Sony KDL-32BX300 horizonal lines flickering
  • nelsonba44
    • Aug 2015
    • 17
    I have looked for threads but didn't see any. If repeat sorry. These just started. opened back and nothing jumped out. checked cables and tape buy unhooking and hooking back. Here are pics and I am trying to figure out how to sent a short video of screen. Any help will be appreciated. Thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony KDL-32BX300 horizonal lines flickering
    Panel fault caused by Tab Bond defect.
    • nelsonba44
      • Aug 2015
      • 17
      Thanks, here is a pic of screen.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Now that I've seen the screen, perhaps you could try a T-CON Bd replacement if it is cost effective.
        • nelsonba44
          • Aug 2015
          • 17
          I am not an expert and appreciate all the help. But I don't see a T-CON bd. Is it part of another? the only other board besides first I sent is the one I am sending now. It looks like it is hard wired to screen across top. Thanks again.
            LCD panel with integrated T-CON board. You are also getting a bunch of multiple repeated images.
            I would say you have bad panel.
            • nelsonba44
              • Aug 2015
              • 17
              Thanks for all help. Can't seem to find that so guess will trash it and move on.
              • reessi
                ACER BM320 Monitor - Horizonal Flickering Lines After a While
                by reessi
                The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                They are black on the right and gradually fade to nothing on the far left.
                They start either after 5 mins or up to 2 hours after so annoying for testing.
                They flicker continuously very fast! With a slight pause milli-second every second.
                Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                I tested each half by removing the first the left flex from...
                06-03-2025, 09:58 AM
              • visionbluedemon
                Help. Sony kd-65x85dj vertical lines
                by visionbluedemon
                First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                tried blocking LC lines too, but same results
                is it lcd panel issue or tcon board issue?...
                07-25-2025, 04:56 AM
              • arctor
                LG 55uh661v flickering images and lines
                by arctor
                Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                06-16-2025, 11:57 AM
              • ggil44
                Sony XBR-65X750D Horizontal lines bottom of screen
                by ggil44
                Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                05-30-2023, 07:51 PM
              • Chrissygizmo
                Sony KD-55XG9505 lines on screen problem
                by Chrissygizmo
                Hello again everyone,
                This is my latest mission, to try getting this Sony tv back to normal working order…
                I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                02-19-2025, 11:31 AM
