Proscan 42LA45H PSU Problem
  • nwcs
    • Dec 2015
    • 311
    • usa
    #41
    Re: Proscan 42LA45H PSU Problem
    let me correct that. I get all of the correct voltages except on which is 0v. This all happened after I replaced three bad caps in the power supply and was running a burn in test. Everything was fine until I turned unit off. I am pretty sure the main is the issue.
    • CapLeaker
      Leaking Member
      • 8326
      so you have no backlight? main board is sending BLon, so if you have nothing there, then the main board is at fault.
      • nwcs
        • Dec 2015
        • 311
        • usa
        #43
        That is kind of what I thought. Right before I turned the tv off there were raster lines in the video but not in the menu.
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • blind2reply
          proscan 40ld45q - no pic -no sound - no backlight - blue light turns off
          by blind2reply
          proscan 40ld45q
          Have tried published resets with no help. (unplug for 10, push on-off for 30, push menu and vol +, etc.)
          After being plugged in, red light comes on. Push power button and blue light comes on for ~five seconds then goes out. Power button does not turn the unit on a second time - have to unplug/re-plug before power button will try to start with blue light.
          No sound, no picture (used flashlight test).
          No bulging cap, no burn spots, no burn smells, nothing visual (cold joints/breaks/bugs).
          Digital voltmeter;...
          06-06-2021, 01:16 PM
        • birdboy385
          Proscan 50" PLCD5092a-b Restarting
          by birdboy385
          Hi all, I have the aforementioned Proscan television. Basically what happens is the TV will boot up like normal once you push the power button, the Proscan logo shows then it shows the channel select and almost immediately you see the date in the corner reset ( I can't recall what to but I semi assume it doesn't matter).
          The TV then freezes for a few moments then restarts. The Proscan logo shows up and the cycle continues pretty much indefinitely. I haven't attempted to let it sit for long to see if it would ever stop doing it. Once the Tv boots up, attempting to push any buttons...
          02-13-2019, 10:33 AM
        • lapfix
          Dell Latitude E5550 LA-A911P no complete power on !
          by lapfix
          First the lap come witth a short to GND , it was a faulty capacitator : PC716
          After desoldered , the lap works fine...but after some tries not power on.
          Power supply reach 0.159amp for 1 minute than off...no short to GND at all coils .
          All the voltages at PM TABLE are finded , try another bios same behaviour !
          PS id is oK ; i try with an original charger same behaviour too...
          PQ700 a P-channel is ok , but his gate is not correct..0.001v...
          Pin 5/8 = 19v
          Pin1/3 = 19 v
          Pin 4 = 0.001v...not correct.
          Pu 800 =
          Pin...
          07-29-2024, 06:05 AM
        • shelby5041
          Proscan 40LD45Q messed up and no image
          by shelby5041
          hi
          tv powers on fine to a blue screen
          when OSD is hit the menu shows up ok sometimes for a few seconds and then just slowly fades away..if i click a diff menu option the refresh is lagging big time from option to option...
          backlights are fine
          this is one of those funky issues that im not sure what would be the cause..maybe bad lcd panel bonded tabs?
          09-22-2020, 03:18 PM
