Vizio m3d550kde no jingle but vertical lines on screen
  • Wingryder
    • Oct 2015
    • 83
    Please take a look at the pictures and tell me what you think. No audio at all.
    Set does not ever show the amber standby vizio but that could just be burnt out. Power on and the white vizio comes up.. no start up jingle.. screen comes up with vertical lines, white vizio goes out after about 10 sec. Screen stays on but times out after a few minutes. Sometimes the white vizio flashes on and off... and times out. But next power push and the screen lights up as below.
    I was pretty sure this was T-con but now not sure. One site that sells the tcon says none of their boards cure vertical lines. All voltages on the ps look good. There is only 24, 12, and 5. Nothing like the Plasmas I have been working on.
    I tried unplugging main board but would not power up at all. Tried some freeze spray.. no go. Also flexed the screen looking for bond issues.. no change what so ever. One more thing.. I noticed the ribbon cable on the right side of tcon board does not insert as deeply as the left side.. Reseated both with blue line still showing on right.
    So do I have a bad panel or??? Set is 55 inch and about three years old.
    Re: Vizio m3d550kde no jingle but vertical lines on screen
    What do you get on the screen if you have one ribbon cable between the T-CON and the LCD panel connected one at a time?
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      10-1, LCD Panel stuffed.
      TELEFIX
      • Wingryder
        • Oct 2015
        • 83
        Thanks to you both for responding. Budm.. With one of the data lines unplugged I get a white screen on that side. It moves to the other side when I switch cables. A side question.. why does any of this kill the audio ??
        • Wingryder
          • Oct 2015
          • 83
          Maybe change the LED Driver Board? They are cheap
            LED driver is for the backlights, you have image on the screen because the backlights are working, lines on the screen has nothing to do with backlights.
            I would say you have bad panel, you can try new T-CON board if it is cheap enough.
            • Wingryder
              • Oct 2015
              • 83
              Thanks budm
              Can't win all the time. I am learning.. so that's worth something.
              • Wingryder
                • Oct 2015
                • 83
                It is an "LED" but I guess still stuffed.
                  It is 'LED' backlights, the screen is LCD. It is not LED TV, false advertising.
                  • Wingryder
                    • Oct 2015
                    • 83
                    I knew better than question a professional... but I did it anyway. Confusion
                    is a foot thick here. I did order a Tcon as last ditch effort. Can I replace the LCD panel for anything reasonable... And if so where? Shop Jimmy almost laughed at me.
                    They indicated a panel would be 80% of new TV.
                    budm I do appreciate your help.
                    • truep
                      • Aug 2010
                      • 373
                      Do the lines move around? Does it change when the menu is displayed? If so you may have a bad main board. Usually a regulator on a Vizio. That would explain no audio. Had a Sony with lines like that that moved around and a Main board fixed it.
                      • Wingryder
                        • Oct 2015
                        • 83
                        No they do not move around or change at all. Only change I could make is unplug half of the tcon board output as suggested above.
                        No sign of abuse or cracked screen either.. bummer
                        • Wingryder
                          • Oct 2015
                          • 83
                          Waiting now for tcon board and still fretting about no audio. No startup jingle or any sound at all. Could I have two separate problems? Can I power it up with the input to the t-con unplugged without doing damage?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Nope won't hurt anything.
                            • Wingryder
                              • Oct 2015
                              • 83
                              Thanks. Did that. no change with jingle or audio.. Screen backlights on.
                              Unless I have two problems, you would think audio would be normal.
                              Found the panel for 625.00 plus shipping. Right. Would not think they would sell many.
                              • Wingryder
                                • Oct 2015
                                • 83
                                While I am waiting on the tcon board can someone explain the logo light to me. Three wires going to it from main board. There are 5 volts on pin 3 all the time set is plugged in. Does the main board pull either pin 1 or 2 to ground depending on light needed.. amber or white? (I could have the pins numbered backwards)
                                • Wingryder
                                  • Oct 2015
                                  • 83
                                  Replace t-con board. No change. I think the main board has problems too... but with bad screen I have come to the end of this one. I would think that with tcon and led driver board unplugged.. should have startup jingle, and audio.
                                  Since I do not... maybe the Eprom got scrambled from p.o. trying to get the screen to come up correctly. It is for sure higher than my pay grade.
                                  Recycle it goes.
                                  Thanks for all the help.
                                  wingryder
                                  • Stanley1843
                                    by Stanley1843
                                    06-29-2024, 11:54 AM
                                  • brad2157
                                    Vizio E70-E3 Two white vertical lines
                                    by brad2157
                                    I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                    Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                    Replacement main board - Boots up fine, but starting...
                                    12-13-2021, 05:11 PM
                                  • viking509
                                    vizio e65 e3 LED tv color vertical lines center tv only
                                    by viking509
                                    I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                    03-21-2023, 12:48 AM
                                  • howardc64
                                    Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                    by howardc64
                                    Failure Symptom
                                    No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                    Where is the short?
                                    Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                    Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                    05-27-2025, 02:56 PM
                                  • visionbluedemon
                                    Help. Sony kd-65x85dj vertical lines
                                    by visionbluedemon
                                    First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                                    Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                                    tried blocking LC lines too, but same results
                                    is it lcd panel issue or tcon board issue?...
                                    07-25-2025, 04:56 AM
