e701i-a3 no picture but backlights
  • jtcurtis
    replied
    Re: e701i-a3 no picture but backlights
    I have a 701i - a3 with same symptoms picture with no sound and back light comes on. I have 480 ohms on transistor on one leg + 1.7 on the other. Is that functional? When I check the power I have no electricity on the silver capacitor no readings on the other inductors except for 100 which gives me 12.3. The transistor also gives me no electricity reading. So it ohms good but no volts. What could be the issue?
    replied
    Wasn't clear if it had side tabs or not, now we ARE.
  • budwich
    replied
    the "tape thing" doesn't work if there are side tabs which the set has. Good that you found them and "saved" the set.
  • kevinm34232
    replied
    FYI I tried the tape thing with no luck as I was going about blindly anyway. But the fix for this 70" was exactly the same for the D650i-B2.
    https://www.badcaps.net/forum/showthread.php?t=81665
    replied
    I think most start on outside and work their way in, mostly trial and error.
  • kevinm34232
    replied
    I see what they're doing with the tape, but is there any method for which pins to cover or trial and error?
    replied
    Guess you could try the "cut tape" method, sometimes you have to fuss with tape placement to get it right, might not work but doesn't cost much: https://www.youtube.com/watch?v=j7vl7-vZEL8
    replied
    Maybe check the mlcc caps on driver board for shorts or very low ohms, guess it could also be a tcon issue.
  • budwich
    replied
    are you looking from the front? Side tabs (no boards) are only visible when the front plastic bezel is removed.... but a 65 may not have them. I think they do... 60 or smaller usually don't.
  • kevinm34232
    replied
    @Kevin, take it slow, tab removal can not be undone, in a lot of the tvs that were fixed by this ingenious method, thanks Freakafter8, had horizontal lines running thru the display, which is not to say that it has to be, just that you want to make sure the tab/s are the problem before removal. Did you try the disconnect one ribbon cable at a time to see what you have on display?
    Yes I have repaired an E701i-A3 with the same issue and fix. One side of this panel is bad I just don't think there are side tabs on this one. I took one apart with a broken screen a couple weeks ago but didn't pay attention.
    replied
  • kevinm34232
    replied
    Has anyone messed with a Vizio D650i-B2? I have one where there's just ghosting picture of vertical lines but disconnecting one side of the panel at the T-Con board gives a good half picture on the other side of the screen. I have not taken the TV apart down to the panel to see if there are any side ribbons that can be removed. Panel # T650HVN05.9
  • Biggnate81
    replied
    I can't believe this post is still active 4 years later... Anyways i was recently given an E701i-a3. Using this thread i replaced the T-Con Board and disconnected the right side drivers from the LCD panel and too my surprise i got a nice picture on the TV. The only problem is the faint " white" spots around the bottom half of the screen, they are really only noticeable when a white picture is displayed on the screen. Is there a fix for these "white" spots or is this as good as its going to get? Sorry for the terrible picture, it is difficult to get a good picture of these spots.
    replied
    20 vdc, on meter black probe goes in com red probe in the one with v ma marking.
  • grandjury3
    replied
    [QUOTE=nomoresonys;929874]Can you post a picture of it? usually you just poke your probe down from the top a little til you hit metal, guess you could use some stripped bread ties.
    gotcha thanks, I am new to all this , trying to figure out what setting to set the multimeter to as well, I am new to this level of repair
    replied
  • grandjury3
    replied
    Start with #3 below, try to do it just as instructed, as always BE VERY CAREFUL when working with powerboard, there are DEADLY voltages on HOT side.
    I attempted to test this voltage, I am unable to find a place to put the positive side on the powerboard because it is surrounded by plastic. what should I do? can I test it from the maine board side? thanks
  • grandjury3
    replied
    Did they tell you what symptoms the tv was exhibiting?
    Yes, when I turn it on the backlight comes on and no picture, but there is audio
    replied
  • grandjury3
    replied
    thank you so much for the quick reply! I'm going to try that right now , I'll post how it goes
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
