Lg 42pj350
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Lg 42pj350
    Hello everyone, today I have this 42" Lg Plasma Tv that came in originally with "clicking fault" turns out the Ysus has shorted igbts. I replaced all the devices that shown as shorted on my meter, removed them, mounted new ones on heatsinks with silicon paste and resoldered them to the board. At the same time I also checked the buffer card and Zsus they check fine nothing obviously shorted, normally on lg sets the Ysus never seems to kill the buffer from my experience ? However plugging the set in it fires on, panel primes and discharges but there is a white band at the bottom of the set then after a few seconds it shutdown. If I unplug the bottom half of the screen the white band moves to the top of the set and it still shuts down however if I unplug all the connectors going from the Y buffer going to the PDP all together it doesn't shut down at all. All the voltages are correct and im sure that its not the control board either. If anyone has any ideas let me know thank you.
    Photos provided below.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 42pj350
    Right more messing found that the VSC is pulsing up and down and that the buffer chips are getting very hot so guessing that the buffer is toast and that possibly Ysus so going to double check.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Re: Lg 42pj350
      Any one ?
      • sordids999
        • May 2013
        • 2161
        • uk
        Re: Lg 42pj350
        check the Z-SUS board high power copper inductor to see if there is any cracked solder joints
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Re: Lg 42pj350
          Ok will do cheers.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Re: Lg 42pj350
            Ok so fixed the set today, was due to cold solder joint on the Zsus on that coil, there was a huge ring crack around the leg of it, used my meter to see if it was connected to the pad at all and it wasn't at all. After re-soldering that by adding fresh solder removing the fresh solder with the de-soldering gun I then scratched around the pad to expose the copper and spun some solid copper wire around the leg of the coil then flooded it with solder to help reinforce the joint. Lg should have riveted that coil in the first place as it has a lot of current flowing through it. I also reinforced the joint on the same coil on the Ysus just to make sure its not going fail in the future. I have a feeling that the reason why the Y sustain Igbts and diodes failed was due to the Zsus coil breaking off which caused them to get overloaded and go short.
            Overall £30 in parts and now a decent tv charged £120 for repair and now a happy customer hopefully wont be failing any time soon. Cheap Lg junk built to fail now at least its working until something els fails. Thanks for the input really helped.
            • sordids999
              • May 2013
              • 2161
              • uk
              Re: Lg 42pj350
              glad it worked
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Re: Lg 42pj350
                Originally posted by sordids999
                glad it worked
                Honestly thank you mate, got another one to do same fault
                • legg
                  LG 42PC3 buffer output doesn't follow YSUS
                  by legg
                  LG42PC3D -UD originally with green lamp but no display or audio.
                  Owner says was working, then went 'pop'.
                  All 5V caps bulging. replaced.
                  All PSU output voltages within spec but -Vy is low on YSUS.
                  One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                  eventually shorts DG. Replaced all 3 - -Vy now OK.
                  Y scan buffer test point does not follow YSUS output below -50V
                  Note: This unit seems to expect YSUS output to park at -Vy in between
                  drive signal pattern periods. A replacement drive signal board confirms this....
                  11-18-2021, 11:49 AM
                • reessi
                  Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                  by reessi
                  Hello:
                  I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                  I started on the ACER:
                  Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                  All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                  I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                  10-29-2024, 11:31 AM
                • PlasMatt
                  LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
                  by PlasMatt
                  I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
                  09-20-2025, 06:50 PM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • Yanleb
                  Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                  by Yanleb
                  Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                  I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                  D608, good
                  D618 RF101L4S, good (See warning 1 below)
                  D619 RF101L4S, good (See warning 1 below)
                  D865 RF101L4S, shorted (See warning 1 below)
                  IC464 Inverter HA MC74HC1G14, shorted...
                  03-09-2020, 12:00 AM
