Panasonic p50g20 power board failure?
Re: Panasonic p50g20 power board failure?
I would class this as mid range. The V20 would be the top for FHD.(VT 3D)The set is a Panasonic Viera TX-P50G20B and I have had this for approx. 5 years. I'm happy to try tightening the screws but as the set hasn't moved in the last 4yrs I'd be surprised if loose screws would be the cause?
I thought this was a mid range set not a budget argos tv.
It's the S series that's budget, noticeably cut down in the A board and SC boards using fewer components, and the buffers have no heat sinks
Both suffer similar failures of the SC and the A boards seem to have more issues with the BGA solders.Last edited by tw2005; 12-13-2015, 05:18 PM.Comment
Another thought.
Have a good look at the cabling and connections too at SC2 and SS11 (Vsus supplies) . On that same G10 with arcing i also found extreme bluing and corrosion on the Sc2 pins , the lead and on the board under the white connector it had been arcing so bad it burnt deep into the board.
this was a TV that was fairly close to the coast so it may have been outside, salty air and dust build up?Comment
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by canadaboy25I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was... - Loading...
