oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    ...completely dead..no standby light..no clicks nothing
    ..originally the hdmi port fried..u can see burn marks and old main board is fried in that area..
    .replaced with another main board and now tv is 100% dead.....
    Re: oCosmo Model CE4001-HM06P7A,....completely dead..no standby light....
    Pictures of the whole back side of the TV so we can see all the boards, then good clear pictures of the whole board for each board.
    • shelby5041
      • Feb 2009
      • 1504
      with the ps out of tv and plugged in i get no 5v standby
      should i be able to test board out of tv?
      im just touching red to 5v pin and black to a metal component on the board
      • shelby5041
        • Feb 2009
        • 1504
        update....
        when i test for 5v on the main board with fried hdmi i get 5v
        when i test for 5v on the replacmenet board i get 0v on the 5v pin
        • shelby5041
          • Feb 2009
          • 1504
          was hoping maybe i could use a part from the board that i get 5v and install on the board with no 5v
          can anyone tell me if there is a component i could look at for being defective on the board with no 5v
            We are working blind without the pictures.
            • shelby5041
              • Feb 2009
              • 1504
              i posted photos
              • shelby5041
                • Feb 2009
                • 1504
                look up top......
                • shelby5041
                  • Feb 2009
                  • 1504
                  can u point out the voltage regulator from primary to secondary on the board so i can test it...
                  • shelby5041
                    • Feb 2009
                    • 1504
                    hey budm i posted a another thread for the cosmo tv issue by itself if u go see that it will help
                    thanks
                    • shelby5041
                      • Feb 2009
                      • 1504
                      hey bud m this tv only has one board
                      the ps main inputs and led driver all on same board
                      cheap ass tv
                      was wondering if someone could guide me to find what part is bad on the replacement board i got that has no standby v at all and does have 170v coming from 2 large main caps...the 4 caps in middle of board are also way way low in v....
                      thanks
                        Is this the board you got fro shopjimmy?
                        http://www.shopjimmy.com/ocosmo-a130...1-hm06p7a.htm#
                        I need good clear pictures of the bottom side of the board, the pictures from shojimmy has black insulator blocking the traces to see what drives the power transformer.
                        pictures provided by shopjimmy.
                        • shelby5041
                          • Feb 2009
                          • 1504
                          here are some pics
                          board # a13082145
                          • shelby5041
                            • Feb 2009
                            • 1504
                            s
                            • shelby5041
                              • Feb 2009
                              • 1504
                              z
                              • shelby5041
                                • Feb 2009
                                • 1504
                                i have an old crappy phone trying to take some better photos and the lighting here is causing reflections
                                  master hoarder
                                  • May 2008
                                  • 12168
                                  • Bulgaria
                                  Will need better pictures than this. I can't read anything on the board, so I can't tell you what voltages to check.
                                  The board appears to be a single-supply board (i.e. standby and main supply are one and the same). First thing I would suggest you do on the replacement board is change the caps. I can't see what brand they are, but they don't look like they are one of the good brands. Next, check voltage output on those axial diodes to the left of the transformer as well as the TO-263 component (likely a diode) right above them. Report what voltages you get.
                                  I also see several buck-type DC-DC regulators (the inductors in the lower left and upper right corners of the board) as well as more than a dozen linear regulators in SOT-223 package. Again, you need to check input and output voltages on those. Google their part numbers to see what they should be outputting (if they are fixed regulators, that is). Post your findings here.
                                  *edit*
                                  Never mind what I said about the pictures .
                                  • shelby5041
                                    • Feb 2009
                                    • 1504
                                    c
                                    • shelby5041
                                      • Feb 2009
                                      • 1504
                                      thanks..i tested the caps using esr meter and they test good out of circuit
                                      i do have another board like this that i get good voltages but it has a fried hdmi so it wont power up...i was hoping i could find the bad part and swap it out
                                      • shelby5041
                                        • Feb 2009
                                        • 1504
                                        yes bud m that is the board i have
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
                                        • jasonbay13
                                          Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                                          by jasonbay13
                                          picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                                          am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                                          12-01-2023, 09:55 PM
                                        • Nicktronic
                                          Samsung UN70NU6070F Standby Light flashes twice
                                          by Nicktronic
                                          Hey Everyone,
                                          So I've got this Samsung and the reported issue is that when powered on the backlight comes on, but no picture, no sound, it will flicker, the standby light will flash red twice and repeat the whole process...each loop lasts about 15 seconds.
                                          I've googled the issue and understand it is likely a panel/driver board issue, but was hoping the "tape method" could be successful. Before I did that though, I disconnected the left LVDS cable and powered the TV on. This time I got sound, no picture and the two blink standby light stopped. Did the same...
                                          03-27-2023, 07:01 PM
                                          HP EliteBook 840 G2 Base Model Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G2 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G2 Base Model boardview and 840 G2 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 05:27 AM
