Vizio e701-a3 tcon or panel?
  • topfli8979
    • Oct 2012
    • 311
    I have a Vizio e701-a3 that very seldomly will show a image on the screen. I normally have to unhook panel ribbons and reseat to get anything. When I do see a image its very distorted and almost pixelated even though it's a led. I know this model has known panel issues, what's chances a tcon would fix it.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio e701-a3 tcon or panel?
    Well from what I've been dealing with it very well could be a bad panel. Try leaving one ribbon cable connected to the screen at a time from the T CON instead of both and see if you have a picture that looks somewhat normal
    Do you have horizontal lines throughout the screen?
    • budwich
      • Jul 2015
      • 3097
      looks like another candidate for "THE OPERATION"
      • freakaftr8
        • Oct 2012
        • 3743
        Haha yep. Another sharp panel. This is the model I performed the "operation" on..
        • topfli8979
          • Oct 2012
          • 311
          Unhooking either ribbon cable does not show a picture. I cant get a picture at all now, think i toasted tge tcon. Someone fill me in on "the operation" please...
          • johnboy1313
            • Nov 2012
            • 1959
            https://www.badcaps.net/forum/showthread.php?t=48477
            Things start to pick up around the third page or so.
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • x_orange90_x
              TCL 50S535 bad tcon or panel issue?
              by x_orange90_x
              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
              03-29-2025, 11:02 PM
            • netgearnetgear
              TCL 43S423 TCON OR PANEL FAULTY???
              by netgearnetgear
              Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
              08-20-2025, 06:04 PM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • mmartell
              General Questions on the Relationship Between Mainboard, TCON and Panel
              by mmartell
              My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
              I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
              And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
              01-06-2024, 01:32 PM
