Samsung LCD LN-S4051D, replaced caps, same issue
  • mack505
    • Jul 2011
    • 44
    • US
    Hi all, I have replaced the 7 recommended capacitors on the PSU as recommended, but still having the picture go out after the TV runs for a while. It gets pretty warm.
    The picture will not come back on unless I reseat all the connectors on the PSU board. Then once it gets warm, it cuts off again.
    Any ideas?
    Saved - Element 24" LCD TV, Spectre x22wg-Gamer, LG Plasma DU-42PX12XC, Pioneer Plasma PDP-42A3HD, SONY KDL-55EX501
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung LCD LN-S4051D, replaced caps, same issue
    What mainboard is it ?
    • CapLeaker
      Leaking Member
      • 8079
      Any ideas?
      cold solder joint?
      • mack505
        • Jul 2011
        • 44
        • US
        The main board is a BN41-00679D. 6/26/2006.
        Some of the capacitors had been replaced before as part of the warranty. I think when I unsoldered this time, the solder pad lifted up on 2 of them. Dead in the water?
        • CapLeaker
          Leaking Member
          • 8079
          pictures?
          • Terryfictv
            • Mar 2011
            • 124
            Solder connects on ICM801 regulator
              Is this your main board?
              http://www.shopjimmy.com/samsung-bn9...main-board.htm
              • mack505
                • Jul 2011
                • 44
                • US
                Hard to get good pics, but here are a few. I obviously need to get better and solder/desoldering, just wonder if this one is toast.
                The solder connects look ok on ICM801
                • mack505
                  • Jul 2011
                  • 44
                  • US
                  Originally posted by budm
                  Yes, that's it.
                  • CapLeaker
                    Leaking Member
                    • 8079
                    Ooyyyyyyy! But that can be repaired easily, at least for someone who knows how.
                    • mack505
                      • Jul 2011
                      • 44
                      • US
                      Yeah... pfffvt. Welp, any direction? I saw this thread that shows someone exposing the copper, tinning it and using a patch...
                      http://home.comcast.net/~machrone/bjr/mistakes.htm
                      • CapLeaker
                        Leaking Member
                        • 8079
                        Yep, you got the idea! You also can use a small piece of wire, to the exposed copper and one turn around the leg of the cap. maybe google something like pcb repair or trace / pad repair... something along that line.
                        What happened to you was / is your soldering iron ran out of heat, it isn't big enough wattage wise.
                        • Terryfictv
                          • Mar 2011
                          • 124
                          Clean off flux with old toothbrush and denatured alcohol.
                          • mack505
                            • Jul 2011
                            • 44
                            • US
                            Ok, I will give it a shot. So I was using a desolderer, with the bulb that sucks up the solder. The soldering iron I have is a 15/30w, usually use it on 30.
                            • CapLeaker
                              Leaking Member
                              • 8079
                              yeah... I figured.
                              • mack505
                                • Jul 2011
                                • 44
                                • US
                                yeah... I figured.
                                I should grab a higher watt iron than my 30 you think? And/or should I avoid using the desolderer?
                                  09-07-2024, 05:50 AM
                                • vincentedel
                                  Samsung SyncMaster 740n Phase Control Issue
                                  by vincentedel
                                  I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                                  I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                                  04-22-2025, 12:33 AM
                                • Manucsl
                                  QE65Q800TATXXC Samsung TV Issue
                                  by Manucsl
                                  Hello.
                                  My TV is a QE65Q800TATXXC Samsung TV.
                                  Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                                  Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                                  Any ideas to check would be very appreciated 😊
                                  After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                                  02-19-2025, 07:47 AM
                                • ScHAmPi
                                  Samsung UE48JU7000 screen issue after backlight replacement
                                  by ScHAmPi
                                  Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                  I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                  07-15-2024, 05:41 AM
                                  09-06-2024, 11:40 PM
