Philips 42PFL8404H works and then doesn't
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Just finished testing the TV (connected to the PC via VGA) and the symptoms are the following:
    the TV worked for about 5 minutes then the picture cut out with an audible bang from the speakers. After maybe 15 seconds the picture came back. However, 5 minutes later the same thing happened all over again. Finally, it stayed on for about 15 minutes until I manually turned it off via remote.
    However, now it refuses to display output from the PC or anything else for that matter. It shows the PHILIPS splash screen then goes black and the white LED is blinking. After a while it goes to solid red and stays that way.
    I inspected the power supply and all caps look fine but could be dry?
    What should I look for?
    Cheers
  • Half-Saint
    • Jan 2010
    • 213
    • Slovenia
    Re: Philips 42PFL8404H works and then doesn't
    Find attached pictures of both boards.
    • CapLeaker
      Leaking Member
      • 8326
      a new main board maybe?
      • simwalsh
        Philips 47PFL4606 Powers on, works normal then powers off after a minute
        by simwalsh
        I am new to this forum and have searched for some answers with problems similar to mine.
        Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
        It sounds like a power supply issue?
        I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
        12-04-2023, 04:03 AM
      • CapLeaker
        Dell ATX PSU won’t start, but forcing it works fine?
        by CapLeaker
        Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
        Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
        10-28-2024, 06:59 PM
      • alro7779
        Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
        by alro7779
        Hello, guys!
        The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
        09-14-2025, 12:25 AM
      • G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo
        by G33RT
        Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
        It does power up when pressing the power button.
        I already try the power button while plugin the plug with no result.
        Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
        Could this be an PSU or eMMC issue ?
        07-19-2025, 03:43 AM
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        🛠 Original Issue
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
