Sony bravia kdl26ml130 no remote signals pics this time
  • manstoblame
    • Jan 2011
    • 85
    Same problem as before where as I can turn set on and change channels manually but get no action with the remote. The parts list shows what the ratings are for the resistors used arrows point to them also included is a diagram showing where things connect I guess you call it a pinout not sure anyway just wondering if the resistors can be replaced with a simple jumper wire? They're all 0 (micro Henry) as i have been told. Other ideas are needed asap if more images are need I now know how to use this Android tablet so just ask I need help please
    Re: Sony bravia kdl26ml130 no remote signals pics this time
    Are those two resistors (it is more likely supposed to be ferrite bead small value inductor), as long as it shows as <1 Ohms it is OK. So do they show as open circuit? I doubt that they are bad due to very small current flow through them.
    The 0.01uF cap, is it bad? you can use 0.01uF CERAMIC CAP.
    How about the diagram for the KEY pads connected to that connector?
    • manstoblame
      • Jan 2011
      • 85
      How about the diagram for the KEY pads connected to trust connector?
      The first image on the bottom part of the connector has three connect points for the manual key pad I believe it's ground the power initiate and key 1 pins 9,10,11 about the 0.01 uf it reads 3.3v if I understand right.
        There should be a diagram for the HMI board (control panel).
        http://www.shopjimmy.com/sony-a-1268...-hm1-board.htm
        • CapLeaker
          Leaking Member
          • 8163
          first make sure the remote is putting IR out! If that's good, then proceed to the IR board on the TV. Most of the time there is a ceramic SMD cap on the IR board that is shorted to GND, or a bad IR sensor itself.
            BTW, there is the Remote IR board that you need to check, the HMI board is the button board which you said it function but not the remote function.
            http://www.shopjimmy.com/sony-a-1268...-hm3-board.htm
            • manstoblame
              • Jan 2011
              • 85
              Budm here you go this is all I have
                OK thanks, please report the DCV reading of all 8 pins of the HM3 IR board.
                • manstoblame
                  • Jan 2011
                  • 85
                  Just a small thing but do the numbers indicated on smd components indicate value like say for instance C322 doesn't imply (capacitor 32 and 2 o's =3200) ?
                    That is just he designator number, for example R1, R2, R3, or C1, C2, ETC.
                    • manstoblame
                      • Jan 2011
                      • 85
                      Looking at the conductor side CN301 from upper to lower of connector
                      -3.3
                      -0.13
                      -0.13
                      -3.3
                      -0.00
                      -0.00
                      -3.3
                      -0.00
                      On the conductor side I get 0.00 at C320 and i'm thinking it should read the 3.3 ?
                      • manstoblame
                        • Jan 2011
                        • 85
                        OK thanks
                        • manstoblame
                          • Jan 2011
                          • 85
                          cap has no reading powered up has to be bad says on surface the number 47 and that its 16v what can be used to replace it?
                            Before replacing anything we need to find out what DCV you have on those 8 pins for the IR board that I request. No Voltage on the cap does not mean it is the bad cap.
                            • manstoblame
                              • Jan 2011
                              • 85
                              Above budm are those the voltages we need
                                OK, I did not see the edited reply with the Voltage reading.
                                I try enlarging the image to see where this cap C320 is. Is that the cap in the OPTICAL SENSOR section where it is connected to the Q320? That section has nothing to do with the remote function. The OPTICAL SEMSOR is for automatic adjustment of the backlights in relationship to the ambient room lights.
                                The remote function is int he IR section, IC401 is the IR sensor that receives the signal from the remote control. It should have 3.3vdc at the VCC pin of that IR receiver. The output signal that goes to the main board is on pin 8.
                                • CapLeaker
                                  Leaking Member
                                  • 8163
                                  if you have a oscilloscope, you can hook up the probe to the out put pin of the IR or on Pin 8 of the connector and check for pulses to see if it receives IR. On the conductor side of the HM3 board, IC 401 is mounted on the other side on the left (see your picture), the middle pin, there are 2 chip caps, see if they are shorted to GND or not.
                                  • dick_barton
                                    • Aug 2015
                                    • 6643
                                    • Wales
                                    A quick test which may work for you for testing your remote and therefor rule it out as possibly faulty is to put your mobile phone into camera mode and point it at the IR end of your remote. Pressing a button should show the led glowing while button is depressed.
                                    • manstoblame
                                      • Jan 2011
                                      • 85
                                      Thanks that's been done and the remote flash is present
                                      • manstoblame
                                        • Jan 2011
                                        • 85
                                        tested those and they measured 3.3 note that all caps and beads are not being used on this particular set just the ones I inquire about others are for different models so as not to confuse anyone my fault for not mentioning it earlier
                                        • PopsCaps
                                          Sony Bravia KDL-40V2500 that will not power on
                                          by PopsCaps
                                          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                          I do not hear any sound and I cannot see any backlight.
                                          I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                          03-25-2025, 11:23 AM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                                          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                                          10-16-2024, 05:15 AM
                                        • x_orange90_x
                                          Sony Bravia KD-50X690E NO SOUND
                                          by x_orange90_x
                                          Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                          Has anyone else had this happen to their tv?
                                          10-05-2024, 05:01 AM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
