LG 42PJ150. Clicking Clicking Clicking
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Hi guys,
    Got this plasma for cheap.
    When i turn it on it just clicks 3 times and then repeats the same thing over and over again.
    Disconnected the ysus/zsus from the powerboard/mainboard but it keeps clicking so my guess would be the PS.
    I dont get any visual on the screen it stays black.
    All caps look ok.
    Have not measured a LG plasma before so if someone could guide me?
    I will take pictures tomorrow if needed.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: LG 42PJ150. Clicking Clicking Clicking
    Sorry for all the dust, only cleaned the PS.
    • sordids999
      • May 2013
      • 2158
      • uk
      Just a idea here I had the same fault on my 42PJ350 LG once I changed them the tv worked
      I'm gathering that psu has the same rating but no doubt tom or more will reply
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Not a problem for me to buy 2 of those ceramic resistors. Is that 22 Ohm?
        • sordids999
          • May 2013
          • 2158
          • uk
          Yes have u checked yours on the psu are the same ?
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Yes same values! Will try that tomorrow. Thx!
            • Amraks
              • Nov 2011
              • 725
              Have you tested these resistors before ordering something you don't need.
              Have you checked 6 legged voltage regulator that is attached to heat sink near the bridge rectifier.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Im going to test those resistors first ofcourse.
                I have not tested that 6 legged voltage regulator , how do i test that? Whats the name for the part?
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  Ok , tested the resistors. Both are 22 OHm.
                  I replaced all the small capacitors except the 3300uf.
                  Took the board with me to work and unsoldered the 3300uf and the value is 3900? Took a brand new 3300 and the value is 3330.
                  Could this be the reason its not starting up?
                    No, probably not.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      Hmm ok , but 3900uf for a 3300 is a bit much?
                      All transistors are ok , the only part that i cant measure is the 6 legged voltage regulator.
                        It still wouldn't cause your fault. Within 20% anyway.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          That sounds like , try figuring it out yourself and if you cant find the problem , i will tell you whats wrong :p
                            I don't know what's wrong, but yes, you should try finding it yourself if you want to do lots of these TVs.
                            How much space do you have? I don't have this many on-going projects...
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              Haha , was just kidding but ill measure the voltage regulator tonight.
                              I have enough space for these projects.
                              • Moreno83
                                • Jun 2014
                                • 2008
                                • The Netherlands
                                Got the panasonic on a hold so ill continue with this 1.
                                Replaced 2 caps ( 3300uf).
                                I just plugged it in and i got 1 click with another click later on and led is on. No more clicks...looks like its running in standby mode?
                                Pressed powerbutton again and led stays on but it continues klicking every 5secs.
                                Nothing happens on the screen.
                                Guessings its the voltage regulator. I read alot that replacing this part does not fix the problem.
                                More time tomorrow for this tv! Any tips are welcome!!
                                  When you get continuous clicking do you get good Vs/Va voltages?
                                  • Moreno83
                                    • Jun 2014
                                    • 2008
                                    • The Netherlands
                                    There are no voltages going to the SS board. M5v / gnd / nc / v5 / va are all 0v.
                                    The only voltages i measure are on 2 pins on the cable going to the mainboard. They are 4v and 5v rest is 0v on the same cable.
                                      Ok, I think it's a good idea to rule out the main A/V board.
                                      Disconnect the connector from power board to main board. Leave main board end unplugged.
                                      Connect AUTO_GND and GND together on this connector.
                                      Everything else connected as normal.
                                      Plug set in, do you get relay clicks, do you get Vs/Va, and a slight glow from the plasma display panel?
                                      • Moreno83
                                        • Jun 2014
                                        • 2008
                                        • The Netherlands
                                        I bridged the gnd/auto gnd and put in in the mains. The relays click ( click click click) and nothing comes on the screen and voltages stay 0v.
                                        The 5v/4v are still the same but the relays stop clicking! ( loop)
                                        • bffargo
                                          2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                          by bffargo
                                          LG 60PB66550 NOV 2014
                                          PSU: EAY63168603
                                          PCB: EAX65359531 2013.11.01 Rev:1.0
                                          Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                          Symptom:
                                          While watching, just went black and started clicking relay every few seconds.
                                          Initial diagnosis:
                                          Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                          Deeper diagnosis:
                                          Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                          09-09-2022, 07:34 PM
                                        • alfredomfr1
                                          TV Plasma LG 60PN5000 ZSUS 15v missing
                                          by alfredomfr1
                                          All Voltages are OK except ZSUS 15v.
                                          YSUS board disconnected still 15v missing.
                                          ZSUS was replaced: 15v missing.
                                          Any help will be appreciated...
                                          04-29-2022, 11:26 AM
                                        • Sisko
                                          Onkyo-593 No power and now clicking sound
                                          by Sisko
                                          Hi all!!
                                          Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                          Yesterday, 02:18 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • novak2
                                          Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                          by novak2
                                          Hello there,
                                          I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                          The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                          From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                          Thanks in advance.
                                          09-25-2020, 02:34 PM
