Vizio vp50hdtv10a problems
+ More Options
Posts
  • kolls1
    • Oct 2015
    • 12
    • usa
    Ok, checked and replaced all caps. this thing is giving me fits here is my readings
    P800:Orange 5Vsb 5.00V
    CN805: Bottom pins0.00V
    CN807 0.0V, 0.0V, 0.0V
    CN802: 0V
    CN803: 0V
    CN809: 0V
    I made a video instead of pics...help please
    http://youtu.be/1p1ifT_cD50
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Vizio vp50hdtv10a problems
    Probably failed Epprom as you get no Pson signal.
    • kolls1
      • Oct 2015
      • 12
      • usa
      so how do i test for this
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Is the pcb connectors labeled with voltages ?
        • kolls1
          • Oct 2015
          • 12
          • usa
          Yes they are
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            https://www.badcaps.net/forum/showth...io+vp50hdtv10a
            these links are too toms manuals you maybe able to use for fault finding the link in post 4 in above link does not work so use the top one in this list as tom says lg panels are the same in that thread.
            http://www.toms-service-manuals.com/...h=Submit+Query
            • kolls1
              • Oct 2015
              • 12
              • usa
              Ok that didn't help, just trying to fix this damn thing before I throw it out the door
              • kolls1
                • Oct 2015
                • 12
                • usa
                Ok with some doing more looking and testing, I found something interesting if I take and jumper AC detect to RL-ON board powers up and doesn't shut down with c800 disconnected. No vs or va voltage . Any suggestions
                • kolls1
                  • Oct 2015
                  • 12
                  • usa
                  Anybody help me
                  • tw2005
                    • Oct 2011
                    • 6458
                    I'll take a stab and it could be in protection if either the ysus or Zsus boards have failed. the logic control board controls the power up sequence, also detects if there's a problem with the z or y boards I believe or it could itself be dead but IPM failure is a fairly common fault.
                    Don't have enough LG knowledge to say more.
                    Maybe describe what it is doing from when it's plugged in to when you attempt to wake it out of standby. I know on an old 2006/7 50PX5 it would attempt to switch on , led would go green then shut off straight bad to red led on a shorted sus board.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • howardc64
                      Vizio M557-G0 1/2 panel VGHD LC1 (and maybe XON VSSQ LC2) Problems
                      by howardc64
                      Failure Symptom
                      No Display. Just random blocks of grouped vertical red lines.
                      Disconnect right 1/2 panel (rear view), left 1/2 displays properly
                      Masking T-Con Signal Diagnostic
                      Reduced masking to 5 signals on right 1/2 panel and get perfect picture
                      Pins are
                      1 GND
                      2 VGHD
                      3 XON
                      4 VSSQ
                      5 LC2
                      6 LC1
                      VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
                      Pictures and Schematic
                      XON, LC2, LC1 are on AUO s302-21 32pin QFN...
                      10-14-2024, 01:30 PM
                    • SS454
                      vizio e650i-a2 backlight flashes then turns off
                      by SS454
                      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                      panel: au optronics T650HVN05.4
                      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                      https://www.shopjimmy.com/vizio-56-0...-power-supply/
                      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                      08-20-2020, 03:57 PM
                    • mrtek
                      Vizio M65-C1
                      by mrtek
                      Hi.
                      picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                      When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                      This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                      Yesterday, 07:28 PM
                    • jean luc ferre
                      laptop hp g72 b52sf screen problems
                      by jean luc ferre
                      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                      i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                      06-07-2025, 03:27 PM
