I got this TV for free, but when I brought it home has horizontal lines all over, with what looks like an overlay or vertical bands in select areas. I haven't opened it yet, but would like to save the trouble if indeed someone has seen this before and can be confirmed as a panel issue.
Samsung LN46B630 lines all over
Re: Samsung LN46B630 lines all over
Sorry to bump an old thread... Looks like keats11 received no replies. I'm curious if you received any help on this or if you ended up dumping the TV.
Interestingly enough, I just picked up an LN46B630N1F yesterday (8/11/2017). The vertical and horizontal line locations appear to be the same as the OP after the panel warms up a little bit. The vertical lines appear where there is TEXT - not necessarily where there is graphic, and spans both halves of the screen. The horizontal lines appear to be two horizontal lines on, followed by one horizontal line skipped.
However, when i plug in a source (chromecast in this case) and let it warm up, i see the vertical lines across a good portion of the screen w/ and w/o the menu displayed.
I've tried the following thus far:
- Disconnect/reconnect the LVDS cable from both ends. Reseating it didn't help.
[*Disconnect/reconnect the T-CON ribbon cables to the panel - no change. - Spray down the T-Con with a spray can - it doesn't appear to change anything.
Searching online, looks like the other possibilities are:
1. a bad T-Con
2. a bad main board
3. a bad panel / tab bonds
I'll have to get pictures of the back tomorrow. The TV is not close by right now... Any suggestions for now would be fantastic, but I know... no help until clear pictures of the boards are posted
Do samsung TVs have a debug jumper / method to enable a panel test mode? (Similar to the LG test pattern jumper, or the Panasonic plasma display test via removing the LVDS cable).
Thanks,
Thomas-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun. - Disconnect/reconnect the LVDS cable from both ends. Reseating it didn't help.
D'oh! I just noticed that i have a crack in the upper right corner of this panel. In my estimation, the TV isn't worth salvaging now. But I would still be curious about these lines in case I (or someone else) comes across TVs like this...-Thomas
I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.Comment
Hi, have you checked if there's a crack also you? If not, anyway this is a common problem in Samsung panels, also LED ones, please do this test, locate testpoints on t-con CPV1,2 or CKV1,2, try to insulate them on the flat cables to where them goes, using very slim adhesive tape strips, first Cpv1, then post result, then CPV2, attention that each of them goes on both connectors so it must be masked on both.Comment
by x_orange90_xI posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went... -
by IhandyrepairHi guys
I just started fixing 4k TV few months ago. so I am still learning a lot
I got this tv from friend complaint is ghosting or horizontal lines on image.
never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
then it started to show the ghosting white image.
I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
it has 3 thin small boards at the bottom of the... -
by RubenlilyHello,
First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
I'm no expert but I've done the tape... -
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by noisykid5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
- Loading...
