Toshiba 58L135UC Power issues
  • cperiuta
    • Nov 2015
    • 38
    • canada
    Re: Toshiba 58L135UC Power issues
    Perfect, I will. Do you know a better shop to buy it?
    Thank you verry much for your help here. You're the best.
    • cperiuta
      • Nov 2015
      • 38
      • canada
      D201 is not good. I'll try tomorow to find it. Thanks
        So now it is tested bad?
        • cperiuta
          • Nov 2015
          • 38
          • canada
          No, it is a problem with the forum. I wrote the same message once again.
          • cperiuta
            • Nov 2015
            • 38
            • canada
            One of my neigbors gave me this Tv. He tried to opened it first to check the fuse. I don't have the remote.
            When I saw the Tv, it had the front power button weakened. Is there a way to check if it works?
              You can check the contact resistance between the two terminals of the switch when it is pushed and released.
              • cperiuta
                • Nov 2015
                • 38
                • canada
                #27
                It works perfect. Do you think the power supply can generate this problem too?
                  At this point I do not know what is causing the POWON to be stuck HIGH like that.
                  The power supply gets the command signal from the main board to tell it to turn on the rest of the power supplies.
                  Since some one else had been inside the TV, I would check all the connectors and connectors pins to make sure they are seated properly, no bent pins, all the circuit board mounting screws are tight, etc. But for sure you do have power supply board problem. you need that to run first before going further and you may find out after getting the correct Voltages but find out there are problem with the main board too, it's a gamble.
                  • cperiuta
                    • Nov 2015
                    • 38
                    • canada
                    #29
                    In this situation I quit. The power supply is more expensive than I expectedand it might not solve the probleme.
                    Thank you very much for your help.
                    Happy New Year!!!
                    • anthonystv
                      • Jun 2014
                      • 73
                      Same issue same board
                      just found Q301 shorted
                      looks like K13A25D on the FET not sure though
                      removing this transistor relieved shorts all over the board
                      • tv_guy6969
                        • Sep 2015
                        • 3
                        • united states
                        #31
                        i have a toshiba 58L1350U how do you disassemble n take the back off
                        • neilc6
                          • Nov 2015
                          • 1550
                          Thanks anthonystv
                          Got this model in with report that it turned on without backlight. Couldn't figure out the wiring to probe from the LED connector so spent an hour taking panel off to find all backlights tested good.
                          Put back together and tv was dead with no standby light. Found this post and Q301 tests as short. Part is FDPF3N50NZ (N-CH, 500V, 3A, TO-220F). Replaced with equivalent (fuse was not blown) and tv powers up.
                          Model 58L1350UC. Think C suffix is for Canadian model. Power supply board PK101W02301
                          No special trick in taking off the back. Just make sure you get all the screws.
                          • fbedregal
                            • May 2015
                            • 5
                            I have same Tv same power board issue apparently but by following Neilc6 post #32 I did not resolve the issue. In fact MOSFET FDPF3N50NZ looks like it’s the wrong replacement dfir K13A25D or Q301. The original is shorten and once replace with FDPF3N50NZ also that got shorten. 3 questions I have at this point: 1. Replacing wrong MOSFET is causing that shorten isssue? 2. Should I start troubleshooting from DC primary everything else? 3. Originally I had same issues as per cperiuta described. Should I better buy a new power card or quit...tv was a gift from work since recently just stopped powering on.
                            • neilc6
                              • Nov 2015
                              • 1550
                              I've replaced shorted transistors and have them short again due to other shorted components. Check all diodes, rectifiers, and transistors.
                              • fbedregal
                                • May 2015
                                • 5
                                Thanks neilc6 for a super quick answer. Is MOFSET PDPF3N50NZ good replacement? Did you finally fix the TV?
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  That's the part number I found on my TV. K13A25D is NCH 13A 250V so specs are a bit different. What's the transistor marking on your board?
                                  • fbedregal
                                    • May 2015
                                    • 5
                                    Original MOSFET is K13A25D. I've replaced that with PDPF3N50NZ. Both are shorten. Is that PDPF3N50NZ transistor a good replacement? I know I have to check all diodes, Mosfet and rectifiers anyways.
                                    • neilc6
                                      • Nov 2015
                                      • 1550
                                      Maybe I read the part wrong or it was previously repaired with the wrong part but probably substituted with a higher rating I had in stock. I do have this board in my junk boards bin and Q901 reads as FQPF16N25C (16A, 250V, NCH) so looks like you should substitute with this one. Yes, the lower amp rating could blow the replacement.
                                      • fbedregal
                                        • May 2015
                                        • 5
                                        Q901? You mean Q301, right? I will check all again but I wonder if this is only a power card issue or something else..since you gave that board on your junk that means you need to get a new one to fix that TV?
                                        • neilc6
                                          • Nov 2015
                                          • 1550
                                          Ok found the confusion since there appears to be two different power supplies for model 58L1350U 58L1350UC according to shopjimmy
                                          Power supply PK101W0230I has a Q301
                                          Power supply PK101W0220I has a Q901 but no Q301
                                          Replace the transistor with whats on your board. Amps and volts are max ratings so you can sub higher. TO-220F is an insulated package so replace with the same.
                                          I currently have this model in with bad backlights that also blew the LED controller IC. Tried replacing the IC but it had terrible solderability and I ended up damaging a new strip and the replacement IC so gave up and bought a new board.
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • cheeky2
                                            Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                                            by cheeky2
                                            I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                                            Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                                            The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                                            Details:...
                                            08-17-2023, 04:34 AM
                                          • zlr8r
                                            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                                            by zlr8r
                                            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                                            Ill try and give as much info as I can.
                                            Dell Inspiron 17 (7786) Laptop
                                            Service Tag: 5J0NHT2
                                            Bios: 1.9.0
                                            When I received this , it would only flicker on the KB backlight for a second, then off and on.
                                            Then it started getting weirder!
                                            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                                            12-12-2023, 09:31 PM
