Vizio e371vl dead after suspected lightning
  • amlederer
    • Oct 2015
    • 14
    I picked up a vizio e371vl (also a e422vl) off of craigslist for free. Owner suspected they had died from a lightning strike. That is all I know of their history. Working on the 371 first. Plugged in it is completely dead, no standby light, vizio logo does not light up any color. Back pulled off. I am a novice when it comes to TV's. Most of my experience deals with PC's and PC monitors. Visual inspection does not show anything obvious, caps look good, no burn marks. I checked the volts at the plug on the power board. The 5volts all look good when plugged in, the 12v and the on/off all stay at zero, even when power button is pushed. I assume and this could be totally wrong that I am looking at something on the main board? Pics fo boards and my meter below. Will this meter be sufficient or do I need to invest in something better?
    Re: Vizio e371vl dead after suspected lightning
    If you do have 5VSTBY to run the main board but the main board does not send any command signals to turn on the rest of the power supply, the the main board will be the first place to check. You are going to need good digital meter to test the Voltages, especially the LDO regulator ICs.
    • CapLeaker
      Leaking Member
      • 8147
      Test the main board first. Sounds like it doesn't return PSON signal to the PSU. After that you can force the PSU on to see if it is o.k. Yeah, I do think too that you do need a better meter than that.
      • amlederer
        • Oct 2015
        • 14
        Any recommendations on a decent meter that won't break the bank (amazon prime or local big box would be nice). I do think that one of the fuses on the main (right of the two right below the plug from power board) on the main board is blown.
        • amlederer
          • Oct 2015
          • 14
          Would this be a decent low cost choice? http://www.amazon.com/Etekcity-Digit...tal+multimeter
          • fzabkar
            • Mar 2009
            • 772
            Here is a better photo of the main board, p/n 3637-0652-0150(6C):
            http://cdn2.bigcommerce.com/n-d57o0b....1280.1280.jpg
            The LG 42LV4400 TV uses the same MediaTek MT5376 SoC. The service manual has circuit diagrams (with pinouts) and a partial datasheet.
            Service manual for LGE 42LV4400 TV:
            The MT5376 SoC requires the following voltages:
            VCC3_STDBY -- 3.3V
            VCC3IO -- 3.3V
            VCCK -- 1.1V
            VCC2IO -- 1.8V DDR2 supply
            AVDD33 -- 3.3V analog supply
            AVDD12 -- 1.25V analog supply
            JVC's JLC37BC3000 TV uses the same main board (017122713276), but I couldn't find a service manual for it. :-(
            • ozzy214
              • Nov 2013
              • 319
              • usa
              I personaly use the sears dvom, craftsmen., Think it was 20 bucks. Use for electronics and car work.
              • amlederer
                • Oct 2015
                • 14
                I will pick up a new meter at lunch today. where would be a good spot to start looking on the mainboard?
                • fzabkar
                  • Mar 2009
                  • 772
                  Your photos are useless for troubleshooting purposes, and I don't feel right about using other photos without permission. In any case I can't read the IC references on any of the photos.
                  That said, the LDO regulators that were mentioned by budm (I think I can see 4 of them) look like this:
                  http://inter-chip.pl/images/product/20694_03a275.jpg
                  Measure the voltages on all three pins plus tab.
                  There are also several switchmode regulators. Assuming these are all step-down regulators, then the output voltages should be present at the coils. I can see two 4R7 coils and three 220 coils, so this would suggest that there are at least 5 switchmode regulators.
                  There are 4 coils near the front panel pushbuttons, but these are associated with a class-D audio power amp.
                  • amlederer
                    • Oct 2015
                    • 14
                    Should these be measured with the set plugged in or not plugged in?
                    • CapLeaker
                      Leaking Member
                      • 8147
                      regulators you measure with the set on, your meter set at DC Volt, your black lead on chassis GND and probe the pins and the tab of these regulators with the red probe.
                      • amlederer
                        • Oct 2015
                        • 14
                        Will check them tonight (although it will have to be plugged in and off as the set does not turn on)
                        • fzabkar
                          • Mar 2009
                          • 772
                          Where do you think that voltage comes from?
                          • amlederer
                            • Oct 2015
                            • 14
                            Very True. LOL
                            So I did some testing with my new meter. F1 is shorted. All of the LDO regulators are 0V at all posts. But worse is U46 appears to have fried.
                              The surge came through the HDMI ports, I bet the cable/Sat box was probably damaged too.
                              You will need a new main board.
                              The two fuses on the main board, one is for 5VSTBY, another one is for switched 12V.
                              • amlederer
                                • Oct 2015
                                • 14
                                F2 shows 0V on both sides, F1 shows 5V on one side and 0V on the other
                                • amlederer
                                  • Oct 2015
                                  • 14
                                  Thanks Budm, I have a line on a board with a bad eeprom. Do you think the eeprom from this board is still good or cooked as well?
                                  Time to dig into the e422vl I have as well
                                  • amlederer
                                    • Oct 2015
                                    • 14
                                    Looks like the same thing happened on the 422 except no fuses were blown. Just a chip out of the similar chip next to the had I ports, I do also have voltage at the on off on the power board but everything acts dead
                                    • Iain P
                                      Vizio E65-F0 really dead
                                      by Iain P
                                      Hi everybody!
                                      I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                                      So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                                      I decided to check the voltages coming off the power supply they are as follows:
                                      connector CN201
                                      pin 1 (18vsb1)...
                                      02-23-2023, 11:32 AM
                                    • catnapped
                                      Dead Vizio D40u-D1
                                      by catnapped
                                      Recently had my bedroom Vizio D40u-D1 apparently die while it wasn't being used. Noticed the power LED flashing, figuring maybe a software upgrade, but attempting to turn it on proved that wasn't the case. When powered on, the power LED will flash a bunch of times after about 2 minutes then turn off again. Definitely is no picture even with a flashlight on the screen. Had the opportunity to open it up over the weekend. Doesn't apper to be anything out of the ordinary visibly inside, nor any odd smells of escaped magic smoke. Readings from the connector in the corner of the power supply board...
                                      04-02-2024, 08:55 AM
                                    • fharris1977
                                      Vizio D50u-D1 Dead: PSU or Main Board?
                                      by fharris1977
                                      Hi. Anyone who has experience with these vizio sets, which pin on this connector is the standby, the 5V pin? Trying to rule out the PSU before ordering a mainboard. I'm getting 0 Volts on all pins on this connector. Trying to jump the standby and PS ON pins to see if the PSU is functioning. Thanks in advance.
                                      03-12-2024, 12:22 PM
                                    • fharris1977
                                      Vizio D50u-D1 Dead Set No Standby
                                      by fharris1977
                                      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                      12-28-2023, 10:25 AM
