There was no power there.
                Thank you.
                • ascertain
                  • Jun 2014
                  • 8
                  Any thoughts from anyone?
                  • martino
                    Not so "senior"
                    • Aug 2013
                    • 997
                    • canada
                    Can we get a pic from the plug that goes from the powerboard to the mainboard? Should be a printing beside it telling what wire does what... like standby power,power-on etc...
                    Proud owner of dozens of broken TV's and many,many,many boards.
                    Our website and passion:http://hollenhundshepherds.com/
                    • ascertain
                      • Jun 2014
                      • 8
                      Martino, I have attached the picture. Thanks
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        I'm kinda curious if you get the power-on signal from the mainboard or not..
                        Kinda hard to read on that pic....Having a standby light would suggest the 5 volt standby is working,do you get any voltage on pl-on and m-on? (not totally sure,which on turn on the powersupply to be honest)..
                        • ascertain
                          • Jun 2014
                          • 8
                          I have 5 vdc on both rl_on and m_on. I attached a better picture of the connector. Thanks
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • ermals
                            Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                            by ermals
                            Hi all!
                            I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                            1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                            2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                            3. I've checked voltages...
                            08-01-2022, 10:35 AM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
