Solarized image on samsung LN40B5307PN
  • Krisna075
    • Oct 2015
    • 4
    • United states
    Hi, I need help in fixing my tv which has solarized image. Can you tell me where is the problem? In the t-con board or main board or power board?
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Solarized image on samsung LN40B5307PN
    This is a tcon board problem could be the as15 gamma ic. But before you buy a new board try reseting the lvds cable. Could just be a dirty connection.
    • Krisna075
      • Oct 2015
      • 4
      • United states
      And i see one capacitor swollen little bit. Does this also have effect on solarization? Can you tell me where is this cable located at please?
      • mmartell
        • Oct 2013
        • 3189
        Between the main board and the tcon.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          A bad capacitor wont cause that symptom I would say failed As15 ic.
          • finntricky
            • Jan 2014
            • 449
            yep i agree with that, as15f
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • ohren
              by ohren
              09-08-2023, 05:24 PM
            • C152Heavy
              by C152Heavy
              Summary for TL-DR readers:
              • VCC pin (18) of PFC...
              01-11-2023, 02:53 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
