oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
    Re: oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
    I see QB101 (mounted on the black heatsink) on shopjimmy board but I do not see that on your board, I see QB102 on your board.
    I also cannot see any SMPS IC on the primary side of the board.
    Is the shopjimmy board the same as your board?
    • shelby5041
      • Feb 2009
      • 1505
      • united states of america usa
      hi im sorry im very novice i dont know how to test the componenets you are referring to...are there any components i could start swapping??....most common ones that would cause no standby voltage from one board to the other?
      • shelby5041
        • Feb 2009
        • 1505
        yes same exact part# a13082145
        • shelby5041
          • Feb 2009
          • 1505
          mine has qb101 also under black heat sink
          • shelby5041
            • Feb 2009
            • 1505
            bud m the shop jimmy image u found is 100% exact as my board i just verified....not sure what u are referring to
              The label on the bottom side of the board is show as QB102 but labeled as QB101 on the top side of the board. Are there two devices mounted on that black heatsink?
              • shelby5041
                • Feb 2009
                • 1505
                #27
                my board has one device mounted under black heat sink
                  Well, looking at the board right now I cannot see what is driving that POWER MOSFET's GATE pin (the device mounted on the heatsink) which drives the power transformer.
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #29
                    both of the boards i have say qb101 on top and qb102 on bottom
                    only one device under heat sink
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #30
                      i get like 160v on that device by mistake i was touching it and prob shouldnt have.....i touched middle leg and then touched other leg and got 160v or so
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        bud on the fried board i get like 36v and 12v output on the caps in middle but on the replacement board i only get 2v and 8v output from same caps
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #32
                          update
                          got replacement board today.....i installed it and i now get a standby light but tv will not power on......the original issue was a fried hdmi port and tv was completely dead no standby at all.........
                          any ideas?
                          could the replacement board be bad?...this tv only has one board that does it all
                          its power supply and main and input and led driver board all in one so its 100% responsible for powering on the tv
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Tried unplugging Lvds and Leds to rule them out dragging Psu down ?
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #34
                              i diid disconnrt led ...no diff
                              ill try lvds
                              could the powet button board be bad?.....or unlikrly?.....is therr a way i csn force on msnuslly by jumpering pwr on?...to rule out pwr button board if so how
                              • shelby5041
                                • Feb 2009
                                • 1505
                                #35
                                some tvs wont power on with certain cables unplugged right?
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #36
                                  one more thing....i only have board mounted with 2 screws...missing 4 screws...this wouldnt cause anything would it?...ground or funky thing?
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Don't think so. If you have one screw in a ground lug you should be ok.
                                    • freakaftr8
                                      • Oct 2012
                                      • 3743
                                      Guess you should research out CN9 and find out where ps on pin is and check voltage there. Make sure your keypad is giving the power supply the on command
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #39
                                        ok thanks...
                                        • shelby5041
                                          • Feb 2009
                                          • 1505
                                          #40
                                          hi i toook the board to work and broguh the power cord and power button assembly and ir board for the hell of it i hooked it up and tried to use the remote to power on and now i get the blue power light to come on...but this is outside of the tv....and prior to this i unhooked the lcd and led backlight when it was in the tv and used the power button on tv and still didnt work but now it works out of tv using remote
                                          i havent tried remote at home....its very possible the power button board is bad???
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
                                          • jasonbay13
                                            Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                            by jasonbay13
                                            picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                            am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                            12-01-2023, 09:55 PM
                                          • Nicktronic
                                            Samsung UN70NU6070F Standby Light flashes twice
                                            by Nicktronic
                                            Hey Everyone,
                                            So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                            I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                            03-27-2023, 07:01 PM
                                            HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                            This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 05:27 AM
