lg 42pj550 zd Clicking Noise
  • Jahson
    • May 2012
    • 245
    Anyone knows the parts needed to repair this fault, its a common fault on the LG's. Seen a few vids on Utube, detailing the fix.
    Volatage Regulator, 2 ceramic resistors, diode, fuse maybe.
    Don't want to be buying the kit, sure I can save a penny not buying this.
    Yes the Tv is not here, fault has been describe to me and heard over the phone.
    Tv can work for random amount of time then click, click, shut down, Or never turn on sometimes.
    LG 42PJ550 ZD
  • Jahson
    • May 2012
    • 245
    Re: lg 42pj550 zd Clicking Noise
    I've removed a diode location d304 it says SR104 a11. tested with DMM it reads 0.234 is this correct not between (0.5-0.8)
    • paulstef
      • Dec 2013
      • 724
      It will be hard to troubleshoot that over the internet and then over the phone.
      The diode you found is a schottky diode, which in general have a lower voltage drop than "normal" diodes. If in doubt, a good source for datasheets is Alldatasheet.com.
      What you measured looks more or less ok to me, see figure 2 in this datasheet:
      http://pdf1.alldatasheet.com/datashe...DES/SR104.html
      If it randomly turns on, and off first thing I would check are bad contacts, bad soldering (check with magnifying glass), then electrolytic capacitors, only then semiconductors.
      • Jahson
        • May 2012
        • 245
        I've now got the tv in my position, will be posting pix later, but im too piss Liverpool beat Man U so forgive.
        That diode was bleeping when in circuit so removed it that's the reading im getting.
        was going test the voltage regulator next.
        • Jahson
          • May 2012
          • 245
          Did a few more checks, removed this resistor, pink body think it should be 368 or 36.8 ohms? used a resistor color code but couldn't get the 4th & 5th band correct.
          I explain 4th should be silver but only seen grey, and couldn't select the 5th band as black.
          When I test resistor on DMM it reads something like 2.3 ohms.
          From the pictures the diode & resistor has been removed.
          Top of my head locations D304 & R305 near heat shield.
          • Jahson
            • May 2012
            • 245
            Changed my DMM that pink resistor reads 000.4? is that correct
            • paulstef
              • Dec 2013
              • 724
              Resistor seems to be 0.36R, so it's ok.
              If you know what's in the kit, buy the parts and try it out. Otherwise some troubleshooting is necessary.
              Did you check for bad solder joints?
              • Jahson
                • May 2012
                • 245
                Yea ive worked out whots in the kit, got the parts, The 2 ceramic resistors they measured ok 22.1 ohms, but I still changed them.
                The diode measured 0.234 which I told was ok, measured against new about the same ish. (Just had a look on datasheet is between 0.2-0.4) cheers paulstef.
                The problem is the tv could work for a few hours then shut down, then you get the clicking sound on trying to restart.
                Some time you could leave the tv for a while it may or may not start again.
                I've have a good look around only for bad caps & tested all diodes, have not looked for dry joints as suggested.
                That voltage regulator, next to the diode & resistor I removed, cant remember the part number (at the top of my head 3br1565jf). Not sure if the readings im getting are correct, but think its ok, when tested against new part.
                Did try looking at the datasheet, but cant make head or tails whot I should be reading on the datasheet.
                Last edited by Jahson; 03-22-2014, 07:33 AM. Reason: Thinking i just unstood a datasheet :)
                • paulstef
                  • Dec 2013
                  • 724
                  So it's a heat related problem. Quite easy to find out.
                  It's probably either caps or bad solder joints, possibly a semiconductor too.
                  Get yourself a can of cooling spray and a heatgun (or hairdryer). Disconnect the unit from mains. Then heat up the whole power supply. MAKE SURE NOT TO OVERHEAT THE UNIT. You should still be able to touch components!!.
                  Try to start up the unit. It probably won't. Use cooling spray in a small area of the PCB, start with smaller caps. Always only a small area! Wait a few seconds, see if it starts again.
                  You can find the exact component that's faulty by this method.
                  You still didn't say if you looked for bad solder joints. If you don't know what to look for google "bad solder joint" and switch to "images".
                  • Jahson
                    • May 2012
                    • 245
                    when you say cooling spray, do mean something like this :> http://www.ebay.co.uk/sch/i.html?_sa...g+spray&_frs=1
                    • paulstef
                      • Dec 2013
                      • 724
                      Probably similar yes. I meant this one: http://www.maplin.co.uk/p/servisol-f...ay-200ml-re77j
                      Only apply it on a small area and also only short bursts. And don't spray it on your skin. It hurts.
                      • Jahson
                        • May 2012
                        • 245
                        Cheers maplins not to far from me, do I need to spray while the tv set is on, or do I spray when off, turn on check.
                        Only spray the semiconductors, voltage reg's, diodes, Zdiodes, resistors etc.
                        • paulstef
                          • Dec 2013
                          • 724
                          You can leave it on, it's easier this way. Start with electrolytic capacitors. The smaller ones. As explained you need to bring the set in the condition where it doesn't work. Spray one cap, wait a few seconds. See if it turns on. If it doesn't next one... and so on.
                          Check for bad solder joints (visual check)
                          • Jahson
                            • May 2012
                            • 245
                            Cheers last time it was on it stay on for 4-5 hours, had to turn it off to go bed.
                            Aint turned it on from ive removed those few named bits. 5w22 resistors, diode, pink resistor.
                            Been on a go slow today coz of all the footy to watch.
                            Will check for dry joints right now, will pick up the cooling spray in the morrows.
                            • Jahson
                              • May 2012
                              • 245
                              Removed 2 diodes D801 & D802
                              Are these readings correct for these diodes
                              SR104 A11
                              0.228
                              don't know how to read data sheets, sorry
                              • Jahson
                                • May 2012
                                • 245
                                Just a update
                                Couldn't get the set to repeat the fault, had it on for endless hours, turning it off & on, all different times didn't miss a beat for 6 weeks.
                                Give it back to owner, next day they said it wasn't working?
                                I let you guyz know when I get it back
                                • Fernandomar
                                  • Feb 2015
                                  • 3
                                  • Portugal
                                  Hi Jahson Were you able to fix the problem? I have the same problem as you do with an LG plasma and can't figure out the value of that resistor. Has anyone explained its value to you? If it has, I would like to know. Thanks.
                                  • Viejo
                                    • Dec 2013
                                    • 3
                                    • United states
                                    Hi i have problem whit plasma tv model 60pk250 only click and click on some time came for 2 minute then goes and click and click some help to fix needed
                                    • sordids999
                                      • May 2013
                                      • 2152
                                      • uk
                                      Test the parts highlighted and if If heating/cooling ic701 makes no difference then there are a set of 11 smd resistors on the back in parallel with ic701 they can go bad
                                      • tboy6969
                                        • Apr 2016
                                        • 6
                                        • canada
                                        I tested my white ones but the little black one gives me -55 on svc and 3 on acv. Can you please tell me what I should do. Thank you.
                                        • NConstantinou
                                          HP Z840 workstation power supply clicking noise
                                          by NConstantinou
                                          No power
                                          i have the above ps which i change the TOP258eg ic.
                                          Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
                                          i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
                                          the colours look like R,R,W or silver,G Bl.
                                          Thanks...
                                          12-25-2024, 02:24 AM
                                        • tony359
                                          by tony359
                                          11-28-2023, 05:18 AM
                                        • MegaZAC
                                          Onkyo TX-SR805 noise in one channel
                                          by MegaZAC
                                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                          There's some logic behind it. As soon as I select an input I get only left...
                                          04-23-2025, 10:09 PM
                                        • asr
                                          Finding replacement diode iPad Pro 3rd gen A1701
                                          by asr
                                          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                          07-09-2024, 06:24 PM
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
