NS-LCD26A Picture/Screen Problem
  • rebelkustoms
    • Sep 2015
    • 150
    Hello All,
    I am new here, I have an insignia NS LCD-26A. The television comes on but either has a white or scrambled screen. A few times I got the "no signal" message to display, but when I did the vertical hold was going crazy, I got to the menu and switched inputs but eventually everything becomes unresponsive. (see pics for some of the screens I get)
    I am a big fan of collecting and repairing Pinball machines so I know my way around some soldering, a DMM, and I am familiar with most components. Any Help would be very appreciated.
  • rebelkustoms
    • Sep 2015
    • 150
    Re: NS-LCD26A Picture/Screen Problem
    bumping this post, had someone tell me this may be a tab issue, anyone have any insight on that
    • CapLeaker
      Leaking Member
      • 8210
      That's not a tab issue. Looks like a timing control problem, so I would have to say t-con board.
      • rebelkustoms
        • Sep 2015
        • 150
        I have also noticed that when the screen freezes it will start to burn out white, does that sound synonymous with a bad T Conn as well?
        • CapLeaker
          Leaking Member
          • 8210
          Upload a nice picture of your t-con. While your at it, reseat the ribbon cables on the t-con too.
          • rebelkustoms
            • Sep 2015
            • 150
            here are some images, I didnt reseat the cable and reassemble yet, as you can see some winner at the factory squeezed silicone all over the other connection like they were icing a donut so I am afraid to disturb it as it may damage it.
            • rebelkustoms
              • Sep 2015
              • 150
              I reseated the cable but it did not seem to help, I am just getting a black screen now. Also I am not getting sound I put sound through several input and kept changing inputs trying to get sound although there was nothing on screen, but no sound? Could this mean main board issue?
              • CapLeaker
                Leaking Member
                • 8210
                If not the right silicone or some other goop is used, it turns either conductive, holds moisture, acidic and corrosive. Seen that many times. So be careful chipping that stuff off, as you don't want to damage nothing.
                However, since you are not getting nothing right now you would have to really check the main board first. In order to figure out if the main board is still producing video, you would have to check the LVDS cable on a oscilloscope, while turning the menu on and off (to make a visible change on the screen, so you can see it on the oscilloscope). Or get a new main board and T-con.
                • rebelkustoms
                  • Sep 2015
                  • 150
                  Well the problem resolved itself when I place the television in the trashcan. Hate to say I am beat but the unit was someone's greasy old kitchen TV and it was not nice enough to invest in. Thanks so much for your help.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Nooooooooooo !
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      The panel is a v260b1 !
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        You can fix it easily ! Watch this:
                        https://m.youtube.com/watch?v=mMo3NBGLwH0
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Don't throw it away think of E waste !
                          • Maklaud
                            • Sep 2015
                            • 56
                            • Russia
                            Bad panel
                            This is a standard defect of the matrix.
                            • Maklaud
                              • Sep 2015
                              • 56
                              • Russia
                              But troubleshoot possible.
                              • Maklaud
                                • Sep 2015
                                • 56
                                • Russia
                                Check the control points.
                                • Maklaud
                                  • Sep 2015
                                  • 56
                                  • Russia
                                  Check resistance from point to point.
                                  • CapLeaker
                                    Leaking Member
                                    • 8210
                                    That's a different issue...
                                    • rebelkustoms
                                      • Sep 2015
                                      • 150
                                      Wow, ton of responses since I tossed it out. I actually did recycle it, they take them for free in the town i live. Next time I will say I am throwing it out on the first post. Also I am sure it was not a tab issue, I checked that and I had no sound either, I am inclined to agree with capleaker here it was probably a T-conn and Main board issue, this unit was caked in grease and not worth the extra effort.
                                      • rebelkustoms
                                        • Sep 2015
                                        • 150
                                        Thanks again Capleaker for helping me through it.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • mmccomputer
                                          problem with replacing lcd screen
                                          by mmccomputer
                                          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
                                          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
                                          If anyone has any information on the subject...
                                          12-15-2024, 03:44 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
