Samsung LN46B550K1F Quick Blink
  • CraigR
    • Dec 2013
    • 965
    I am beginning to loose my confidence in repairs since I can't get my last 2 TV's working and now here is a third. Samsung LN46B550K1F Plug it in and I get a the start up sound then a split second of backlight This happens 4 times then just nothing. I do hear the solenoid click with every flash of the backlight and I can see the video behind during the flash. I did put a meter on the inverter board and compared readings. (not sure I did that right either) then I thought bad bulb?? so I took apart down to the bulbs and had to take a video and go frame by frame in a video editor to find the flash. (pic attached) So if anybody can "hold my hand" a little it would be appreciated!
  • CapLeaker
    Leaking Member
    • 8327
    Re: Samsung LN46B550K1F Quick Blink
    Check the inverter board for cold solder joints, bad diodes and transformers. In this case you also have to check the PSU as there is HV generated for the inverter board (See those 2 big black transformers?).
    • CraigR
      • Dec 2013
      • 965
      No bad solder joints and did a compare between transformers and seemed ok. How can I check the big transformers?
      • CapLeaker
        Leaking Member
        • 8327
        transformer ring tester
        • CraigR
          • Dec 2013
          • 965
          Ok, never heard of that. Where can I buy one?
          • CapLeaker
            Leaking Member
            • 8327
            Did you check the diodes on the inverter board too?
            For curiosity sake, put your model into SJ and see if they have a "repair kit" usually there is a list of components and location they replace. If there is something on the PSU, I'd be checking those locations.
            • CapLeaker
              Leaking Member
              • 8327
              On flea-bay I saw some
              • CraigR
                • Dec 2013
                • 965
                Yes. I see a big repair kit for the PCU but that's it. Still want a tester if you can tell me where to get.
                • CapLeaker
                  Leaking Member
                  • 8327
                  apparently that kit also fixes backlight problem. So check the parts that would go into the backlight circuit.
                  Anatek makes for instance a ring tester, just search in fleabay.
                  • CraigR
                    • Dec 2013
                    • 965
                    is this it?? http://www.ebay.com/itm/AnaTek-Blue-...item2a2ea6e1dd
                    • CapLeaker
                      Leaking Member
                      • 8327
                      Yes, that is one for example. Of course there are others too...
                      • CraigR
                        • Dec 2013
                        • 965
                        Ok, I will order one up Now how do I use it LOL Got a quick tutorial?
                        • CapLeaker
                          Leaking Member
                          • 8327
                          There should be something coming with it.
                          • CraigR
                            • Dec 2013
                            • 965
                            Replaced the power board and that fixed the problem.
                            • howardc64
                              Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                              by howardc64
                              • Prior owner tried a replacement main board. No difference.
                              • Samsung 2x red blinking standby LED = panel fault
                              • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                              • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                              • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                              07-19-2025, 10:54 PM
                            • Deeloc
                              How to flash SSD 1tb WALRAM controller SM2259XT2G flash samsung NAND V6
                              by Deeloc
                              I have a 1tb WALRAM SSD (Photo)
                              Controller SM2259XT2G (photo)
                              Samsung memory (photo):
                              Part Number K9DVGB8J1B DCK0
                              Name V-NAND V6
                              Type TLC
                              The SSD itself is detected as 1gb, but is not initialized.
                              There is a Sata to USB adapter
                              A lot of SMI MPTool, did not flash it. compare flash fail (17)
                              K9DVGB8J1B is not listed anywhere
                              What to flash?​...
                              06-05-2024, 08:32 AM
                            • ChristianBr01
                              LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                              by ChristianBr01
                              I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                              The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                              What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                              04-23-2025, 01:48 AM
                            • KYBOSH
                              Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                              by KYBOSH
                              I picked this one up today.
                              Previous owner says no signs of life.
                              TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                              Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                              The TV model is QN65LS03BAFXZA - version: CB06
                              The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                              I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                              Will keep you all...
                              04-05-2025, 08:32 PM
                            • ekozeko333
                              [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                              by ekozeko333
                              I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                              🔥 The Problem Started After Suspected ESD/PD Fault
                              I experienced a power issue or ESD event through a USB-C charger
                              After that, the NX20P5090 power switch was visibly burned and was replaced
                              Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                              🧠 What I’ve Done So Far
                              Flashed...
                              06-21-2025, 02:48 AM
