Vizio VP50 HDTV20A
  • goggins.jim@gmail.com
    • Nov 2015
    • 21
    Vizio VP50 HDTV20A
    Hi everyone.. need some assistance with a Vizio which I believe is really a Samsung.. the screen appears fuzzy.. I can still see the menu however it seems to be lacking some color. Sound is fine. I've taken the back off the set and there does not appear to be any loose cables.
    Caps appear to be fine looking them over.. the lower portion of the screen seems to have fuzzy black lines running through it. I'll attach a picture.. tonight I intend to check all the fuses based on what I've read on the forum..
    Last edited by goggins.jim@gmail.com; 11-09-2015, 01:08 PM. Reason: added additional image
    • Nov 2015
    • 21
    Re: Vizio VP50 HDTV20A
    Update: Tested all fuses and all are fine. Picture still there but weak and fuzzy with black lines streaking somewhat across the bottom of the screen. The picture with No Signal shows the lines..
    • freakaftr8
      • Oct 2012
      • 3743
      Sounds like a lower ysus buffer fault
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Possibly lower Y buffer failure. Do you have a Dmm ?
          • Nov 2015
          • 21
          sounds like two possible items I can look into.. any tests I can conduct? I do have a Digital Multi Meter.. ready for next steps. Do I need to download the service manual or can you provide direction? Sure do appreciate everyones help.. I added another image.. note at toward the bottom of the screen the horizontal black streaks..
          Last edited by goggins.jim@gmail.com; 11-10-2015, 08:52 PM. Reason: adding another image
            • Nov 2015
            • 21
            I have a Digital Multi Meter.. are there tests I can perform to prove I have a Y Buffer failure?
              • Nov 2015
              • 21
              O.K. I done some additional reading.. I'm going to connect a dvd player to the TV and capture a couple more pictures. Hopefully by capturing some actual TV images we can determine if I should be looking at a Y-buffer or sustain card. However if I'm reading and understanding correctly the Y-Buffer card failure can damage the Y sustain card.. am I going down the right path?
              • freakaftr8
                • Oct 2012
                • 3743
                Ok looking over your pictures again it may not be a buffer board however you may have a problem in your y Or z sustain. What are your voltage is coming off the power supply?. About vs voltage.
                  • Nov 2015
                  • 21
                  Hello Freakaftr8.. I see you're online now. I can check voltages tonight is there a certain test point I should be looking at? I'm assuming these are all DC voltages
                    • Nov 2015
                    • 21
                    There appear to be multiple places to check the VS voltage if I'm reading this correctly I'm seeing 200 Volts DC. Vg appears to be approx. 15 Volts
                    • freakaftr8
                      • Oct 2012
                      • 3743
                      Those voltages sound about right. This looks like possibly a zsus issue. Can you post a picture of what the picture looks like when it's a full white screen? Also does the picture appear to be dim and washed out?
                        • Nov 2015
                        • 21
                        Hello again... just got back from my daughters house where the TV is.. I attached a DVD player to her TV and captured a couple pictures. It seems like the color red is missing and I would agree the picture is somewhat washed out. I'll go back tomorrow and capture a couple more with full white. While there I did remove the Y buffer and X main boards and I could not find any sign of excessive heat or burnt parts. Both boards have been reinstalled and screen appears the same..
                        • tw2005
                          • Oct 2011
                          • 6458
                          I'm going with Freak, i would look at ZSUS / XMAIN. Have you worked out whether this is Samsung or LG based? LG has those horrible IPMs. If samsung it'll be easier and cheaper if it's Z / X board.
                          If Samsung, check all the fuses including the small green pico fuses, samsung board picture below
                          • tw2005
                            • Oct 2011
                            • 6458
                            those black splotchy streaks are typical Xmain / zsus failure.
                              • Nov 2015
                              • 21
                              Update: I have attached the white picture and also while there check the fuses.. the fuse in the attached picture shows 15V DC on one side of the fuse and approx 5V DC on the opposite side.. all other fuses have the same voltage on both sides.. could this fuse be bad and I'm picking up 5V DV from other components on one side of the fuse?
                              Ready for next steps... thanks again everyone for providing directions
                              BF= Blown Fuse
                              WS = White Screen
                              Sansung = Label
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                take the fuse out and test the fuse what does it read on resistance mode? if your unsure of what a good fuse should read take one of the other fuses out and test it, my guess yes it bad but if it is more fault finding will be needed to see why it has blown.
                                  • Nov 2015
                                  • 21
                                  I can certainly do that.. its the small pico fuse and I believe it's soldered in. I'll remove the board tomorrow and unsolder one end. I've looked at the cost of the xmain zsus board and it seems the price has a considerable range. I've seen from 18.00 to approx 80.00. When this board is replaced does it require any voltages to be set?
                                    • Nov 2015
                                    • 21
                                    Here's the White Screen image
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      sorry i didnt realise it was the small green one i didnt look at the picture to be fair just read your post yes just unsolder one side and test but a resistance reading in circuit should tell either way.
                                        • Nov 2015
                                        • 21
                                        Got pulled out of town on business this week.. will resume troubleshooting next Tuesday.. I certainly haven't given up.. just a slight delay.
                                        • SS454
                                          vizio e650i-a2 backlight flashes then turns off
                                          by SS454
                                          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                          panel: au optronics T650HVN05.4
                                          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                          https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                          08-20-2020, 03:57 PM
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          07-14-2025, 07:28 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • howardc64
                                          Vizio SmartCast TV software bug that looks like hardware
                                          by howardc64
                                          Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                          It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                          11-16-2024, 05:17 PM
