Bush DLED40127FHDS white screen
  • RULEX
    • Sep 2013
    • 7
    • IRELAND
    I have Bush DLED40127FHDS with white screen,sound is good.Power supply is Vestel 17IPS20,
    mainAV 17MB95S-1,
    T-CON S60TVAMB4C2LV0.0
    Power supply output voltages is 3.3v,5.3v,11.9v,23.4v
    T-CON board fuse is good,voltage on it 11.7v also is 1.8v and 3.2v.
    When T-CON LCD panel ribbon cable unplugged one screen side get black other stay white,same when unplugged other ribbon,only changes black and white with out picture.What should I check?Which board could be faulty?
    Re: Bush DLED40127FHDS white screen
    Pictures of the T-CON board?
    You will need the Oscilloscope to see if you are getting any signals at all on the LVDS connector.
    • RULEX
      • Sep 2013
      • 7
      • IRELAND
      Hi,thanks for quick reply.There is TV board pictures.
      I don't have the Oscilloscope,is there other way to diagnose the boards?
      • CapLeaker
        Leaking Member
        • 8352
        using a oscilloscope and check the LVDS signal from the main board is the only way I know how to make sure that the main board is putting a signal out. Other than that, I'd say you have a T-Con problem. If you want to make sure it isn't the main board, you have to borrow an oscilloscope.
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
