Panasonic p50g20 power board failure?
  • Tinkerless
    • Dec 2015
    • 6
    2 days ago my p50g20 failed and powered off, don't think any visible error blink codes were shown.
    This tv has always produced a buzz when displaying very bright images mostly noticeable at night time, the brighter the image the louder the buzz. This has been getting worse until the other night when during an almost full white screen there was some crackling/arcing noises and the set powered off by itself. Checked for smoke/smell and couldn't find anything switched back on to test and all seemed ok again until another white screen and more crackling/arcing and switched off again. Switched the unit off at the side power button and started to scratch my head when the arcing/crackling noises started again and I paniced and just pulled the power cord.
    I have opened up the back to have a look to see if anything obvious, there is a capacitor on the power board that is slightly bubbled but otherwise no other visible symptoms.
    So what next? Can I test the power board in isolation without any other connections? Is this safe? I'm comfortable replacing the power board with a like for like replacement but not confident soldering components. The unit has a lot of dust inside, could the also be a factor?
    Could there be other non visible damage to other boards?
    Before the failure the unit had no other problems, great picture and colours etc.
    Any advice greatly appreciated.
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Panasonic p50g20 power board failure?
    Pictures of the back of the tv showing all the boards
    May help you more
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      P-50G20, Thats the cut-down Cheapo Argos special, innit??
      Tighten ALL the board mounting-screws, especially those os SC and SS boards.
      Probable usual arc fault that kills the SC board etc--and You DONT want to go There!!
      TELEFIX
      • Tinkerless
        • Dec 2015
        • 6
        Here are some shots of the insides including a close up of the bulging capacitor (wasn't argos, was from currys I think) :
        https://www.dropbox.com/s/m78penb1bx...81303.jpg?dl=0
        https://www.dropbox.com/s/n6ru08lz3o...90147.jpg?dl=0
        https://www.dropbox.com/s/ghdylqj4bd...90213.jpg?dl=0
        https://www.dropbox.com/s/ijzlskde60...90226.jpg?dl=0
        https://www.dropbox.com/s/ubdcokekrw...90232.jpg?dl=0
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          Try to upload the pictures in advanced mode. ( Attachment option ).
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            As I said--Tighten ALL the screws on ALL the boards.
            Cut-Down sets are sold by the chains such as Argos. Thats why they are cheaper--Because they are MADE cheaper than the premium set.
            The premium model we'll say uses 4 transistors in parallel, Cut-down set will use say only 2 maybe 3--As little as they can get away with--All user apparent features are the same, so buyer has NO idea, only the Model Number indicates the difference.
            Thats why they are cheap. Buyer THINKS he's getting a deal--But he isn't as the reliability is compromised by the use of less parts (And CHEAP SCREWS!)
            This issue is particularly apparent with Panasonic sets....
            TELEFIX
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              maybe in a very dark room power the set up with the back removed you maybe able to see where its arcing etc !!but dont do this long at all as dont want a blown sc board etc!!
              • Tinkerless
                • Dec 2015
                • 6
                The set is a Panasonic Viera TX-P50G20B and I have had this for approx. 5 years. I'm happy to try tightening the screws but as the set hasn't moved in the last 4yrs I'd be surprised if loose screws would be the cause?
                I thought this was a mid range set not a budget argos tv.
                • Tinkerless
                  • Dec 2015
                  • 6
                  Would it be possible to test the power board without anything else connected to it? Remove all the other connectors and ribbons?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    the screws have been re designed with a extra washer etc as this is a known fault now you can get updated screw kits etc.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      i would guess so but im not sure which pins on the psu you would have to link with resistors etc maybe a more experienced member will advise whats the power supply board number?.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        The cheapo screws work loose By Themselves!
                        The arcing to chassis is what destroys the SC. Do Not run it agan till you've tightened 'em, or you risk blowing the SC etc--And That'll cost lots!
                        TELEFIX
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          as alastair e suggested a few posts back defently tighten those screws up first it may not solve the problem but may stop other boards from shorting out and if possible upload some pictures of the power supply and the bad capacitor you can see your self.
                          • tw2005
                            • Oct 2011
                            • 6458
                            This model does not suffer from loose screws AFAIK. has the good old bolts before they stuffed up in 2011.
                            So is this TV working or not now?
                            • tw2005
                              • Oct 2011
                              • 6458
                              Just had a look at the SS image, I would blow out and clean all that dusty crud off all the boards especially the SC,SS,P .
                              That in itself could be arcing, I have worked on a 2009 G10 and literally had a board arcing across from a heatsink to a nearby component all due to build up, scared the crap out of me at the time.
                              • Tinkerless
                                • Dec 2015
                                • 6
                                No haven't tried putting power back into it again. Just tried to upload picture of the bulging capacitor, it's the 230v one in the background :
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  If you remove sc2,ss11,p35, 3 white ribbons at the A board it should power up normally but do no more than 30secs or it will fail and shutdown with a 4 blink code with no load.
                                  Don't reconnect those until the voltages have dropped off those leads especially P35 or you can damage the panel
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    tw2005 so basically the loose screw arcing issue is sets made after 2011? does this apply to all the panasonic range of plasmas, because ive saw you mention the loose screws in various threads i didnt realise it was after a certain year so good imformation to know.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      It's quite common for those large HV caps to have a natural dome to them and bad caps are fairly rare in these. Most issues are SC or A board in these.
                                      I reckon pop the sc , ss ,, p out, inspect and clean, even a soft brush. I've seen roaches get trapped under boards and burn to a crisp in a LG, blew a buffer in that. I'm assuming this is working but the SC can buzz and if loose as the other guys mention can make a very loud noise but it's more of a buzz, not crackling noise when I've heard it leaving screws out.
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        From everything I've read and seen here 2011 on , not sure after 2012 only seen 2011 and 12 models.
                                        I own one of the P50V20A , still a good TV
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • canadaboy25
                                          Panasonic TC-P54VT25 No image. A or D board?
                                          by canadaboy25
                                          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                          01-17-2021, 01:06 AM
