LG 50PA5500-UA Black Screen, sound on
  • S77
    • Nov 2015
    • 10
    Hi everybody,
    have 50PA5500-UA plasma tv with black screen now.
    Started from screen blinking, some times was black screen, some times was ok.
    Then it stopped turning on. Standby light, press ON button, CLICK tried to turn on, another CLICK right away - turn itself off, standby on.
    Unpluged Z-SUS with Y-SUS (power cable goes from PS board to Z-SUS then from Z to Y-SUS), tv turned on.
    Z-SUS pluged in, Y unpluged - tv turned on.
    So does it means Y-SUS or Y-buffers are bad?
    Checked top Y-buffer connections, all clear.
    Should i replace all 3 Y boards or i can check smth before?
    Please help
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PA5500-UA Black Screen, sound on
    Remove the upper y buffer board off the equation and then power it up. Do you have a grey raster on the bottom half of the screen?
    • S77
      • Nov 2015
      • 10
      No, just blank screen (after remove upper y-buffer)
      Funny thing, that after i connect everything back and Y-SUS to power supply, no tv still starts ok, and sound works
      • freakaftr8
        • Oct 2012
        • 3743
        With ysus and zsus disconnected can you verify vs voltage from the power supply
        • S77
          • Nov 2015
          • 10
          so i have black screen with or without Y buffer boards, tv starts but no picture
          • freakaftr8
            • Oct 2012
            • 3743
            That's correct. You will not have a screen at all with the Y buffers disconnected. However you need to verify if you're still receiving vs voltage from the power supply with or without the buffers connected to the ysus board. Without monitoring output voltages from the power supply you have no way of telling if your power supply is going into protection mode with the buffers installed therefore you can't physically tell if your buffers ar shorted unless you doing ohm test
            • S77
              • Nov 2015
              • 10
              So i have to check voltages on ps board or ysus board? This ysus board getting voltages from zsus board. It doesnt have any power cable from ps board to ysus directly
              Please advise what exactly should i check with meter?
              • sordids999
                • May 2013
                • 2155
                set you meter on dc 600 volts (red lead on test point black to chassis of the tv )then use the VS/VA test points on your power supply to see if they match up with your panel which should have a sticker attached giving voltages VS/VA/VSC/VE etc
                try this with YSUS/ZSUS unplugged first
                • S77
                  • Nov 2015
                  • 10
                  Just tested vs and va without ysus and zsus boards. Read correct numbers as on board table: vs 203, va 54
                  • S77
                    • Nov 2015
                    • 10
                    Guys, what should i check now? Meter vs, va with zsus or ysus connected?
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • Rozp
                      70LE660U dark cloud or black screen with sound.
                      by Rozp
                      Hello Everyone,
                      This is my first post so I will try to be as precise as possible without making this post too long winded. Unfortunately I don't have pictures of the original problem but I included images of the TV internals.
                      I have a Sharp 70LE660U. The problem started a few months ago with the bottom row looking out of sync and was dark on the left side and then fading to transparent on the right side. Shortly after, a dark cloud appeared in the center of the screen. The dark cloud started small and shaded but the image was visible. It also affected the menu area....
                      08-29-2023, 05:25 PM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • ChaosLegionnaire
                      by ChaosLegionnaire
                      09-13-2022, 09:02 AM
                    • Audeze
                      Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                      by Audeze
                      I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                      Does...
                      10-06-2024, 08:54 PM
