rca rlded5078a-d
  • dpcookson
    • Sep 2015
    • 11
    Re: rca rlded5078a-d
    Sorry, don't mean to hijack this thread but I am curious if the OP solved their problem as I am experiencing the same issues with an identical board; my voltages to the LEDs read .689v
    • CapLeaker
      Leaking Member
      • 8188
      Not that I know of.
      However after your second or third post, you are able to do your own thread. You can use this one as a guide and report what you find.
      • dpcookson
        • Sep 2015
        • 11
        Bear with me please, I am by no means an expert here, nor even a seasoned novice, lol.
        Please correct me if i am mistaken,
        After following the board layout according to SJ's pictures I have found that C10F may be the culprit as I have 358 VDC on the "south" side of the (cap?) but only 0.398 VDC on the "north" side.
        Suspect device "C10F" is located below T2F (transformer at top of picture) on "HOT" side of board.
        http://www.shopjimmy.com/proscan-ay1...upply-unit.htm
          C10F is the DC Blocking/Coupling cap and part of the Half-bridge drive circuit, one one of the cap is connected to the Primary side circuit circuit GND, anothe end is connected to one end of the primary xformer T2F. So one end of the cap will be 0V since it is connected to the primary circuit GND.
          If the cap is bad (need to check its capacitance, common failure of that cap will be the lost of the capacitance) then there will be no output for the LEDs.
          • dpcookson
            • Sep 2015
            • 11
            22.3 nf
            Seems this cap is right on spec from what I have researched on it. Guess it's back to the drawing board, lol. Thanks for the help, I'm pretty new to this stuff so I appreciate any info I can get.
              There is that 18-pin SMD IC1F that drives the Gate Drive transformer T1F, if you can get the spec sheet to get the pin out to find out if that IC is working or not.
              • dpcookson
                • Sep 2015
                • 11
                Okay, thanks for the suggestion. I'll take a look hopefully tomorrow night and see what I can find.
                • smuddge
                  • Feb 2012
                  • 96
                  no I haven't solved this yet. was away for a few days. I am looking forward to hearing if SMD IC1F is the problem.
                  • dpcookson
                    • Sep 2015
                    • 11
                    IC1F is a BD9211F
                    I don't honestly know what I'm looking for to test this component so I took some voltage readings with my DMM while the board was wired up and powered on.
                    Pin # = VDC
                    1 = 11.14
                    2 = 4.15
                    3 = 0.001
                    4 = 1.465
                    5 = 0.023
                    6 = 0.020
                    7 = 0.001
                    8 = 0.096
                    9 = 0.001
                    10 = 3.495
                    11 = 0.001
                    12 = 0.001
                    13 = 0.003
                    14 = 0.002
                    15 = 0.025
                    16 = 0.001
                    17 = 0.001
                    18 = 0.001
                    I'm not sure if this is useful, any direction from here is appreciated though, thanks.
                      Well, looking at the spec sheet, you do have 11VDC for the VCC pin 1 to run the IC, you also have >2vdc for the STB PIN 2 to turn on the IC.
                      There is not activity at the drive output pin 17, pin 18.
                      I do not understand the definition of the CP PIN 9 CP (timer latch detect voltage), 2vdc is the typical when it latch into shutdown or when it is running.
                      There is no application notes circuit to see how it is used.
                      I need to do more research on this IC, so far it looks like there is no activity from this IC.
                      May be you can monitor pin 9 when TV is OFF and when TV power switch is activated to see if it changes state.
                      • dpcookson
                        • Sep 2015
                        • 11
                        Thank you budm for your time so far. I monitored the voltage on pin 9 while powering the unit on and off a couple times but there was no change.
                        • 2cams70
                          • Sep 2015
                          • 3
                          Hi Guys,
                          Greetings from Australia. Found an Aldi Bauhn ATV-50FHD3 TV courtesy of the kerbside shopping mall that seems to be a clone of this TV. Has the same issue. Have been right through the AY128D PCB checking MOSFETS replacing IC's (including one mentioned) and no success. I am coming to the conclusion that there is nothing wrong with the power board and that the problem lies with a faulty LED in the display causing the board to go into protection mode - this issue was found by another badcaps member somewhere in relation to another type of TV (search under "badcaps" and the LED driver IC type description). Will be a while until I get a chance to pull the screen apart to check though - any thoughts from you guys?
                          • dpcookson
                            • Sep 2015
                            • 11
                            It just so happens that I already have mine tore down that far, I could test my strips if anyone can point me in the right direction.
                              I would expect there will be the output to the LED strop first THEN the fault detection circuit kicks in, so it is either that the meter is too slow to show any Voltage spike at the LED's connector before it drops down to 0V as reported.
                              • CapLeaker
                                Leaking Member
                                • 8188
                                If the problem is indeed a bad LED, I expect the LED driver circuit to come on and ramp up the voltage, then it senses an error, protection circuit kicks in and the voltage goes down. If there is no output at all on the LED driver and BLon is present, there has to be a problem somewhere on the board, or a dead short in the LED wiring. So to rule out the latter part, disconnect the LED's from the PSU and measure again.
                                • dpcookson
                                  • Sep 2015
                                  • 11
                                  Okay, measured the LED connector during power cycling and got -394V (why is this negative?) but it dropped out quickly like you guys said it might.
                                  If this is a sign of a bad LED or more how do I check them? I tried setting my DMM to diode to test a few random ones but didn't seem to get anything.
                                  • 2cams70
                                    • Sep 2015
                                    • 3
                                    Hi dpcookson, would you be able to post a couple of pics of the screen LED's seeing as you have yours already in bits. Does this TV have edge or backlight LED's? Would appreciate it as I haven't dismantled mine that far yet - only gone as far as the PCB's.
                                    • dpcookson
                                      • Sep 2015
                                      • 11
                                      It is full backlight, there are 5 strips of 14 LEDs.
                                      note: The TV is "upside-down" in the pics
                                      • CapLeaker
                                        Leaking Member
                                        • 8188
                                        That depends on where you had your GND lead from your DMM connected to during the measurement.
                                        You can check every diode with your DMM set in diode mode and look for an open or dead short.
                                        • dpcookson
                                          • Sep 2015
                                          • 11
                                          GND lead of the DMM was on the GND circuit of the board. On power up, the voltage at the LED connector started at +0.69V then about 3-4 seconds later it "dropped" to -394V, then returned to +0.69V. With the unit powered off there is 0V at the LED connector. I suppose it doesn't matter which side of the LED circuit is positive or negative, as long as the LEDs polarity matches.
                                          I realize that an LED is a diode but maybe I was checking them wrong with my meter, if you look at my previous posted pictures, I was connecting my leads to each copper "dot" on both sides of an LED. I tried reversing the leads but came up with an open circuit on the few random LEDs I tested, makes me think I am doing something wrong, that or every LED is "NFG".
                                          • Joel Ohana
                                            Lenovo IdeaPad 3 15IAU7 that suffered water damage
                                            by Joel Ohana
                                            I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                                            Symptoms:
                                            • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                                            • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                                            What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                                            03-06-2025, 11:25 AM
                                          • azozexd
                                            Need help hp 725 g3 liquid damage
                                            by azozexd
                                            Hello freind i have hp elitebook 725 g3 White liquide damage
                                            after cleaning the board i find à damage resistor white no value i test it not reading in multimeter
                                            could some one tell me the value of this resistor
                                            Thank you...
                                            12-15-2024, 06:01 PM
                                          • mon2
                                            A1466 Macbook Air (Liquid damage repair)
                                            by mon2
                                            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                            Macbook AIR Model A1466 Diagnostic 09-01-2021
                                            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                            Problems & Resolutions
                                            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                            09-01-2021, 09:31 AM
                                          • rtstorm
                                            HP EliteBook 840 G8 water damage - identify component
                                            by rtstorm
                                            Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
                                            SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
                                            Here is schematics + boardview...
                                            09-18-2024, 05:36 PM
                                          • Jenzo
                                            MacBook A1989 overheating after liquid damage
                                            by Jenzo
                                            Hey everyone,
                                            Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
                                            I can't figure out how...
                                            05-13-2023, 07:58 AM
