Hello badcappers, if anyone has the data sheet for the 0B3302CP I need it so that I can turn off the feedback protection to stop it turning the backlight off, the protection goes high due to a failed lamp and I dont want to have to replace it. Cheers.
0B3302CP Ic Datasheet ?
https://www.facebook.com/Telford-Tel...7894576335359/Tags: None -
Re: 0B3302CP Ic Datasheet ?
It's extremely rare for chip numbers to start with a digit. Generally the format is letters, usually two or three, then numbers, followed by a suffix (sometimes hyphenated)
So check the part number is correct...Last edited by tom66; 10-29-2015, 11:07 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
Is it OB3302CP, not 0(zero)B3302CP?
http://www.datasheet-pdf.info/entry/OB3302CPNever stop learning
Double post ignore.Last edited by ReeceyBurger123; 10-29-2015, 12:24 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Whoops, should have used a MS ! Thanks anyway chaps I found the protection pin and removed a small ceramic cap to turn it off, I made a small diagram which is what helped me. Going to do a youtube video as the tv this is for is very problematic.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Thanks everyone for the inputPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Hi which pin is the protection? Feedback pin?Comment
Pin 2 CMP/SST.
You will do that for testing PURPOSE ONLY!Never stop learning
Yes be very careful as fire is possible if left alone like this. Depends on the set... Some can be okay. But not worth the risk.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ive done a few like this no houses burnt down yetPlease Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
I hope you don't sell them... the only ones like this I've done I've given to friends and told them to let me know if anything goes bad. One blew a transformer after a few months, the other is still good.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
You would want to short the cap as the test, this is the timeout capacitor, so shorting it makes it seem as if it has infinite capacitance.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
Here's what happens:
1) Power on
2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
3) Blue status light flashes for appx 4 minutes... -
by AJ847.63eHi All.
Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights... -
by mikey5791Hi,
This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...-
by khelaneHello
I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
Is there a way... -
by SoulFreezeHi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq.... - Loading...
