This fix is the same as the Vizio e701i-a3, you can refer to the thread below started by freakaftr8:
https://www.badcaps.net/forum/showthread.php?t=49281
Same issue basically, backlight with no picture or fading vertical lines. Removed left side ribbon from T-Con to panel and had good picture on right side.
Panel # T650HVN05.9
Removed the 8 left side driver tabs from the panel and as with the same fix from freakaftr8, it's all good.
Hope this helps others, I was about to gut the TV for parts when I remembered to try the same fix above.
It's also really easy to get at these tabs on this model.
Panel # T650HVN05.9
