Samsung LN40E550
  • stonoguy
    • Jan 2012
    • 65
    Samsung LN40E550
    My mother's HDTV got hit by a power surge during a thunderstorm. The symptom of the set is that it plays fine for about 4 to 5 minutes then cuts off. Stays off (no sound or pix) then after about a minute or so, the set cuts back on and plays fine...then repeats the on/off scenario over and over. The TV is 3+ hours away...Was trying to get a grasp on what to check first. I worked on TVs for over 20 years when they had CRTs and flyback transformers. I have replaced capacitors and a shorted diode in a few of my LCD/LED sets, as well. Any thoughts? Point me in the correct if this isn't the right forum in which to post! Thanks!!
  • stonoguy
    • Jan 2012
    • 65
    Re: Samsung LN40E550
    I have more info....printed on the owners manual is 'SERIES 5 550'.
    Sounds as if a componet on the power supply board is heating up, shutting
    the set down, cooling off & the set returns to the ON mode. Am I off base
    here or should I wait until I get the set n front of me??
    • CapLeaker
      Leaking Member
      • 8146
      Not much you can do until you have the TV in front of you. Then you have to figure out is it the Main board causing this (losing PSon voltage to the PSU), or the PSU itself.
      • stonoguy
        • Jan 2012
        • 65
        I have FINALLY gotten the TV. The set played for about 30 minutes. I turned the set off to remove the probe I had attached to the HOT ground and went to turn on the set, it would not turn on. The set can only be controlled from the remote. Luckily, I have a Samsung TV that this remote will control. I checked the usual...fuses and such....no luck. It appears that this set has a BN44-00440b power supply board in it. I can not find the correct schematic. The one I do have, the components' ID on the board do not match the components' ID on the schematic....making it difficult for correctly IDing the components. Will someone point me in the correct direction for troubleshooting this set? I surmise there is no voltage going to the standby. If any pics need to be accessed, I will be more than happy to do that! Sets that can only be operated by the remote are, IMHO, a PITA!
        • freakaftr8
          • Oct 2012
          • 3743
          As you mentioned the TV only works via remote. The touch sensitive buttons on the front of the TV panel may be at fault try powering up the TV and well its on, unplug the front touch sensitive buttons from the main board. See if the TV turns off after 5 minutes then..
          I should note I have seen these touch sensitive buttons fail before also I have seen a corrupt EEPROM cause this issue as well
          • stonoguy
            • Jan 2012
            • 65
            I have done as suggested....no luck. I wasn't aware there were touch sensitive buttons on this model. BTW, where is the IR pick-up? Maybe someone can point me to the right place to get a schematic for this set? I haven't found one. Used to be able to get just about any make/model from Sams.
              http://www.shopjimmy.com/samsung-bn9...-ir-sensor.htm
              P-Touch and IR are on the same board.
              • stonoguy
                • Jan 2012
                • 65
                Thanks for the info! When troubleshooting a dead condition, can the boards be removed from the set and worked on? This set has 4 boards (that I can see, anyway). Power supply board, a PCB that contains 2 HDMI inputs, ANT input, composite & audio inputs and output to the 2 speakers, a board that supplies voltage to back light LCDs, and a board that connects the touch sensitive buttons & IR. If this is the case, it sure would save a bunch of area!! I would really like a schematic for this chassis...any idea where I can access one??..........Sure would make things simpler!!
                • stonoguy
                  • Jan 2012
                  • 65
                  I believe I have acquired a schematic....what voltages are supposed to be present? I had ~400 volts on the 2 filter caps when the set was playing....now that the set is dead, the voltage is ~ 168 volts.
                    OK , when the set is dead, check and see if you still have standby Voltage, if it does, see if you have PS-ON signal.
                    • stonoguy
                      • Jan 2012
                      • 65
                      I am going to have to take a break from repairing this set. as I am helping out friends who were effected (big time) by all the rain we had over the past couple of days...... I live in SC.....thanks to all who have guided me thru this so far. When I get back to "normal mode". I'll try (hopefully successfully) this one more time. Again. thanks! See y'all soon!
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Wish you all the best. I've seen the news and what happened there. Just horrible.
                        • stonoguy
                          • Jan 2012
                          • 65
                          Finally, I am able to dedicate some time to try and repair this set. After helping friends, holiday activities, etc…..
                          I have been able to piddling around with it some. I believe, too, that the schematic I have isn't jiving with the components I have on this BN440-0440B board. I have searched for the stby 5.3v rectifier (DM857) but have yet to find it. I guess I'm used to Sams Photofacts…..”spoiled”.
                          Anyway, I didn't find the 5.3 stby volts. I measured for this voltage at the cable that runs from the power supply board to the board where the IR pick-up is located. All the fuses are OK. 120V AC is there. I have ~165v DC on the 2 filter capacitors (100uf @ 450v) as related to HOT ground. That's where I stand now. Any photos that are need can be supplied.
                            Please upload good clear straight shot of the top and bottom sides of the board.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              i think the board number above is a missing a number? maybe its a BN44-00440B.
                              • stonoguy
                                • Jan 2012
                                • 65
                                You are correct!
                                • stonoguy
                                  • Jan 2012
                                  • 65
                                  Here are photos...if not adequate, please advise......Thanks!
                                    OK, What DCV do you have on connector CN802, make sure to put pin number, follow by pin name, and follow by the DCV reading for each pin.
                                    Pictures provided by shopjimmy.
                                    • stonoguy
                                      • Jan 2012
                                      • 65
                                      OK….here are the readings…...looks as if the 13v & 5v are low or non-existent.
                                      Pin # Pin Name DC readine
                                      1 B13V 2.3v ~ 1.9v
                                      2 P_DM (DIM?) 0.25V ~ 0.15V
                                      3 B13V 2.3V ~ 1.8V
                                      4 N/C
                                      5 B13V 2.3V ~ 1.8V
                                      6 BLU_0N .23V ~ .03V
                                      7 B13V 2.3V ~ 1.9V
                                      8 GROUND
                                      9 GROUND
                                      10 GROUND
                                      11 B5V .28V ~ .05V
                                      12 A5V ~ 1.0V
                                      13 B5V .28V ~ .05V
                                      14 PS_ON ~ .69V
                                        You have to have the connectors in place (boards connected) then make the DCV measurement, it will not be easy, you will need skinny probe.
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
