Sony bravia kdl26ml130 no remote signals pics this time
  • manstoblame
    • Jan 2011
    • 85
    Re: Sony bravia kdl26ml130 no remote signals pics this time
    Originally posted by budm
    OK, I did not see the edited reply with the Voltage reading.
    I try enlarging the image to see where this cap C320 is. Is that the cap in the OPTICAL SENSOR section where it is connected to the Q320? That section has nothing to do with the remote function. The OPTICAL SEMSOR is for automatic adjustment of the backlights in relationship to the ambient room lights.
    The remote function is int he IR section, IC401 is the IR sensor that receives the signal from the remote control. It should have 3.3vdc at the VCC pin of that IR receiver. The output signal that goes to the main board is on pin 8.
    Ok so no need to really worry about that one cool but I did test and the voltages were right at these two points
      So you need to look for the P/N of that IR sensor to find out if the middle pin (output pin) is normally high or normally LOW).
      You can put the DCV meter at the middle pin and GND, then hit the remote control button to see if the reading will show any fluctuation or nor, the correct way to test is to use the Oscilloscope.
      • CapLeaker
        Leaking Member
        • 8199
        here is a clip from norcal715 about the same problem.
        https://www.youtube.com/watch?v=imF8_DHUPmU
        • manstoblame
          • Jan 2011
          • 85
          Thanks I have viewed that before and have it downloaded somewhere guess I need to find which drive its on and re-view it
          • manstoblame
            • Jan 2011
            • 85
            OK will do and let you know my findings
            • manstoblame
              • Jan 2011
              • 85
              #26
              Oh and also because I forgot I have no power led so maybe fault lies in that area just wanted to thank you guys for the help you gave me and hey budm would it be prudent to assume that most smd beads that are the same size generally are the same resistance? Or if I might be able to remove the bead from another MB for a replacement?
                As far as the Ferrite bead inductor, as long as they show < 1 Ohms or so, they are good, the bad one will be open circuit.
                • PopsCaps
                  Sony Bravia KDL-40V2500 that will not power on
                  by PopsCaps
                  I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                  I do not hear any sound and I cannot see any backlight.
                  I have tried disconnecting every cable on each board one at a time to see if anything changes.
                  The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                  My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                  03-25-2025, 11:23 AM
                • justin35
                  Sony bravia kdl-43w755c - boot loop
                  by justin35
                  i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                  from what i read online it looks to be an emmc issue…
                  i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                  i took out the board and say an samsung 16gb emmc
                  i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                  i could try to put one instead of the 16gb one, but will it work?
                  where do i get the software from?
                  any help will be much appreciated!...
                  03-06-2024, 12:26 PM
                  Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                  Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                  10-16-2024, 05:15 AM
                • x_orange90_x
                  Sony Bravia KD-50X690E NO SOUND
                  by x_orange90_x
                  Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                  Has anyone else had this happen to their tv?
                  10-05-2024, 05:01 AM
                • pbig
                  advices for repairing Sony Bravia 32EX600 after lightning strike
                  by pbig
                  hi everyone,
                  my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                  On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                  - the 450V/150uF capacitor voltage when plugged is normal at 394V
                  - from connector CN6150 (15 poles)
                  STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                  06-28-2023, 02:43 AM
