LG 42LW450U mainboard MICOM SoC_Reset holding processor in reset?
  • jesterace
    • Aug 2013
    • 87
    • United Kingdom
    I'm troubleshooting another TV that has no backlight or picture. Standby light comes on, and TV can be turned on with all PSU voltages available. I've followed the procedures to jump start the backlight, and that works ok but there was still no picture.
    All PSU voltages appear normal.
    Suspected mainboard and have been following the schematics checking voltages. Haven't found any missing voltages on the mainboard but have discovered that it's a MICOM microcontroller that starts the TV up. It's sending the PSU turn on signal ok, but the INV_CTL or (INV_ON) is 0v.
    My main question is about a pin labelled SoC_Reset on the MICOM chip. It's reading 0v.
    From my bit of experience fixing laptops, i'm guessing i'm right in thinking the main processor/video chip is being held in reset (problem)?
    Just wondered if anyone encountered this before?
    I suppose signals like the INV_ON signal from MICOM gets sent out after the reset it pulled away from SoC??
    Cheers,
    James.
  • CapLeaker
    Leaking Member
    • 8168
    Re: LG 42LW450U mainboard MICOM SoC_Reset holding processor in reset?
    what are the numbers on that chip so we can pull the specs hopefully.
    • jesterace
      • Aug 2013
      • 87
      • United Kingdom
      number of chip is uPD78F0514
      I read a bit about it in one document but from how i understood, the pin used for this SoC_Reset is a programmable in/out pin. Not sure if it's programmed to be active low or what in this TV.
      • CapLeaker
        Leaking Member
        • 8168
        that's the question I don't know either. You can try cutting the trace, lift a pin, tracing the reset trace etc.
        • jesterace
          • Aug 2013
          • 87
          • United Kingdom
          yep think i'll follow it, maybe cut the trace and see what happens if i pull the reset high.
          I suppose considering the PS_ON signal is coming out of the MICOM, the EEPROM/data is probably in good shape?
          • ngth82
            • Jul 2015
            • 541
            My appologies for resurrecting an old thread, but were you able to diagnose what was wrong with your MICOM? I have the same issue that is being tracked in a new thread for a 55LV5500. Your response would be greatly appreciated and any insight into fixing your current issue would help me (and others!) out.
            Thank you,
            Thomas
            -Thomas
            I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
            • TLFonderie
              • Feb 2017
              • 11
              • Europe
              I'd like to resurrect this thread too. I have the 42LW450U that has not picture. I found out that the MOFSET Q601 is dead. I would like to order two new ones (I'll replace Q602 while I am there).
              I never ordered MOFSETs before.
              What I can read on them is
              18NM60N
              GK2AR V6
              CHN 039
              apparently from ST Micro from the logo.
              Someone could tell me where I can buy this by unit? Thanks... and keep all feeding the badcaps community!
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                https://uk.rs-online.com/web/c/semic...384E4D36304E26
                  BTW, What is the P/N of the IC that the GATE of the failed MOSFET connected too? When that MOSFET went out it could have taken out the Gate driver circuit inside the IC with it so your newly installed MOSFET can be damaged.
                  • TLFonderie
                    • Feb 2017
                    • 11
                    • Europe
                    Thanks Peter... I studied mechanics so my knowledge in electronics is limited. But I want to learn.
                    So my question might be silly but there are 4 different MOFSETs on the link that you provided. How do I know which one is the one I am looking for? Will the 4 of them do the job?
                    • TLFonderie
                      • Feb 2017
                      • 11
                      • Europe
                      Hi Budm,
                      As mentioned in my previous post, I have a limited knowledge in electronics but I am willing to learn. So thank you both for your help. I will put in pictures of the board so maybe you can tell me if I am wrong.
                      As far as I can see, there is only one IC near the MOFSETs. One of it's branch is going to a strange MOFSET that has only two branches, not three, and this MOFSET seems to feed the triger (middle) branch of the MOFSET.
                      Hopefully my explanations make sense.
                      If that IC needs to be changed, that will be a soldering challenge because it's quite small.
                      I'll post the pictures in a minute.
                      • TLFonderie
                        • Feb 2017
                        • 11
                        • Europe
                        Here are the pictures
                        I put a red square around the faulty MOFSET on the last picture
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          pick the one that looks the same as yours . there are 3 different case styles
                          • TLFonderie
                            • Feb 2017
                            • 11
                            • Europe
                            Yes you're right, the first one is the one as it has the tread for the screw to the heat bridge
                              Pictures are low res so I cannot even read the P/N of the PCBA.
                              That section where the MOSFET is si the PFC section.
                              • TLFonderie
                                • Feb 2017
                                • 11
                                • Europe
                                Sorry about the low resolution, the pics have been resized when I added them into my badcaps account. The PCB part numbers are PCB P/N EAX62865401/8 (rev 1.0 2010.11.19) LG P/N EAY62169801
                                Funny enough it has two part numbers...
                                  EAX???? (printed directly on the board) is the PCB (Blank circuit board without parts installed)
                                  EAY??? (on the barcode sticker) is the PCB Assembly which is the PCB stuff with the required parts to make PCB Assembly for particular model, countries, ECT.
                                  http://www.shopjimmy.com/lg-eay62169...upply-unit.htm
                                  LG EAY62169801 (EAX62865401/8) Power Supply.
                                  Pictures provided by shojimmy.
                                  Please see if this is the same as your board.
                                  BTW, those two MOSFETs are for the PFC Voltage booster circuit, they are bascially connected in parallel, the one device with two leg is the diode for the PFC.
                                  The SMD IC close to the MOSFETs is the PFC Controller IC, P/N?
                                  So when you say the MOSFET is dead what exactly do you mean? It has very very low resistance between S and D pin? If it is shorted or has very low resistance the main AC fuse should have blown too.
                                  The more details as what TV/Board not doing the better.
                                  • TLFonderie
                                    • Feb 2017
                                    • 11
                                    • Europe
                                    Actually, both EAX??? and EAY??? are printed on board. I have another number on the sticker, which BB2HD62169811056 (1.4)
                                    I also found another part number printed on the card, which is LGP4247-11SLPB
                                    Unfortunately as I am located in Europe, I do not have access to shopjimmy, the access is prohibited for some reason.
                                    Anyway, I detached the MOFSETs and tested them... and I was wrong, both seem to work (tested with my tester on "Diode" mode).
                                    So I plugged the 220V input cable and measured the output lines of the card. The led feeding lines are all at 5.1V. The motherboard feeding line has 3.5V where indicate, but has 0V on the 12V lines (PWM, N.C., DRY-ON) and the 24V lines as well (24V, PWR-ON).
                                    One weird thing is that when I put my multimeter in alternative voltage position and I put only my minus wire on the ground of the card (on one of the screws), I get a 12V reading without having the positive wire touching any component...
                                    • R_J
                                      • 9535
                                      Your led voltage (118 vdc) comes from D206, filtered by C212 & C213 and feeds one lead of the led's. The return lines are controlled by the led driver sub board
                                      • R_J
                                        • 9535
                                        Ops... Ignore my post #19, wrong thread
                                        As for this thread, Check your P201 PWR-ON pin, that pin turns the power supply on and off and I believe needs to be (high) to turn on the board.
                                        To test the power supply, disconnect the cable between P201 and the main board, then get about a 1k resistor and connect it between 3.5v and POW-ON, that should give you +12v and +24v
                                        • Yanleb
                                          LG 42LV5400-UB doesn't power up, Micom issue
                                          by Yanleb
                                          This repair is very challenging. I already made my way to the problem. Please read the complete post before commenting. I need the help from good gurus.
                                          The power button on the TV set is working, the same for the power button on the remote control. When activated the power LED changes from red to white and the power supply relay clicks. But no image appears, and no sound is heard.
                                          I already investigated the problem. the Micom chip on the EBR73110104/EBT61520408 main board is the issue. The Micom is IC602 that use the μPD78F0514 (UPD78F0514)...
                                          01-03-2022, 10:52 PM
                                        • Sorrow1
                                          OPTI-495SLC 386 WB mainboard fails to POST but not after reset
                                          by Sorrow1
                                          I'm repairing OPTI-495SLC 386 WB manboard: https://stason.org/TULARC/pc/motherb...LC-386-WB.html
                                          It has some damage due to battery leak that I have cleared. I measured affected wire patches and they seems to be OK. The damaged part is shown on the attached picture.
                                          The board often fails to POST when I turn the PSU on. Most often POST card gives AMI BIOS 12/13 error codes but no code or different codes are also shown sometimes.
                                          When I reset the board while the PSU is running or if I switch it OFF/ON the...
                                          03-20-2023, 02:24 PM
                                        • rutgerv
                                          Acer Swift 3 SF314-42 not powering up
                                          by rutgerv
                                          Dear all,
                                          For a friend I'm trying to repair an Acer Swift 3 laptop (SF314-42). I'm not a professional, but have some experience (both as amateur and professional) in working with electronic design and repair of musical instruments.
                                          The issue with the Acer laptop is the following:
                                          It was bought new and used (not heavily) at home for about three years. After normal use, it was put to sleep, connected to charger and left over night (just like any other day). The next morning, the laptop would not wake up from sleep. Instead, when pressing the power button, the power...
                                          08-02-2024, 06:59 AM
                                        • orcic
                                          MASTER TL240 and new mainboard LW36BKC01
                                          by orcic
                                          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                                          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                                          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                                          Now I have some doubts about how to connect the new mainboard to the old power supply.
                                          First of...
                                          05-12-2023, 08:10 AM
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
