thosiba 32DT2U1 dead
  • vinceroger69
    • Mar 2012
    • 6714
    Re: thosiba 32DT2U1 dead
    Originally posted by laloualfa
    what BGA means?
    bga means
    https://en.wikipedia.org/wiki/Ball_grid_array
    • laloualfa
      • Oct 2015
      • 15
      • canada
      Originally posted by budm
      Is that reading with the resistor still feed the ACD pin of the main board and ACD pin of the power supply wire not connected?
      yes
      • laloualfa
        • Oct 2015
        • 15
        • canada
        thanks
        very interesting
          yes
          That means something on the main board is loading down that ACD pin.
          Remove that 1K resistor that is connected to the ACD pin on the main board, then you have to measure that ACD pin on the main board to see how low the resistance it has.
          You are sure that 1K resistor you are using is good, if it is good then if you remove that end of the resistor that goes to the ACD pin of the main board, it should then show 5VDC at both ends against GND.
          Can we see how you hook up this 1K resistor to the main board ACD pin?
          • laloualfa
            • Oct 2015
            • 15
            • canada
            I was wrong , at the 1 k reistor to the main board 4.598 vdc when the green pilot light is on.
              So with the resistor in place with solid connection you are able to get the TV to function?
              • laloualfa
                • Oct 2015
                • 15
                • canada
                #27
                no, just the green light comes on for 5 sec and after nothing.
                • Newbie62
                  • Apr 2015
                  • 27
                  • usa
                  #28
                  Is the BGA on the PCB or control board?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #29
                    the bga chip that some times causes issues is on the main board
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • robante15
                      Acer Aspire 4520 won't turn on after reboot
                      by robante15
                      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                      If I remove the...
                      04-06-2024, 06:50 PM
                    • masoksian
                      Dell latitude e7470 not turn on .power buton on off and Run Power problem
                      by masoksian
                      I am dealing with the problem of turning on and off my Dell e7470 notebook.
                      The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                      The system does not turn on, there is no post.
                      I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                      The problem continues in the same way.
                      I tried to turn on the Fn key, nothing came to the screen....
                      02-15-2025, 12:08 PM
                    • Ledgurra
                      MacBook Pro A1425 it doesn't turn on
                      by Ledgurra
                      hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
                      thank you all
                      11-09-2025, 06:07 AM
                    • dqtech
                      lenovo x240 nm-a091 wont turn on
                      by dqtech
                      i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                      board number VIUX1 NM-A091 REV:1.0...
                      02-07-2024, 01:57 AM
