Samsung LN46B630 lines all over
  • keats11
    • Nov 2012
    • 88
    I got this TV for free, but when I brought it home has horizontal lines all over, with what looks like an overlay or vertical bands in select areas. I haven't opened it yet, but would like to save the trouble if indeed someone has seen this before and can be confirmed as a panel issue.
  • ngth82
    • Jul 2015
    • 541
    Re: Samsung LN46B630 lines all over
    Sorry to bump an old thread... Looks like keats11 received no replies. I'm curious if you received any help on this or if you ended up dumping the TV.
    Interestingly enough, I just picked up an LN46B630N1F yesterday (8/11/2017). The vertical and horizontal line locations appear to be the same as the OP after the panel warms up a little bit. The vertical lines appear where there is TEXT - not necessarily where there is graphic, and spans both halves of the screen. The horizontal lines appear to be two horizontal lines on, followed by one horizontal line skipped.
    However, when i plug in a source (chromecast in this case) and let it warm up, i see the vertical lines across a good portion of the screen w/ and w/o the menu displayed.
    I've tried the following thus far:
    1. Disconnect/reconnect the LVDS cable from both ends. Reseating it didn't help.
      [*Disconnect/reconnect the T-CON ribbon cables to the panel - no change.
    2. Spray down the T-Con with a spray can - it doesn't appear to change anything.
    Searching online, looks like the other possibilities are:
    1. a bad T-Con
    2. a bad main board
    3. a bad panel / tab bonds
    I'll have to get pictures of the back tomorrow. The TV is not close by right now... Any suggestions for now would be fantastic, but I know... no help until clear pictures of the boards are posted
    Do samsung TVs have a debug jumper / method to enable a panel test mode? (Similar to the LG test pattern jumper, or the Panasonic plasma display test via removing the LVDS cable).
    Thanks,
    Thomas
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • ngth82
      • Jul 2015
      • 541
      D'oh! I just noticed that i have a crack in the upper right corner of this panel. In my estimation, the TV isn't worth salvaging now. But I would still be curious about these lines in case I (or someone else) comes across TVs like this...
      -Thomas
      • dskall
        • Oct 2016
        • 2905
        • usa
        Well to me it doesn't look like it affects the osd which usually means it's not panel defect. But just my opinion
        • geeforce
          • Oct 2017
          • 87
          This is exactly what my samsung tv was doing (LN46B640). Eventually went black to just the horizontal lines... not sure if I should just trash it or try to find a tcon for it.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4546
            • Italy - Milan
            Hi, have you checked if there's a crack also you? If not, anyway this is a common problem in Samsung panels, also LED ones, please do this test, locate testpoints on t-con CPV1,2 or CKV1,2, try to insulate them on the flat cables to where them goes, using very slim adhesive tape strips, first Cpv1, then post result, then CPV2, attention that each of them goes on both connectors so it must be masked on both.
            • x_orange90_x
              Samsung UN46C8000XFXZA vertical bars/horizontal lines
              by x_orange90_x
              I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
              The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
              09-04-2023, 12:09 PM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              08-12-2025, 04:19 AM
            • noipi
              samsung Oled 65 Horizontal Lines and Flicker
              by noipi
              I have samsung 65", i bought it last january 2025 2nd hand, and last month got this problem, flickering with horizontal lines. any inputs if this is Motherboard replacement or the LCD tcon, can someone help me what to do, i saw in YT, someone says that to cover the flex connector of the unit. Sorry for my english i am asian. i include the video so someone can help me out. thanks...
              10-14-2025, 02:11 AM
            • Ihandyrepair
              Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
              by Ihandyrepair
              Hi guys
              I just started fixing 4k TV few months ago. so I am still learning a lot
              I got this tv from friend complaint is ghosting or horizontal lines on image.
              never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
              then it started to show the ghosting white image.
              I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
              it has 3 thin small boards at the bottom of the...
              12-05-2022, 04:18 PM
            • Stanley1843
              by Stanley1843
              06-29-2024, 11:54 AM
