Picked up this set today. It will power on. No picture or sound. And it will not turn off. I think mainboard. I have all voltage 24v,12v 5vsb 5vps-on 3vbl but no dimming. Pictures will come later.
vizio l42hdtv10a
Tags: None
Re: vizio l42hdtv10a
My camera is on the fritz. But here are some voltage reg. reading.
u4
In 5
out 3
adj 0
u5
I 3.3
o 1.9
.69
u6
i 5
o 3.2
a 0
u7
i 0
O 0
a 0
u8
i 5
o 0
a 0
u9
i 0
o 0
a 0
u10
I 0
O 0
A 0
U16
I 5
O 2.48
A 0
U18
I 0
O 0
A 0
DU2 I 5.5 O 3.3 A 0 DU3 I 5 O 2.48 A 0 DU4 I3.25 O1.25 A 0Attached Filesif you find these attachements useful please consider making a small donation to the site
u8
i 5
o 0
a 0
Input is 5V and no output? it is dead if that is the case or shorted load (you can check the resistance on output pin against GND).Last edited by budm; 10-22-2015, 09:04 AM.Never stop learning
So when you removed the regulators, did you check the resistance between the solder pads where the regulators were against GND to see of the shorts went away?
MLCC: Multi Layer Ceramic Capacitor.Never stop learning
Sorry but i haven't been able to troubleshoot this down to the component. I have ordered a new mainboard and will follow up later.
Thanks for the help!!!!!Comment
Ok replace the main board. Still the same. There is no bl_on voltage or no dim light voltage. I got 4.4dvc on the ps-on. What you guys think?Last edited by fixerupper75; 11-05-2015, 04:02 PM.Comment
Where did you get this board from? Those signals are generated by the main board.Never stop learning
Electroparts off of ebay. I think I've made a rookie mistake the board number doesn't match. Orginal 3642-0062-0150 new 3420-0012-0150. ugh.Comment
a quick google search no one seems to have the board in stock maybe for now whilst your looking put your old board back in and maybe we can do some more fault finding like budm suggests in post 8, also most repair kits online consists of these so double check on your board
Kit contents
Replacement components for U5 , (U4, U6, U8).Last edited by vinceroger69; 11-05-2015, 04:54 PM.Comment
by howardc64Problem
Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
Model & Board Pics
Conflicting Spec
Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
https://www.shopjimmy.com/vizio-gj-2k1... -
by Bugman1400EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
+5VSB= +5.09
12V= +12.18
PS_ON= +2.25
I_ON/OFF= +3.27
LAMP= +3.18
DIM= +2.97
Any more testing I can do on Main board or is it just a replacement?... -
Assuming...7 Photos -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by howardc64Failure Symptom
No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
Where is the short?
Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but... - Loading...
