e701i-a3 no picture but backlights
  • hubbardd
    • May 2017
    Re: e701i-a3 no picture but backlights
    Hey just a shout out to budwich, freakaft8 and the rest of the crew. Found a TV by the dumpster (Vizio 70 A3i) and was able to fix it by removing the side tab drivers on the right side. I didn't even have to fix the TCON board Thanks!
    • SleepyWakes
      • May 2017
      • 7
      Originally posted by budwich
      ok... so you got the picture part right... now how about some description of what this represents... what cables are connected, what are not. My guess is you have bad tabs on the right side (looking at the picture). You should spend some time and read thru the thread as there is lots of info and you are basically close to a save.
      Here has been my process:
      • Only backlight, no boot-up
      • Remove the right white ribbon and see no change. Re-attach right white ribbon
      • Remove the left white ribbon and see no change. Re-attach left white ribbon
      • Remove both white ribbons and see no change. Re-attach both white ribbons
      • Order t-con board and install
      • Get boot-up but picture is black/blurry on right side with horizontal line across entire screen 1/3 of the way up from the bottom (previous photo)
      • Remove right white ribbon and right side driver panel
      • Get full picture but it is not particularly sharp and has a green (and sometimes red) tint. See photo below
      • budwich
        • Jul 2015
        • 3097
        hmmm.... show a picture of the back panel with attention to the "right side panel" removed. how did you remove it?
        • SleepyWakes
          • May 2017
          • 7
          I can't get a photo right now unfortunately, but I followed the pictures and videos that Freak has posted on how to remove it. I unplugged the white ribbon at the bottom and then carefully pulled off the five tabs to remove the side driver component and set it aside. I put the metal cover back on the side with the white ribbon at the bottom unattached to anything.
          I can snap a photo tonight if that will help. Thanks for helping me through this!
          • mikegarland
            • Jun 2017
            My resistance readings on my tcon are 800ohms on one side and almost nothing on the other (1 ohm.) You think its shorted?
            • budwich
              • Jul 2015
              • 3097
              interesting.... not sure anyone has actually check that way. I would think that they should be the same on both sides.... 1 ohm is pretty low as you are then likely looking at 12 amp flow.... which is pretty high. see if you can do a "visual" on that side looking at the various tab drivers for signs of heating / over heating.
              oops.... you are doing reading of the "fets" on the tcon board. It appear that the fet in question is shorted.
              • HAHOMETP
                • Nov 2012
                • 155
                Just used this method to fix my Dell 3007wfp monitor. Thanks again, folks!
                • budwich
                  • Jul 2015
                  • 3097
                  good to know that a few other types of sets can be "saved" this way. I assume that you may have some issues with refresh rates and possibly resolutions being a bit soft ... maybe.
                  • HAHOMETP
                    • Nov 2012
                    • 155
                    No issues, everything is perfect.
                    • augiedoggy
                      • Aug 2016
                      • 62
                      • united states
                      #730
                      im having a strange issue even tried a second tcon board but it had no effect... the picture looks very pixelated and almost out of focus... if its not the panel at this point I suppose it could be the main board but its odd that know one else has this issue if its the panel and or its related to removing the side buffers off one side.
                      • augiedoggy
                        • Aug 2016
                        • 62
                        • united states
                        #731
                        I think im having the same exact issues as you after the same fix only I removed the left side buffer boards. picture looks poor with marcoblocking like that in dark scenes... tried second tcon after reading on another forum it corrected this issue for someone but it did nothing for me.
                        • SleepyWakes
                          • May 2017
                          • 7
                          That does sound like what mine looks like. Blocky and out of focus. I may try a second new Tcon because perhaps I blew the last new one. I'll let you know how it goes.
                          • budwich
                            • Jul 2015
                            • 3097
                            you might consider replacing the lvds cable going from the main to the tcon.
                            • augiedoggy
                              • Aug 2016
                              • 62
                              • united states
                              #734
                              I have tried cleaning and reseating the cable multiple times... I may try replacing it but I already have an extra tcon board now and hate to keep sinking money into it... I have about a dozen other sets repaired sitting here that I cant even give them away it seems... Even as little as a year ago I could sell them easily.
                              At this rate I think I will live to see the day when people buy clothes to wear them once and throw them away instead of washing them..
                              • budwich
                                • Jul 2015
                                • 3097
                                :-( it is rather disappointing as I know. Hopefully, the card replacement will work. My "take" on blocking / fuzzy, is that it is associated with loss of transmission "integrity" (error or timing or otherwise) resulting in compensation or otherwise by an appropriate circuit that tries to do "magic" with what it did get but it could just as much be a problem with the "end circuit" not handling the incoming stream well for what ever reason.
                                I do seem to recall a few other instances where tcon replacement helped with this type of problem though.
                                • augiedoggy
                                  • Aug 2016
                                  • 62
                                  • united states
                                  #736
                                  Yes well in my case both tcons have the same picture quality..
                                  • SleepyWakes
                                    • May 2017
                                    • 7
                                    Looks like the new T-con board did the trick for me.
                                    Thanks!
                                    • jwillifixit
                                      • Apr 2017
                                      • 113
                                      • usa
                                      #738
                                      On my way out of town this past Sunday for a work trip I came across a Vizio e701i-a3 but didn't have the time to try to power it up (only had time to swing back by the house and drop it off in the shop)... I can't wait to get back home and see what I've got!
                                      • jwillifixit
                                        • Apr 2017
                                        • 113
                                        • usa
                                        #739
                                        Originally posted by freakaftr8
                                        , ok what you have disconnected in your pictures looks proper. However you need to test your t-con board to make sure that its not failed from the get go. A lot of eBay sellers are selling bunk non functioning tcon boards. You'll notice in my illustrations one picture shows which transistor to check mark with the red box. You need to set your voltmeter to ohms mode and black probe the center pin right probe the right bottom pin in the left bottom pin make sure that neither side is shorted. One side should show roughly 500 ohms and the other side should show almost infinite. If your getting anything other than that your tcon board is toast
                                        Do I have this right?
                                        • jwillifixit
                                          • Apr 2017
                                          • 113
                                          • usa
                                          #740
                                          Update on my find... turns out the screen was broken so this one is not a candidate for the surgery fix.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • maxim2511
                                            LG 55EC930V OLED - swich on swich of no screen
                                            by maxim2511
                                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                                            Then I get an idea to take it apart and clean boards from dust.
                                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                                            05-14-2021, 02:21 AM
                                          • Fly_Among_Stars
                                            VIZIO E70-E3 Half picture with half TCON
                                            by Fly_Among_Stars
                                            I have a VIZIO E70-E3.
                                            Symptoms: Black screen, no picture, but LED backlights are working.
                                            I probed the power board and voltages are as listed on the board.
                                            Main board appears fine, too.
                                            I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                            There are two separate ribbon cables feeding the LCD.
                                            If both are connected, the screen is black.
                                            If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                            04-24-2023, 08:20 PM
