Samsung LN40E550
  • stonoguy
    • Jan 2012
    • 65
    Re: Samsung LN40E550
    Received the PCB and the set still cuts off then on after playing approx. 5 minutes or so. This is just like previously. Anything else I should check??
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #82
      im sorry to hear the replacement board hasnt fixed the issue try taking again the voltages on the psu when the sets working and when its not and post your findings.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        also check the power on the tcon.
        • stonoguy
          • Jan 2012
          • 65
          I had another unexpected medical emergence (in-law) that called me out of town and away from that HDTV.
          I looked at the MOSFET that I had replace and saw that one of the 3 'legs' connects directly to the 5 volt regulator rectifier. I replaced this rectifier and have played this set without any problems since ~ 10AM this morning (no back installed). (4/7). Hopefully this fix will rectify this on/off problem, We'll see! Will let the set play over night and until 10AM on 4/8 and see if any problems arise. Will assemble the set with stand and back and let play for a few hours and see what transpires. So far, so good! Fingers crossed!! Later on!
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #85
            Fingers crossed its now fixed it was a odd fault.
            • stonoguy
              • Jan 2012
              • 65
              Well, I thought it was fixed. Secured all the modules and installed the back & stand. Set played for about 30 minutes and 'poof'!....dead set! I haven't done a thing to this set as I am very 'frustrated' (a nice word for an expletive). Looks as if this is a thermal problem??....any suggestions?
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8352
                What exact part did you replace last time and its location (like D104) and with what did you replace it with? Any picture(s)?
                • stonoguy
                  • Jan 2012
                  • 65
                  Have checked and removed from the circuit the same parts that has been shorted previously....the MDD3752, P channel Trench MOSFET. The set goes dead but doesn't blow any fuse......strange.
                  • stonoguy
                    • Jan 2012
                    • 65
                    Pictures forthcoming.......
                    • stonoguy
                      • Jan 2012
                      • 65
                      MDD3752
                      P-Channel Trench MOSFET, -40V, -43A, 17mΩ
                      Can not find this part stocked anywhere I have looked in the USA...Mouser, Digikey....can get them from China.....replaced this with the same component. What is the significance of the negative v & A? Also, have found MDD3752RH.....What does RH mean? Would it be OK to use one of these? Also, this component is soldered to the circuit side of the module....the underside......TO-252 package.
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8352
                        Did you check the mosfet if it actually is bad? Is there a short to the gate of the mosfet?
                        • stonoguy
                          • Jan 2012
                          • 65
                          Yes, I have…the defective part:
                          Drain to Source= 0 ohms
                          Source to Gate = 760 ohms
                          Gate to Drain = 760 ohms
                          Shorted for sure!
                          I am assuming that the data sheet is correct: TO-252
                          Source is the right leg
                          The Gate is the left leg
                          The Drain is the tab.
                          With the defective component out of the circuit,
                          I found that the connection where the Source
                          is soldered, reads ~ 3M ohms…..drops to ~ 4K ohms
                          then increase again…...capacitor influence??
                          • TechGeek
                            Computer Geek
                            • Jan 2015
                            • 2254
                            Sounds like a capacitor receiving voltage from the multimeter probes.
                            Permanently Retired Systems:
                            Kooky and Kool Systems
                            sigpic
                            • stonoguy
                              • Jan 2012
                              • 65
                              I know that Digikey nor Mouser do not have MDD3752......The link to Newegg have them. They are from UTSOURCE. This is where I purchased the ones I have now. The description says these components are REFURBISHED.....huh? I never heard of a refurbished transistor!
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8352
                                maybe a working pull?
                                • stonoguy
                                  • Jan 2012
                                  • 65
                                  I am still out of town (In-laws medical)...no access to TV......since I am retired, I am the choice for my "services"! I will return (hopefully) soon! Thanks for the previous help!
                                  • stonoguy
                                    • Jan 2012
                                    • 65
                                    I am FINALLY back home!! Have soldered a new MOSFET to replace shorted one. Also replaced 13 volt regulator. Will give update on set progress....have a bunch of yard work to do.....
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #98
                                      Originally posted by stonoguy
                                      MDD3752
                                      It's a P Channel Mosfet so is a negative channel device. -40V means max voltage -40V (minus) and max current through device -43Amps (minus).
                                      N Channel Mosfet is positive channel device so would be +40V @ +43 Amps
                                      P and N Channel devices operate on reverse supply voltages.
                                        09-07-2024, 05:50 AM
                                        09-06-2024, 11:40 PM
                                        09-06-2024, 08:40 PM
                                        Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                                        This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-06-2024, 06:20 PM
