LG 60PZ570-TB only stays on for 5 seconds
  • nimble87
    • Oct 2015
    • 29
    Hi All,
    My 60 inch LG 60PZ570-TB decided to turn itself off the other day. It now clicks once and then clicks again 5 seconds later shutting it off. I researched it a lot and purchased a replacement C802 1.6kV capacitor. The original one had bulged a little bit, unfortunately the new capacitor made no difference.
    I'm now stuck as to what to do next. I'm still learning when it comes to these things, but like everything else i've pulled apart i'll have a crack at anything.
    PCB: EAX63330001/11
    PSU P/N: EAY62171201
    After reading a few posts I'm thinking it could be the voltage regulator, that's a stab in the dark for me. I managed to find this kit, thinking it may fix the problem.
    http://www.shopjimmy.com/lg-eay62171...repair-kit.htm
    Any help would be greatly appreciated, thanks in advance.
    Cheers
  • CapLeaker
    Leaking Member
    • 8158
    Re: LG 60PZ570-TB only stays on for 5 seconds
    Here is what we need to know. There is a ribbon cable from the PSU going to the main board you have to check with your DMM. Write all those voltages down with their corresponding pin out, with the tv on and the same thing when the tv acted up.
    • nimble87
      • Oct 2015
      • 29
      Thanks for the reply Capleaker, I'll give it a shot tonight after work and post the results.
      Cheers
      • nimble87
        • Oct 2015
        • 29
        Just took some readings on the pin outs on the power supply board, they are as follows:
        Incoming mains = 248v
        YSUS and ZSUS had exactly the same outputs
        VS=203v
        VA=starts at 53v drops to 46v then shuts off
        Mv5=5.2v
        Pin out to ctrl=5.2v
        I had a bit of a play to try and eliminate different boards, the only thing I found was that wen I disconnect the YSUS and ZSUS the TV will stay on with sound only This is the only time I've managed to get the tv to stay on.
        Cheers.
          So, with Y-SUS and Z-SUS connected it clicks off immediately?
          What is Vsus with them connected?
          • nimble87
            • Oct 2015
            • 29
            With both YSUS and ZSUS connected it will click once when powering on and then click again roughly 5 seconds later when it shuts it self off.
            Sorry I'm very new to this, I'm guessing you mean the voltage at Vs test point while connected? It's 203v
              So you get 203V with both boards connected but it still clicks off?
              Weird. Can you try with just the Z-sus removed?
              • nimble87
                • Oct 2015
                • 29
                Yes that's correct.
                Just the ZSUS removed VS test point reads 203v then shuts off
                Just the YSUS removed does exactly the same reding 203v
                With both YSUS and ZSUS removed tv stays on with only sound and no picture. Vs test point reads 203v and Va test point reads 54.9v while tv is running.
                  Does Va read 55V with boards connected?
                  • nimble87
                    • Oct 2015
                    • 29
                    Va is 53v when powered on then drops to 46v a few seconds later as the tv shuts off. That's with both boards connected.
                      OK, not a panel short then, that's good.
                      With the boards removed, does the LED on the control board blink at all?
                      • nimble87
                        • Oct 2015
                        • 29
                        With both boards removed the control board LED flashes green. Two long flashes, followed by two shorter flashes
                          Well, it's not a control board fault then.
                          Baffling - not really sure what to suggest.
                          Could be a short on one board - but seems to affect both?
                          No cracks/damage to the panel?
                          • nimble87
                            • Oct 2015
                            • 29
                            It's got me stumped, could it be that something on the YSUS and ZSUS failed at the same time? The panel is all good.
                            The shut off time seems to vary a little bit depending on how long I leave the tv off. Sometimes I can get a glimpse of the picture before it turns itself off, it seems like it's very close to staying on. Randomly before it stayed on for around 5 minutes with picture and sound working and then it failed again. Haven't been able to reproduce that result again.
                            • nimble87
                              • Oct 2015
                              • 29
                              It wouldn't be the new C802 capacitor causing the problem would it? The output voltages would be wrong if this had failed, correct?
                              Thanks very much for all the effort you're putting in, greatly appreciated.
                                Hm, wouldn't be a short if it worked like that, maybe it is a misbehaving mainboard.
                                Try this:-
                                Disconnect the LVDS cable between the main board and control board. This is the only ribbon cable that runs between the two boards. The main board has the HDMI ports on it; the control board has the blinking LED.
                                Disconnect the power cable between the power board and main board.
                                Put a jumper across the EXT AUTO GEN test points.
                                Plug the TV in, do you get test patterns on the display?
                                If so - replace main board
                                If not - we may need to jumper power board connections to be sure
                                • nimble87
                                  • Oct 2015
                                  • 29
                                  Can't seem to locate the EXT AUTO GEN test points. Are these on the control board?
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Checked Pson and Vs on signals at the mainboard generates ?
                                      AUTO GEN not marked, but it's the two holes next to R51,R52. These need to be shorted together.
                                      • nimble87
                                        • Oct 2015
                                        • 29
                                        Ok so just had a quick test this morning.
                                        The first time it powered on it flashed a red screen and turned off, 2nd try did the same, 3rd it stayed on and went red, then green, then blue and then sweeping gray color from each direction and then switched off.
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                          Samsung ccfl tv powerboard clicks every 5 seconds.
                                          by nomoresonys
                                          Having a problem diagnosing this old tv, seems to be a powerboard problem, trying to trace the problem from power in at ac cord to power out to ccfl lamps but not doing very well in the attempt, power board there: https://www.shopjimmy.com/samsung-bn...w-605563813499
                                          07-01-2023, 02:10 PM
                                        • liquidzorch
                                          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                                          by liquidzorch
                                          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                                          10-18-2024, 05:19 PM
                                        • PowellSkier
                                          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
                                          by PowellSkier
                                          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
                                          06-17-2024, 11:43 AM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
