Vizio M470NV - No Picture, but has sound backlight
  • jortgonfreit
    • Aug 2015
    • 12
    I own a Vizio 47" M470NV that just decided to stop displaying anything on its screen.
    There is still sound and it still has a backlight, but just no picture. I did take a flashlight to it just to be sure and no dice. It doesn't display anything when booting up, no logo, nothing. Also, when I change the volume or channel that display doesn't show up either.
    I've read conflicting things across the internet and this site on this subject. Some say it could be the power board, others say it could be the mainboard. Has anyone had a similar experience with a Vizio TV?
    I have not opened up the TV yet to look for any scorch marks or blown or swollen capacitors. I'm willing to take a multimeter to the boards to check it out, but does anyone have any idea where to start and what things I should measure first?
  • CapLeaker
    Leaking Member
    • 8326
    Re: Vizio M470NV - No Picture, but has sound backlight
    check out the tcon. since there is sound etc. maybe you want to borrow a oscilloscope and check out the LVDS signal. Then you know fast what's going on
    • jortgonfreit
      • Aug 2015
      • 12
      I don't think there is a T-Con board. I looked and found nothing.
      I only see a Main Board, Daughter Board, and Power Board. There's also a Wifi Board, a board for the Infrared sensor, and another board for the power button.
      I've attached the main, daughter, and power boards. The main board has the wifi board attached to it at the top. All of these pictures are rotated so that the bottom of the picture is the part of the board facing the floor.
      After taking a look at all of the boards I don't see any capacitors that are bulging or leaking. There are also no black spots on the board either.
      What are some good next steps for troubleshooting this problem? I do not think I'll be able to get access to an oscilloscope.
      • CapLeaker
        Leaking Member
        • 8326
        Another pic of the whole back of the tv with everything connected, please.
        • jortgonfreit
          • Aug 2015
          • 12
          Here you are.
          You can see at the very bottom of the television what appears to be the infrared sensor board. And the very right of the television is the board for the power button.
          • jortgonfreit
            • Aug 2015
            • 12
            That board at the bottom is a bluetooth board.
            • CapLeaker
              Leaking Member
              • 8326
              See the board in the middle of the tv with the big black heatsink? That's the t-con. With all the boards connected like it should be, check if the t-con gets any power (5V) from the PSU. Check fuses TF1 and F4 on the t-con.
              • jortgonfreit
                • Aug 2015
                • 12
                I'll try that when I purchase a multimeter today and let you know the results.
                I'm a bit confused why you call it a t-con board and it's called a daughter board here: http://www.shopjimmy.com/vizio-3647-...hter-board.htm
                • TVRepairNoobie
                  • Feb 2015
                  • 158
                  Possibly the board has the T-CON chip on it. so, most would call it that.
                  • jortgonfreit
                    • Aug 2015
                    • 12
                    When the TV is both on and off fuse f4 is around 5.14 volts.
                    When the TV is on fuse tf1 is 12 volts. It's zero when it's off.
                    • CapLeaker
                      Leaking Member
                      • 8326
                      both sides of the fuses?
                      • jortgonfreit
                        • Aug 2015
                        • 12
                        Yes. Both sides.
                        • jortgonfreit
                          • Aug 2015
                          • 12
                          I just decided to buy a new Daughter (or TCon) board off eBay. It was only $40 and if that fixes it then it was worth it.
                          • jortgonfreit
                            • Aug 2015
                            • 12
                            So I swapped out the T-Con (or Daughter) board and still have the same issue.
                            What is the likely culprit at this point? I've got two options here. The main board or the power board.
                            • jetadm123
                              • 2169
                              Try checking the 3 fuses on mainboard. I can't read the part number of U24 in the lower right corner of the mainboard. It might be a voltage regulator. Check it's output voltage.
                              • CapLeaker
                                Leaking Member
                                • 8326
                                borrow a 100Mhz oscilloscope and check the LVDS. This makes sure that either Video is or isn't coming out of the main board.
                                • jortgonfreit
                                  • Aug 2015
                                  • 12
                                  Say I get an oscilloscope to measure the LVDS signal. What exactly am I looking for and how would I measure this signal?
                                  • CapLeaker
                                    Leaking Member
                                    • 8326
                                    What you do is to turn the TV on and probe the LVDS connector on the mainboard. Not on all pins is the LVDS carried, but you will find it no problem. Now take the remote and turn the menu on and off all the time while probing the LVDS connector and if the mainboard works, you will some pins on the connector that will change the signal on the LVDS each time you press the menu on and off.
                                    https://www.youtube.com/watch?v=WeYFzugvH4c
                                    • jortgonfreit
                                      • Aug 2015
                                      • 12
                                      Thanks for your help. I've located a place in my city that offers access to oscilloscopes. I'll test this out on Saturday.
                                      If I am able to determine that this is the issue is there any way to fix it beyond replacing the mainboard entirely?
                                      • CapLeaker
                                        Leaking Member
                                        • 8326
                                        If you find that the signal changes each time you turn the menu on and off, that main board would be o.k. and the trouble lies further down the chain. Then do the same thing on the T-con board.
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
