Panel resistor question
  • Sniper82
    • Aug 2011
    • 27
    What is the effects of not using the exact same size resistors and possibly using to big of one or small of one? I got a TV with some blown resistors on the panel board(not replaceable) that caused it to not display the image.
    Here is a pic of the other side of the panel with the good resistors so you will have a idea what I'm talking about. I would take a pic of the solder job but I know I'd be laughed at lol. The resistors that was replaced are the two(the bigger and one of the smaller) closest to the connector. But the TV is working again(for how long I don't know).
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Panel resistor question
    First of all, Sir. No one will laugh at you for attempting to solder a component on a circuit board no matter how ugly you may think it may look. We are here to help and encourage each other, so don't feel bad or anything. I myself and there are many others who will guide you on the right path.
    From same size resistor....are you speaking in terms of physical size or Ohms size? If it is physical size there is no problem as long as there is room to accommodate it. If however the OHMS size is bigger then yes there will be problems associated with the working of the circuit.
    • Sniper82
      • Aug 2011
      • 27
      Noted for the future. I know some forums people seem to get judged when they post bad soldering jobs. I was referring to size not ohms. I didn't even check the ohms. I'm not sure how I would check the ohms on the ones that are toast. Is that something where the resistor needs to be off the board to check? Or can they be tested in the circuit? I know size wise they aren't exact but are close.
      So if they aren't correct ohms they could just fry again? Honestly I kinda rushed everything because I didn't actually think it would work. I was going to pull the parts and throw the panel out but over the past couple days I said the heck with it I'll try and replace them.
        Looking at the picture, there is only resistor R116, the rest are CXX MLCC (Multi Layer Ceramic Capacitor) which usually failed as shorted circuit so it burnt up.
        • Sniper82
          • Aug 2011
          • 27
          So the single black component is a resistor and the brown are caps? Guessing thats why there is a C at the beginning of all of them and the single black one starts with a R? If so I need to edit my post lol. I'm such a newb.
            R = Resistor, usually has black body with numbers printed on top.
            C = Capacitor, the MLCC usually has light brown color.
            So what did you replace? C or R?
            • Sniper82
              • Aug 2011
              • 27
              They had a C so they are caps. Didn't know that before.
              • gica69
                Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                by gica69
                I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                Resistor shows orange range silver gold and green lines.
                Thanks in adv...
                07-21-2025, 09:49 PM
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • dragometin
                Hitachi 40HYC42
                by dragometin
                TV Model: Hitachi 40HYC42
                Power Supply: 17IPS71
                MainBoard: 17MB95M
                Panel: VES400UNDS-2D-NO3
                When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                Is there any variants on 17IPS71 power supply's?
                UART output pins 10 and 12 on scart connector:
                Code:
                12:24:04.595
                08-08-2024, 05:53 AM
              • m1ch43lzm
                Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                by m1ch43lzm
                Hi everyone
                I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                There's also an extra OTP Secu.R...
                09-06-2025, 05:47 PM
              • BustinCaps
                Dell 2007WFP resistors under white silicon blog
                by BustinCaps
                My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
                04-29-2022, 06:19 PM
