Hi, I have a LG 42PJ350. There seems to be a problem on the power supply (EAY60912401) the relays keep clicking and the standby light comes on then goes off continually, the voltages at connector p813 come on then go off with the clicking relay. Fuse F801 was blown. I changed the 2 mosfets Q801 AND Q802 which stopped the fuse blowing. I have removed the 2 resistors R927 and R929, both read 22ohms. I have replaced the rectifier IC301 (3BR1565JF) and checked the diode D304 and all the caps look fine. Any help would be appreciated.
42PJ350 clicking noise
Re: 42PJ350 clicking noise
https://www.badcaps.net/forum/showth...hlight=42PJ350
Not sure if this will help but seems the same as yours but.... -
Thanks I read that post already, if I disconnect the left hand connector the relay still clicks and the tv does not come on.https://www.badcaps.net/forum/showth...hlight=42PJ350
Not sure if this will help but seems the same as yours but....Comment
Changed ic801 l6599ad still no joy. The optical light on the control board comes on when the relay clicks then goes off. The voltage to the control board come on when it clicks then drop back to zero. There is no voltage present on the secondary.Last edited by del3165; 06-03-2014, 01:21 PM.Comment
Do you get any brief Vs/Va voltages or are they dead?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hi Have 42pj350 plasma tv making clicking noise removed power supply fitted new resistors r927, r929 3br1565jf regulator new diode d304.
but no joy still clicking.
any help would be appreciated new to the siteComment
Tried disconnecting the Y-SUS and X-SUS boards from PSU and re-testing?
--Whats the voltage on the Vs and Va points of PSU when you do this?TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Hi disconnect the ysus board tv stopped clicking
not sure how you check voltage have multimeterComment
You'll need to check both Y-SUS and X-SUS for shorts......TELEFIX
Hi took the y sus and x sus boards off which parts of the boards do i check
thanks martyComment
Hi checked for shorts found few blown fets on ysus board
diode open near transformer,do you know where i can buy replacement parts?
because can not find replacement board all sold out
cheersComment
Charles Hyde and Sons or fleagay, Ohm-supplies, flat-panel TV spares (or summit) just google 'Kit' and the board number.....
Most of the 'fets' will be IGBT's.....TELEFIX
Hi does any on know what the green resistors are on ysus board just posted 42pj350 just found 2 that are shorted any one know where i can buy them
or what they are
cheersAttached Filesif you find these attachements useful please consider making a small donation to the site
No power
i have the above ps which i change the TOP258eg ic.
Now i have power but is clicking and voltages are flutuating. I change all capacitors, i test all mosfets and all are ok.
i am wondering what is the value of R901! I am getting 0.5Ohms. Is that correct!
the colours look like R,R,W or silver,G Bl.
Thanks... -
by tony359Hi all,
2. Even with the fan running outside of the case, there is still some noise which is clearly going back to the processor via power line....2 Photos -
by MegaZACSurprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
There's some logic behind it. As soon as I select an input I get only left...-
Channel: Troubleshooting Audio Equipment
04-23-2025, 10:09 PM -
by SiskoHi all!!
Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...4 Photos-
by courtcircuitHello
I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
Removed each of tyhe boards
02-08-2025, 08:22 AM -
- Loading...
- No more items.
