Panasonic TX-P42X50B Totally Dead
  • sordids999
    • May 2013
    • 2155
    Good evening guys
    Just got this set its totally dead no standby light etc
    i looked at tw2005 post about the TCZAA6755U IC ref (U203) problem but im getting 4.94 volts on the STB5V volts or could it still be the IC ?
    thanks
  • sordids999
    • May 2013
    • 2155
    Re: Panasonic TX-P42X50B Totally Dead
    ok so removed the main board to check it visually and put it back now the tv is powering up fine so i think ill try changing the IC
    thanks
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Sounds like the tv have you checked under neath the Psu as aware that these suffer from corrosion damage ?
      • sordids999
        • May 2013
        • 2155
        Board looks fine to me
        • sordids999
          • May 2013
          • 2155
          Update:
          changed TCZAA6755U IC ref (U203) tv working again
          • CapLeaker
            Leaking Member
            • 8195
            short n sweet!
            • Clutchbox
              Cap Clutcher
              • Sep 2011
              • 41
              • The Netherlands
              Watch out for future reliability problems, it's all Aishi caps inside this Panasonic.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I got one here now, Ic has input voltages but nothing out so going to change it. Awesome thread mate thanks
                • Mike Russell
                  Lenovo 14ALC6 - NMD521 - No power, totally dead.
                  by Mike Russell
                  Machine won't power on, no power led, no fan spin, completely dead.
                  Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
                  Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
                  VCC 20v
                  ACDET 2.8v
                  ACDRV 0v (goes to pin 4 gate of AONS32314).
                  ACOK 0v
                  REGN 6v
                  According to datasheet, conditions are correct for ACOK to be high but it is not.
                  Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
                  12-25-2024, 08:31 AM
                • phantomEVO
                  [HELP] 2 Imac 820-2641 TOTALLY DEAD: NO LED/1 LED
                  by phantomEVO
                  hi to all! please help with 2 imac 21,5 dead...
                  i already changed u7700 in both without luck
                  u7700 pin 17, 18, 5, 4, 24, 12
                  have those voltages in both imac..
                  12v, 5v, 5v, 5v, 0,3v, 3,9v
                  i have 3V3_S5 (L7710) in one imac (one led) but no 5v on L7750
                  NO SHORT ON L7750
                  i have not 3V3_S5 (L7710) in the other (no led)
                  PLEASE HELP I'M GOING CRAZY!!
                  01-25-2024, 01:46 PM
                • badcappo
                  Dead Panasonic Viera TX-P65STW50 Plasma TV
                  by badcappo
                  Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                  Diode type G972s6 - D101 with a short
                  Mosfet 06N90E - Q301 shorted
                  Fuse T5AH 250V - F103 blown
                  Diode D301 shorted
                  Relay DG1U-17VDC II - RL001 blown
                  I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                  11-24-2024, 11:27 AM
                • Andre Gilbert
                  by Andre Gilbert
                  Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                  Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                  11-20-2024, 08:52 PM
                • phantomEVO
                  [help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
                  by phantomEVO
                  've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
                  replaced u5000 with a brand new one now i have
                  PPBUS_G3H=8.18
                  3V42_G3H=3.42
                  3V3_S5 3,3
                  no voltage for PP3V3_SUS (no shorts
                  on u8020 i have 0v on P3V3SUS_EN no shorts
                  0v on R1464 no shorts
                  SMC_ADAPTER_EN, 0v
                  PM_BATLOW_L, 3,3
                  PCH_DSWVRMEN, 0v
                  PM_DSW_PWRGD 0,9v​...
                  02-26-2024, 10:08 AM
