HDMI Headscratcher Hannspree 37" YTO8
  • spottydog10
    • Mar 2014
    • 34
    • uk
    Re: HDMI Headscratcher Hannspree 37" YTO8
    Replacing the mainboard is an option although I've never done one before (but plenty of pc mainboards under me belt)
    Vince, what do you think of this as a solution?
    http://www.ebuyer.com/409852-xenta-v...nverter-xeby01
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      ive never used those in the link so cant really comment ive read though that with some the audio dosnt work maybe see if a more experienced member will comment if they have used one
      too be honest if you can change a pc mothercoard swopping a tv mainboard is easy just the wire connectors and a few screws thats it usually but if you go down that route maybe ring that company first to comfirm it will work in you tv sometimes they need the lcd panel number its on the metal tv chassis usually on a white sticker.
      • Xcat2008
        • Sep 2015
        • 25
        • Portugal
        Dumb Question.. have you tryed another HDMI Cable?
        That conversor from that Link the Output is HDMI, so if you connect your Computer from the VGA Port to that converter, then the OUTPUT HDMI to your TV.
        If your HDMI is Broken, you need the inverse correct? HDMI -> VGA NOT VGA -> HDMI
        • Xcat2008
          • Sep 2015
          • 25
          • Portugal
          But like @vinceroger69 is saying, better change the Board, it's easy to replace you just need a bit of patiente and time...
          Because if you try any adapter, you can forget any kinda of good Pictures... If you have used always HDMI, then you will feel a lot of diferences between HDMI and VGA qualities.
          The Adapter cost £6.90... Agains 30£?
          So i think the quality wins? better spend the 30£... Just my opinion.
          Regards.
          • spottydog10
            • Mar 2014
            • 34
            • uk
            Vince, I may give that a go, is there a way to find the exact model of the motherboard without taking the back off my TV again?
            It's killing me bad back...
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #26
              post nine second picture i took the number from by the tuner but you need to go of the white sticker of that board too also whilst the backs of look on the back metal tv chassis for another white sticker it should say the panel number etc take photos of the too if you can just incase we need them for future refrence its really the only safe way to get the corect board i think.
              • aliougm
                Marantz SR4003 AVR HDMI board issue, seeking for help
                by aliougm
                I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                Connection as below:
                Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                If I bypassed AVR then HDTV screen color be good.
                I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                I replaced all...
                04-30-2022, 12:21 PM
              • japlytic
                Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                by japlytic
                With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                An examination of the HDMI CEC wiring...
                07-10-2022, 09:48 PM
              • spleenharvester
                Toshiba 50UL2063DB randomly rebooting with HDMI-CEC and/or HDMI-ARC enabled
                by spleenharvester
                I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
                I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it?
                03-12-2025, 03:42 PM
              • RossMoodley1967
                LG LCD TV HDMI PORT FAULTY
                by RossMoodley1967
                LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                02-28-2024, 08:38 AM
              • RatherLoopy
                Pioneer VSX-44 receiver HDMI dropouts
                by RatherLoopy
                I have an older Pioneer receiver (VSX-44) that's been dropping the HDMI output (black screen) for a few seconds every few minutes. Setup is HTPC -> Pioneer DVD HCMI in -> Pioneer HDMI out -> Samsung TV HDMI in, all with cheap HDMI cables that have never caused trouble before..
                I initially found a lot of play in the receiver's HDMI inputs and output so I kind of squeezed them back into shape and they're making a tighter connection, but the problem persists.
                And also, often, the HDMI will drop out in exactly the same way (black screen) just as my central air...
                05-26-2023, 03:54 PM
