My mother's HDTV got hit by a power surge during a thunderstorm. The symptom of the set is that it plays fine for about 4 to 5 minutes then cuts off. Stays off (no sound or pix) then after about a minute or so, the set cuts back on and plays fine...then repeats the on/off scenario over and over. The TV is 3+ hours away...Was trying to get a grasp on what to check first. I worked on TVs for over 20 years when they had CRTs and flyback transformers. I have replaced capacitors and a shorted diode in a few of my LCD/LED sets, as well. Any thoughts? Point me in the correct if this isn't the right forum in which to post! Thanks!!
Samsung LN40E550
Re: Samsung LN40E550
I have more info....printed on the owners manual is 'SERIES 5 550'.
Sounds as if a componet on the power supply board is heating up, shutting
the set down, cooling off & the set returns to the ON mode. Am I off base
here or should I wait until I get the set n front of me?? -
I have FINALLY gotten the TV. The set played for about 30 minutes. I turned the set off to remove the probe I had attached to the HOT ground and went to turn on the set, it would not turn on. The set can only be controlled from the remote. Luckily, I have a Samsung TV that this remote will control. I checked the usual...fuses and such....no luck. It appears that this set has a BN44-00440b power supply board in it. I can not find the correct schematic. The one I do have, the components' ID on the board do not match the components' ID on the schematic....making it difficult for correctly IDing the components. Will someone point me in the correct direction for troubleshooting this set? I surmise there is no voltage going to the standby. If any pics need to be accessed, I will be more than happy to do that! Sets that can only be operated by the remote are, IMHO, a PITA!Comment
As you mentioned the TV only works via remote. The touch sensitive buttons on the front of the TV panel may be at fault try powering up the TV and well its on, unplug the front touch sensitive buttons from the main board. See if the TV turns off after 5 minutes then..
I should note I have seen these touch sensitive buttons fail before also I have seen a corrupt EEPROM cause this issue as wellDid I leave the soldering iron on?Comment
I have done as suggested....no luck. I wasn't aware there were touch sensitive buttons on this model. BTW, where is the IR pick-up? Maybe someone can point me to the right place to get a schematic for this set? I haven't found one. Used to be able to get just about any make/model from Sams.
http://www.shopjimmy.com/samsung-bn9...-ir-sensor.htm
P-Touch and IR are on the same board.Never stop learning
Thanks for the info! When troubleshooting a dead condition, can the boards be removed from the set and worked on? This set has 4 boards (that I can see, anyway). Power supply board, a PCB that contains 2 HDMI inputs, ANT input, composite & audio inputs and output to the 2 speakers, a board that supplies voltage to back light LCDs, and a board that connects the touch sensitive buttons & IR. If this is the case, it sure would save a bunch of area!! I would really like a schematic for this chassis...any idea where I can access one??..........Sure would make things simpler!!
OK , when the set is dead, check and see if you still have standby Voltage, if it does, see if you have PS-ON signal.Never stop learning
I am going to have to take a break from repairing this set. as I am helping out friends who were effected (big time) by all the rain we had over the past couple of days...... I live in SC.....thanks to all who have guided me thru this so far. When I get back to "normal mode". I'll try (hopefully successfully) this one more time. Again. thanks! See y'all soon!Comment
Wish you all the best. I've seen the news and what happened there. Just horrible.Did I leave the soldering iron on?Comment
Finally, I am able to dedicate some time to try and repair this set. After helping friends, holiday activities, etc…..
I have been able to piddling around with it some. I believe, too, that the schematic I have isn't jiving with the components I have on this BN440-0440B board. I have searched for the stby 5.3v rectifier (DM857) but have yet to find it. I guess I'm used to Sams Photofacts…..”spoiled”.
Anyway, I didn't find the 5.3 stby volts. I measured for this voltage at the cable that runs from the power supply board to the board where the IR pick-up is located. All the fuses are OK. 120V AC is there. I have ~165v DC on the 2 filter capacitors (100uf @ 450v) as related to HOT ground. That's where I stand now. Any photos that are need can be supplied.Comment
Please upload good clear straight shot of the top and bottom sides of the board.Never stop learning
i think the board number above is a missing a number? maybe its a BN44-00440B.Comment
OK, What DCV do you have on connector CN802, make sure to put pin number, follow by pin name, and follow by the DCV reading for each pin.
Pictures provided by shopjimmy.Attached Filesif you find these attachements useful please consider making a small donation to the site
OK….here are the readings…...looks as if the 13v & 5v are low or non-existent.
Pin # Pin Name DC readine
1 B13V 2.3v ~ 1.9v
2 P_DM (DIM?) 0.25V ~ 0.15V
3 B13V 2.3V ~ 1.8V
4 N/C
5 B13V 2.3V ~ 1.8V
6 BLU_0N .23V ~ .03V
7 B13V 2.3V ~ 1.9V
8 GROUND
9 GROUND
10 GROUND
11 B5V .28V ~ .05V
12 A5V ~ 1.0V
13 B5V .28V ~ .05V
14 PS_ON ~ .69VComment
You have to have the connectors in place (boards connected) then make the DCV measurement, it will not be easy, you will need skinny probe.Never stop learning
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
This specification for the Samsung Galaxy Book Ion NP930XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ boardview and NP930XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 08:40 PM
This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 06:20 PM
- Loading...
