Bush BLED42FHDAE No standby light
  • matyka
    • Jan 2015
    • 179
    • Uk
    I aquired this TV today.
    No stand by red led , all PSU voltages fine.
    Could you help me what pin to short to force back light on ?
    At this point i'm stuck, was wondering if the eeprom on the AV board is screwed. does any one have a copy of the eeprom for this TV. Any pointers on fault finding on the AV PCB, Any known faults for this model ?
    Any other sugestions welcome.
    PCB numbers as follows
    PSU BL-0p415601-001 REV.1.2
    Main A/V T.MSD306.69A.11345
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bush BLED42FHDAE No standby light
    Possibly a shorted voltage regulator on the mainboard, do you know how to check them ?
    • matyka
      • Jan 2015
      • 179
      • Uk
      Hi,I have checked the voltage regulators on the mainboard and no shorted found.
      I have all the voltages read ok from the psu connectors CON2 ,CON3, CON4
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Normally they wont show up as shorted but just wont output the correct voltage.
        • matyka
          • Jan 2015
          • 179
          • Uk
          If I have the right output voltages from all 3 connectors it that mean the voltage regulator is fine ? and output the correct voltages ?
            "No stand by red led , all PSU voltages fine" So do you mean the signal pins also have all the correct Voltages?
            What DCV do you get at the signal pins?
            • matyka
              • Jan 2015
              • 179
              • Uk
              Con2 I have at pin3 and 4 --23.98v
              Con3 I read at pin5,6,7 and 8 -- 23.96v
              Con 4 at pin1and2 :12v. Pin6,7,10 and 11 --5v. Pin8 stby 4.98v. Pin9 on/off 2.89v
              All this voltages read when tv plug in to the main
              No light coming up and no standby red lihgt you could see.
                Well at least the main board is sending the ON/OFF signal, but I do not know what the root cause of the problem is on your main board. Look at the LED driver board to see if the main board is sending the BL-ON to the LED driver board.
                • matyka
                  • Jan 2015
                  • 179
                  • Uk
                  Hello,I have plug in the tv and measured from the main board (T.MSD306.69A 11345) to the led driver and I don't have BL-ON printed on board just BK-ON and I have no current going through.
                  ADJ has 1.323V
                  All 24v present on the led driver coming from PSU
                  24v present on the main board coming from the PSU
                  • matyka
                    • Jan 2015
                    • 179
                    • Uk
                    Hi,just to let know after changing the main board T.MSD306.69A 11345 the tv now is working properly .
                    Thanks for all the help .
                    • ChristianBr01
                      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                      by ChristianBr01
                      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                      04-23-2025, 01:48 AM
                    • brithepi2k
                      Sony KD-65XE8596 no standby light
                      by brithepi2k
                      I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                      cheers...
                      09-06-2025, 02:22 PM
                    • AleMonti
                      LG 55EG910V - no power and no standby light
                      by AleMonti
                      I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                      I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                      The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                      After checking the basics I did the following:
                      • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                      11-04-2024, 05:02 PM
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                    • jasonbay13
                      Philips 37HFL5682L/F7 no standby light, incomplete service manual?
                      by jasonbay13
                      picked up a tv and when the power is plugged, the standby light flashes real quick then goes off. of 3.3, 12, 24v is all there but i couldnt find any 5v on the back-end board. ON/OFF is low, which it seems is what turns on the backlight so i removed the wire at the back-end board and put a 10k resistor to the 3.3v, which when plugged in brings on the backlight for a split second and also a blue light "LED1" on the inverter board, which goes off after a short time.
                      am i missing something to bring on the backlight or is the inverter/ccfl gone bad? would that cause the inverter board...
                      12-01-2023, 09:55 PM
