Lg m228wa
  • 820uF
    • Apr 2012
    • 39
    • Russia
    Lg m228wa
    Changed caps but, fuse is fine but still doesn not take power in.
    Even the power led doesn't light up.
    Transformer?
    Re: Lg m228wa
    Can you please provide good clear pictures of the board and how they are all connected together so we can see what we are dealing with.
    What have you tested so far?
    I would assumed you have already tested the Main AC fuse, rectifiers, DCV between the two legs of the main filter cap in the primary side, etc.
    • victor_cj
      • May 2015
      • 90
      • Romania
      Re: Lg m228wa
      You measured the voltage 15V, 5V at CW201 ? Check R108, D202, D201, U303, U304.
      The art of fighting without fighting
      • 820uF
        • Apr 2012
        • 39
        • Russia
        Re: Lg m228wa
        No power on CW201 at all.
        http://imgur.com/HmxfB4s.jpg
        Under D102 looks pretty burned.
        Is there any scematics for this board around?
        • victor_cj
          • May 2015
          • 90
          • Romania
          Re: Lg m228wa
          Check for cracked soldering, replace all caps C106, C105, C201, C202, C203, C204. Check ZD103, D102, D101. Replace in the last case U101, Q101.
          • 820uF
            • Apr 2012
            • 39
            • Russia
            Re: Lg m228wa
            D102, D101 ok but R108 - From color code orange;orange;silver;gold it's Resistance Value:
            0.33 ohms, +/-5%, but multimeter shows 0.7ohms. could that be the problem?
              Re: Lg m228wa
              No, that is not the problem, you are reading the meter probes resistance + the value of the resistor.
              • victor_cj
                • May 2015
                • 90
                • Romania
                Re: Lg m228wa
                Put the multimeter probes in short to see their resistance value. Anyway check again.
                • 820uF
                  • Apr 2012
                  • 39
                  • Russia
                  Re: Lg m228wa
                  Thak you all for help.
                  U101 was bad.
                  • corrize
                    A funny fuse story – Lumix LX100 II
                    by corrize
                    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                    10-19-2023, 09:58 AM
                  • jesterace
                    Samsung UE46ES8000 Blown fuse but no other signs of short
                    by jesterace
                    Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                    09-11-2024, 03:14 PM
                  • jshhh
                    Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                    by jshhh
                    Hi guys,
                    I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                    How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                    Anybody know how to remove this type of fuse?
                    (The fuse is toward the bottom of the image labeled F2)...
                    06-17-2025, 01:35 AM
                  • Babbar
                    by Babbar
                    04-12-2024, 01:12 AM
                  • redbaron1007
                    Liquid damaged macbook A1466 fan spins, but doesn't turn on.
                    by redbaron1007
                    I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
                    10-24-2024, 05:45 PM
