AFTV Dies Tonight
  • mmartell
    • Oct 2013
    • 3189
    AFTV Dies Tonight
    "Uhhh, dad.. there's something wrong with the tv!"
    Not exactly the tv, but the Amazon Fire TV. It was sitting on "Update Failed, please wait and the unit will reboot shortly or unplug for three seconds and it should boot normally". But, no it doesn't. Storms rolled in and I guess it picked a bad time to power off...
    So I plugged in a usb keyboard and got to the stock recovery. This gives me four options:
    Reboot now
    Apply update from ADB
    Wipe data/factory reset
    Wipe cache partition
    Factory reset went through its steps but rebooted into the exact same place I was in before.
    Is it safe or even necessary to wipe cache partition ? I've read what seems like the best option isn't available as its basically disabled (update from adb).
    Anyone have ideas or is this thing bricked ?
  • mmartell
    • Oct 2013
    • 3189
    Re: AFTV Dies Tonight
    And thats supposed to be AFTV DIED Tonight but can't change the title I guess.
    • mmartell
      • Oct 2013
      • 3189
      For those that don't know this box is essentially an Android. Surely some of you must be familiar enough with Recovery mode to give some advice ?
        • 31051
        ADB gives away the fact that it's android.
        do you run windows, or Linux - and can you download a flash file for it?
        WARNING - you cant flash down - version must be the same or higher.
        if you can get the flash, i'll upload the adb & fastboot utils for the pc side.
        oh yea, to answer your question - feel free to wipe the Dalvik cache - it's the config files used by the app's
        it's common to wipe it after upgrades anyway to avoid strange shit happening.
        • mmartell
          • Oct 2013
          • 3189
          I downloaded the latest flash but it's in a .bin format ? Not sure what format the aftv is expecting because I've only ever used .zip and .apk of course.
          Windows. I can find these utilities need to find a A-A usb cable.
            • 31051
            fastboot can probably flash the bin.
            • mmartell
              • Oct 2013
              • 3189
              Ok will try tonight. Is .bin flashable or should I zip it up maybe ?
                • 31051
                fastboot -h says:
                usage: fastboot [ <option> ] <command>
                commands:
                update <filename> reflash device from update.zip
                flashall flash boot + recovery + system
                flash <partition> [ <filename> ] write a file to a flash partition
                erase <partition> erase a flash partition
                getvar <variable> display a bootloader variable
                boot <kernel> [ <ramdisk> ] download and boot kernel
                flash:raw boot <kernel> [ <ramdisk> ] create bootimage and flash it
                devices list all connected devices
                reboot reboot device normally
                reboot-bootloader reboot device into bootloader
                options:
                -w erase userdata and cache
                -s <serial number> specify device serial number
                -p <product> specify product name
                -c <cmdline> override kernel commandline
                -i <vendor id> specify a custom USB vendor id
                btw, adb says
                adb reboot [bootloader|recovery] - reboots the device, optionally into the bootloader or recovery program
                did you try the recovery menu?
                • mmartell
                  • Oct 2013
                  • 3189
                  Can't try tonight as I didn't have time to procure a usb cable.
                  Yes I can get into the Recovery Menu as stated in my first post; a Factory Restore did nothing and I can't yet connect to the device as I am only connected to it over ethernet.
                  Unless there's a way to do this over ethernet ?
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    nonsense!
                    Follow the white rabbit.
                      • 31051
                      it's not nonsense, it was recently implemented because people found a way to root the older firmware.
                      btw, lots of stuff here:
                      http://forum.xda-developers.com/fire-tv
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        never seen a device able to do that..... usually just flash the old bootloader and your good!
                        • mmartell
                          • Oct 2013
                          • 3189
                          ok have everything connected and need advice. How do I connect to the aftv ?
                            • 31051
                            boot the device and run adb or fastboot on the pc - they should recognise it.
                            that's the first thing.
                            • mmartell
                              • Oct 2013
                              • 3189
                              with what switches ?
                              • mmartell
                                • Oct 2013
                                • 3189
                                If I do
                                fastboot usb
                                I get..
                                <waiting for device>
                                and it keeps waiting lol
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  I'm pretty sure I'm not connecting to the aftv and I'm not sure if it's even possible ??
                                    • 31051
                                    it knows it's usb, just try fastboot -h.
                                    on linux it is anyway, on windows i suspect it would be /h
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      I just get <waiting for device>
                                      When it boots I hear a Windows sound that I had to look up. First sound is "Device Failed to Connect" followed about 15 seconds later by "Device Disconnect".
                                      Driver problem ?
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Any suggestions here or is this one toast ?
                                        • brconta
                                          MacBook A1502 EMC 2835 820-4924-A dies when installing firmware update
                                          by brconta
                                          I have a macbook Early 2015 A1502 EMC 2835 820-4924-A.
                                          Whenever I try to update the system the device dies after reboot. It only comes back to life if the battery is disconnected, and then connected again (energy drain). Apparently the firmware update fails.
                                          I can install High Sierra normally, but I can't install a newer one.
                                          I can use a disk with a newer system that was installed on another machine.
                                          I've already tested another chip and another bios file, but no effect.
                                          Boot ROM: MBP121.0177.B00
                                          SMC: 2.28f7
                                          I've tried the procedure...
                                          11-02-2021, 04:47 PM
                                        • TheUser
                                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                          by TheUser
                                          Hello to everyone ,
                                          This is my first post here, and i would like to share with you a small story in case you can help me.
                                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                          02-10-2024, 02:07 PM
                                        • lordgeny
                                          z490-f gaming bricked after bios update
                                          by lordgeny
                                          I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
                                          11-02-2023, 09:03 AM
                                        • iMuhtaseb
                                          A1706 2017 critical update
                                          by iMuhtaseb
                                          this board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
                                          we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
                                          One weird symptom is it takes too long to power on and show the Apple logo for some reason..
                                          I've taken a look into the MLB and noticed tiny liquid around Q3100.. its...
                                          08-13-2024, 08:41 AM
                                        • al3m0di
                                          Update bios EFCN58WW to EFCN59WW
                                          by al3m0di
                                          Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                                          I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                                          The BIOS version is EFCN58WW.
                                          When I turn on the device, it displays the message:
                                          "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                                          The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                                          I've tried
                                          07-29-2024, 10:32 AM
